      09-10-2008, 08:07 PM   #1
calvino
318
1,928
Drives: had e90, 330i mystic blue
2006 e90 330i  [0.00]
Thumbs up Car Parts.
I found this website that have a bunch of fake cars parts, if you are a car aficionado or a mechanic you are going to find it hilarious the site looks extremely real, products have descriptions, reviews, pictures etc.. check it out.
www.kalecoauto.com
here are some examples:
Engine Oil Bypass Kit $49.95
Modern synthetic oil is very expensive - so why run the risk of getting it dirty by running it through your motor block? KaleCoAuto bypass kit comes with everything you need to run the oil around your motor block where it will do more good. Oil runs cooler, and as a result, there may be horsepower gains!
reviews:
I have to say this.. I LOVE this oil bypass kit! It is really cheap and it does a great job! I got this kit installed on my 04 Enzo. And it totally keeps my engine oil clean! Seems like I will never have to do oil change. You know what's special about this kit? It makes your car sounds stronger! After I got the kit installed then my engine started knocking! Sounds like a very powerful muscle car with butterfly valve! Highly recommended!
Cross Drilled Brake Lines $69.95
Want improved braking? Why just cross drill those rotors? Introducing KaleCoAuto cross drilled brake lines! Improved airflow through lines provides superior brake cooling. Brake fluid is exposed to cool moving air, almost instantly reducing heat, and providing shorter stopping distances! All lines are made of quality latex. Brake lines come in: Red and Yellow. Please specify color when ordering!! Warning!! You must replace ALL brake lines at once. You may mix colors.
the list goes on they have products such as Adjustable Powerband , Radiator Insulator , Tampon Dispenser (For Automatic Vehicles) etc...
E90 Mytic Blue 330i 07-20-2006. 05-17-2011
Doesn't the idea of making nature against the law seem to you a bit . . . unnatural? Support NORML
