09-15-2019, 07:01 AM | #1 |
27
Rep 71
But will it float ?
One design feature of the G20 is that it has an aerodynamically clean underside to the chassis the only things hanging down are the wheels. The prop shaft is above the under tray as is also the back axle and the petrol tank. the underside is recessed so that the exhaust pipe and silencers and catalytic converters are all up and out of the airstream. There is also a close fitting cover tray below the engine and associated gubbins and the rear suspension arms are fitted with aerofoil plates to smooth flow over them .
My mind says what happens, heaven forbid, if on a dark road on a stormy night at speed you hit floodwater ? More than 15 cm of depth and you could be in for a nautical experience I wonder if the BMW bods in the design office have run this through their test programme ? If so what are the critical limits in order to maintain affinity with terra firma ? |
09-15-2019, 07:37 AM | #2 |
Grumpy Old Git
443
Rep 923
Drives: BMW G20 330i RWD M Sport
Love that thought process
Retired:
F10 520D M Sport E60 520D SE Volvo S60 type R |
09-16-2019, 01:14 PM | #4 |
8576
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
And I thought my wife was a "worrier"!
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
09-16-2019, 02:28 PM | #5 |
27
Rep 71
Best not tell her about the G20's amphibious potential then... ! Last edited by Bumble; 09-16-2019 at 02:47 PM.. |
