12-29-2020, 07:58 PM | #1 |
eBay Special
3751
Rep 3,210
Drives: E90 330xi, E90 328xi
Who here likes to work on motorcycles?
In addition to my cafe racer thread, I might be pulling the plug on somewhat of a mechanics special. Unlucky for me I've never worked on one before and could use some assistance
Common sense is a flower that does not bloom in everyone's garden
12-29-2020, 08:18 PM | #2 |
3144
Rep 5,583
This was going to be my place to do self maintenance. Search for similar places in your area. http://baltomoco.com
Bike are relatively easy to work on. When I was 25 and not having much engine experience (worked on karts at the track twice and watched/helped a friend work on the head gasket of a 2.0 Liter Lotus engine in a Jensen) Anyway, when I was 25 had access to a neighborhood filling station garage and rebuilt a Honda engine in a non runner and had a little motorcycle to ride in the hills. Tip: Bike had a fuel leak from the gravity fed and the the bike was pushed by a friend with the transmission in gear and the spark plug cable hanging loose ignited the bike and that was the end of it. Bikes are pretty easy to work on since they are small and easily accessible. Some Italian valve trains are very specialized and some electrical systems with computers need specialized knowledge. But with YouTube and if u have some innate mechanical skills... And what you can't do yourself, you can usually carry a part easily to a machine shop or garage and have then do that section of work. Last edited by overcoil; 12-29-2020 at 08:58 PM.. |
colorado.e9x3750.50 Efthreeoh19714.50 |
12-29-2020, 08:35 PM | #3 |
eBay Special
3751
Rep 3,210
Thank you for building my confidence a little bit more I read that a couple times
12-30-2020, 01:03 AM | #4 |
5362
Rep 2,020
Drives: Here and There
Garage List (2)11 BMW E90M Stri ... [10.00]
(1)11 BMW E90M Stri ... [10.00] 98 Lexus LS400 [10.00] 16 Toyota Land Cruiser [10.00] 97 Toyota Land Cruiser [8.33] |
Check out "Saturday's Wrench" on YouTube.
Watch his CB350 build in order. That'll get you in the mood! https://www.youtube.com/playlist?lis...Pq35ieq4_FO9Tg |
colorado.e9x3750.50 |
12-30-2020, 01:29 AM | #5 |
727
Rep 946
Worked on my dirtbike and atv’s a bit if that counts
07 E92 335i 6MT, MMP inlets, DCI, VRSF 7.5 competition intercooler, VRSF catless downpipes, VRSF chargepipe, 335is clutch, Vader Solutions stage 2 LPFP, MHD stage 2+, Hawk HPS 5.0 pads, R1 Concepts drilled slotted rotors, TSW Nurburgring 19x8 19x9.5
12-30-2020, 03:26 AM | #6 | |
#buildnotbought
14367
Rep 5,572
Although that might vary from brand to brand. 2 weeks ago I had to diagnose an ECU problem on my royal enfield but workings and pinout of the ecu was a very vague and pixalated picture in the workshop manual. Luckily it was not the ECU itself but a problem in the wiring loom. But really diagnosing the ecu... I'd have no clue what interface or program to use (the blink sequences of the eml light tell only little)
12-30-2020, 06:13 AM | #7 | |
5589
Rep 3,361
12-30-2020, 07:54 AM | #8 |
81
Rep 84
Kinda depends on the motorcycle too. Parts for 1980s bike can tough to find, 1970s bikes are collectible enough to have a large aftermarket, 1990s parts should still be around.
For the 1980s Japanese bikes I have rescued, it has comes down to a few things that will make or break a project. 1. Getting the fuel tank clean and leak-free. 2. Rebuilding and adjusting the carbs. Everything else is just cleaning, replacing (bearings, tires, etc), and refurbishing to your liking. Maybe let us know what bike you are looking to get into? A 1980s Honda V-Four would be a different ball game than a 1970s twin or single. Fwiw, I usually don't really mod, just back to stock... |
12-30-2020, 08:17 AM | #9 | |
5589
Rep 3,361
12-30-2020, 10:18 AM | #10 | |||
eBay Special
3751
Rep 3,210
Absolutely it does Quote:
12-30-2020, 10:45 AM | #11 |
486
Rep 637
My only recommendation is to look at basic wear parts. It's one thing to have something not working and knowing you may need to spend some money to get it working. It's another thing when you have to deal with that and overall lack of proper maintenance as the price really starts to go up.
When you look at the bike check out the tires, brakes, suspension, look inside the gas tank for rust and look around the bike for signs of leaks like near the carbs. You should have a good idea on what you're getting into. Also, just as a general comment, if people can't get something working then in my experience general maintenance is also very poor. It's much rarer to find a unfinished project with a lot of new parts but it's being sold because the person has no time. |
12-30-2020, 10:57 AM | #12 |
19715
Rep 20,004
I'll chime in.
