      07-18-2021, 09:44 PM   #1
DrGadget
DrGadget's Avatar
Australia
58
331
Drives: M140i F20 LCI-2
2018 BMW M140i  [8.50]
Map Update Australia/New Zealand EVO 2021-1
At long last this latest Map Update (Australia/New Zealand EVO 2021-1) is available for download via BMW Download Manager (for Windows & Mac). It unzips to a 32Gb+ USB stick (ex-fat formatted) and then inserted into whichever of your USB ports is connected to the bus system (my M140i has two such ports).
Enjoy!
Current: Alpine White M140i F20 LCI-2, 250kW/335hp, 2018.
Sold: Melbourne Red 340i F30 LCI Luxury Line MMPK - 265kW/355hp, 2016.
Sold: Alpine White 123d e82, 2010, 150kW/204hp.
      07-22-2021, 09:39 PM   #2
DrGadget
DrGadget's Avatar
Australia
58
331
Send to Car not working? [Solution]
Forget about using Google maps to directly send a destination to your BMW. If you are subscribed (Booked in BMW parlance) to Connected Drive+, use the latest iteration of the MyBMW app on your Android smartphone or iPhone, and if still not working correctly, follow this advice from BMW:
-In the main menu in your car, select "ConnectedDrive".
-Press the Option button on your controller at the center console.
-Select "Update BMW Services".
-Select "OK".
If the issue still persist, please proceed with a Soft Reset or Reboot by doing the following:
Press and hold the volume button for 30 seconds while the engine is running until it shuts down completely. Then, press the button again to turn it back on.
Moreover, please make sure that the Data Privacy in your vehicle are active, to check this, please go to Car > Settings > General Settings > Data Privacy > Agree and activate all.
Once done, please log out from the app and log in again. Then please try if the "Send Destination to Car" is working.
It works!
      07-22-2021, 10:53 PM   #3
gchriste
gchriste's Avatar
14
28
Drives: BMW M440i xdrive
I had given up, thought they had forgotten us forever!
Will give it a go tonight
