07-19-2020, 08:39 PM | #1 |
Joint Chiefs of Staff
24454
Rep 191,382
Turbo Transformer Boost Controller. Simple, Reliable & Fun!
I had the chance today to try the Turbo Transformer in my car, and I'm very impressed!
It's a very simple piggyback with only two sensors to connect. It'll take a few minutes to install. One of its best features is Bluetooth capability that allows you to use the TT app to change maps and settings. I took a few screenshots of the app,and I figured i would show you how it works. Setup
Base PSI: This is the PSI level at which the tuner is active. when your boost is below this PSI, the unit is not active and the car is running at stock power Delta PSI: This is the maximum amount of PSI the unit will be adding to stock. Its set to +2 PSI by default but can be increased to +4 PSI (please use with caution) Slope (Rate):
Graph:
Power Modes
Power Default
Max Eco
Hybrid
Custom
07-22-2020, 10:43 AM | #5 |
24454
Rep 191,382
BBH15.00 |
08-13-2020, 09:10 AM | #6 |
24454
Rep 191,382
08-13-2020, 10:19 AM | #7 | |
13
Rep 47
08-13-2020, 11:44 AM | #8 |
24454
Rep 191,382
I would start with 1 PSI and datalog to make sure the car is handling the extra boost well. As long as your datalog is clean, you can raise boost
08-14-2020, 09:18 AM | #10 |
24454
Rep 191,382
08-20-2020, 01:40 PM | #11 |
24454
Rep 191,382
08-27-2020, 11:08 AM | #12 |
24454
Rep 191,382