Been a life long motorcyclist from 13 years old. My first motorcycle was a dirt bike, a 1974 Indian ME100A (Googleit ). Even in 1974 it was almost impossible to get parts for it. The bike used a Taiwanese copy of a Rotax 100cc thumper. The shifter mechanism was a POS and used a 5-bump cam plate that wore out and I had to reweld material on it, then re-file the profiles. I was 14 years old at the time... It was a great learning experience. Anyway, I think your question needs context. What type of motorcycle is it and how big is it, and what is your level of tolerance for kneeling and lying on the floor while turning wrenches? Wheel, brake and tire work is a PIA unless the bike is lifted or has a centerstand. Most motorcycle engines are compact and need smaller tools, which you may not currently have in your tool set. The valves are tiny on most engines and use solid lifters that require periodic adjustment. If the bike you are considering has sat for a while and was not properly stored, expect the carburetor(s) to be trash. That means cleaning or replacing the jets and then synching the carbs, which requires a multi-gauge vacuum gauge set. If it's really old, look forward to replacing all the vacuum lines. If you have good automotive wrench skills they mostly translate over to motorcycles, other than the platform is a bit different and getting a comfortable work height is difficult because motorcycles are unstable from the outset and get more unstable as you remove components. While I enjoy working on cars, motorcycles not so much. If I would invest in a lifting apparatus to get to a comfortable working height I'd like it more, but I'm not willing to commit to it. My current bike is a 20 year old Honda Valkyrie, which is a flat-6 full-dress cruiser. I usually let a pro handle most of the repairs above oil changes, plugs and electrical issues above the seat level. It's a Honda, so it doesn't break much, and I don't ride much anymore so maintenance is few and far between. I have a Clymer's for it, which has been adequate to keep it maintained. Before the Valk, I had a Honda CBR 1000 Hurricane and a Kawasaki Concours, both with in-line 4's and each was a PIA to work on. My 2 cents.
zx10guy5589.00 colorado.e9x3750.50 |
12-30-2020, 12:45 PM | #13 | |
5589
Rep 3,361
Frankly, I'm surprised Pitbull hasn't come out with a frame lift stand such as this: https://www.bursigusa.com/ They are the originators of this design as there have been some copycats out there. The fact they're still around speaks volumes towards their quality and commitment to have custom brackets for each new model motorcycle. Oh and working on motorcycles requires extra attention to torque values. The parts tend to be lightened and small as you've said. The risk of snapping something goes way up when working on bikes. I hamfisted my first repair job on a I think an 89 ZX750 and ended up snapping a bolt to the clutch basket. Fortunately, there was enough of the bolt sticking out that I was able to manually work the stub back out. |
Efthreeoh19714.50 colorado.e9x3750.50 |
12-30-2020, 01:56 PM | #14 | |
#buildnotbought
14367
Rep 5,572
TIS is integrated in ISTA But regarding the motorcycles: I'm not only talking about the service manuals, I'm also talking about the diagnose/programming software. I think newer motorcycles now become obd compatibe, but I think lots of them had complete proprietory interface systems not so long ago. Luckily my 1935 BSA has none such things
12-30-2020, 02:00 PM | #15 |
#buildnotbought
14367
Rep 5,572
I don't understand. Are you sure this comment is directed at my post?
12-30-2020, 02:09 PM | #16 | |
19715
Rep 20,004
I bought the Sears craftsman ATV/Motorcycle lift years back. I tried it once. Scared the poop out of me. The Big Girl weighs in at 476 pounds; I figure it'd hurt if she fell on me.
zx10guy5589.00 |
12-30-2020, 06:01 PM | #17 | |
5589
Rep 3,361
Did you know my BMW C650 Sport Maxiscooter tips the scales at 525 lbs? The GT version does it at 550 lbs. |
12-30-2020, 06:07 PM | #18 | |
5589
Rep 3,361
As far as the diagnostic software with BMW, there is GS 911. I just purchased it for my BMW scoot. I only really got it because of the need to use it to reset the service reminder indicator. https://www.beemershop.com/category/...eemershop.html With my Ninja, haven't had the need to find what scan tool options are out there for it as it's been rock solid reliable so far. And strangely enough, the same seems to have applied to my Ducati although I did have issues with the immobilizer system while under warranty. |
12-30-2020, 11:38 PM | #19 |
eBay Special
3751
Rep 3,210
Y'all have given me tons to consider though to be honest as of now it still sounds like fun. A pain in the ass kind of fun. I'm thin so my hands tend to fit into areas a little easier. And considering alls I do is work on either car ramps or jack stands, laying on the ground a bit more with a bike doesnt sound any worse. Good point on investing in a lift though. If I couldn't find a way to make that happen my Dad is a an excellent carpenter. Haha
Heres some info on the bike in question: 1983 Yamaha Virago XV920, 33k Miles. Price: $850 Cosmetically it's not in the best shape but that doesn't matter when all of that would be replaced. This year and model in specific has some sentimental value to me and finding it for this price and mileage is a really good deal in my area. Most out here (all being 5+ hrs away from me) are around $1,800 and have at least 95k on them. Here are some notes listed by the seller Pros: -New Starter motor and gear -New battery -Rebuilt and cleaned carb -Adjusted float level and idle -New Spark plugs -Re-routed and replaced all fuel and vacuum lines. -New Petcock -New oil filter, oil, and cleaned crankcase -Adjusted suspension settings -Replaced all stripped bolts -De-rusted and sealed gas tank -Extra brand new battery -Single side view mirror -New OEM clutch lever -Bolt kit -Clymer Service Manual Cons: -Compression in both cylinders are a little low, adding oil to the cylinders increases the compression more than 20% which tells him the rings are shot -Adding to above, it burns a little oil and doesn't have the power it could -No title but be has the original bill of sale, he ran the serial # through the local sheriff's office and it didn't come up as stolen or anything like that -Wiring seems to be a little jerry rigged As far as registration I'm not too concerned. There's a couple ways I can try to get a title. If I truly can't I could either buy a frame with a clean title and swap everything over. Police in my area don't seem to care much about it anyways so taking it around the block for a few minutes without plates probably wouldnt hurt either
Efthreeoh19714.50 |
12-31-2020, 10:03 AM | #20 | |
19715
Rep 20,004
Apologies.
12-31-2020, 10:10 AM | #21 | |
19715
Rep 20,004
12-31-2020, 04:01 PM | #22 |
eBay Special
3751
Rep 3,210
Doesn't sound horrible, I think there's a local shop or two that'd be able to do it. Other than that it seems like they're solid bikes eh?
