09-20-2020, 05:00 PM | #3 |
847
Rep 1,962
Nope. M2 used M Performance suspension (rebadged KW V3), while M3 and M4 just use Height Adjustable Springs - hence the name - with the existing electronically controlled dampers.
09-20-2020, 05:04 PM | #4 |
In the Details
1812
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
Acetech218.50 |
09-24-2020, 07:12 PM | #7 |
219
Rep 275
Well the link above clearly indicates the single part # KW HAS kit fits F80-82 & F87M2
Considering that I wager the F80/82 M performance HAS kit ( manufactured by KW for BMW) would likely work on the F87 but why bother when the KW HAS kit is directly approved for F87 M2 and significantly less expensive than M performance kit. |
09-25-2020, 02:07 AM | #8 |
847
Rep 1,962
The reason the F80-82 BMW HAS kit apparently works on those models but not the F87 is supposedly the active dampers on the former that the latter lacks.
The CS has the active dampers, and hence the question. HTH |
09-25-2020, 06:34 AM | #9 | |
In the Details
1812
Rep 867
Drives: Yes
if you scroll down and see the list of compatible cars you will see M2, M3, M4 and then if you consider what that means, when the M3 and M4 already had adaptive suspension, the point becomes, yes, the same kit will work on the M2CS with adaptive suspension. what do you think is special about the adaptive suspension that makes it need different springs? |
09-25-2020, 06:41 AM | #11 |
847
Rep 1,962
I don't think it needs different springs, more that the adaptive dampers on the F80-82 can apparently cope with the HAS kit, whereas the non-adaptive dampers on the F87 OG and LCI struggle.
So, noting that the CS has adaptive dampers I was wondering whether the F80-82 HAS kit would work on that car even though it apparently doesn't on the OG and LCI. I am aware of the KW HAS kit, and that it is listed as having broader application than just the F80-82. |
09-25-2020, 06:42 AM | #12 |
In the Details
1812
Rep 867
Drives: Yes
https://www.kwsuspensions.com/kw-sus...253200anu.html
Notes 91: Front and rear height adjustable (front and rear springs with threaded height adjusters). Stock shock absorbers including electronic controls are being utilized. |
09-25-2020, 09:47 AM | #14 |
96
Rep 71
09-26-2020, 06:01 PM | #15 |
847
Rep 1,962
09-27-2020, 05:31 AM | #16 |
1030
Rep 1,191
Spring rates are partially decided based on a cars wheelbase. F80 springs will be a few percent off for an F87 in terms of front to rear balance. Will you notice? Maybe. Would I? Yes.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
09-27-2020, 09:57 AM | #17 |
219
Rep 275
OP, where are you getting your information from?
I haven't yet checked the ETK parts catalog at work to see I'd the CS is listed yet, realoem doesn't list it yet. But here is a screen shot of a previous post here stating that the M2CS uses the same springs front and rear as both OG &C M2. It also indicates the shocks/struts are the same part number as F80-82-83 with EDC. |
09-28-2020, 12:31 PM | #18 |
847
Rep 1,962
I think we might be talking at crossed purposes, but this is why I think the parts are different on the M2 compared to the M3/4:
https://www.realoem.com/bmw/enUS/par...&q=31312289535 https://www.realoem.com/bmw/enUS/par...&q=31312289536 https://www.realoem.com/bmw/enUS/par...&q=31337853270 https://www.realoem.com/bmw/enUS/par...&q=33522289537 https://www.realoem.com/bmw/enUS/par...&q=33537853275 |
10-21-2020, 01:58 PM | #19 |
1943
Rep 1,552
I assume we don't have any more clarity yet on what springs may work for the CS application right?
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
12-20-2020, 07:23 AM | #20 |
IG@i.am.wah
2780
Rep 3,815
Drives: M2 CS
Did you ever determine if the F8x MP HAS kit would work? If I trade in my M4 I may pull the HAS kit if it can be reused.
12-20-2020, 11:41 AM | #21 |
1943
Rep 1,552
i have ordered the KW HAS and plan to try it right when I get my car
Hedoniste3877.50 |
12-20-2020, 12:39 PM | #22 |
2865
Rep 3,844
I installed the Dinan springs on my M235i with adaptive suspension. I know it's not an M car, the programming of the adaptive suspension sometimes got it wrong with the springs. For instance driving on the freeway at 70 mph it became very stiff and jiggly. I remember on some BMWs the tuners came out with a hack for the adaptive suspension to take into consideration the springs. Sadly they were never able to hack the adaptive suspension on the M235i. One of the main reasons I sold the M235i was because I could never get the suspension right.
