06-25-2019, 08:15 AM | #1 |
3932
Rep 3,134
NEW RELEASE: Dinan F90 M5 Adjustable Performance Coil-Over Suspension System (HAS Kit
Dinan F90 M5 Adjustable Performance Coil-Over Suspension System (HAS Kit) Part Number: D190-0901 Applications: 2018-2019 F90 M5 Product Page(s) / Additional Photos / Pricing: Click Here Recommended Install Time: 10.5 Hours (includes alignment) Release Date: Available Now! Description: For the driver that demands the best out of their vehicle. The Dinan Adjustable Coil-Over Suspension was bred in the race lab but refined on the street for maximum versatility. No matter the environment, the traction that is bestowed upon the vehicle from the improved suspension will inspire new found confidence when running at higher speeds. From the substantial reduction in body roll as well as reduction of dive under breaking and squat under acceleration, Dinan guarantees you superior handling, performance, and comfort. Dinan's design retains the superb factory electronic shocks but swaps the springs to a more aggressive formula and implements threaded collars to allow the user to change the ride height. While a stiffer spring is typically associated with diminished ride quality Dinan has also swapped the progressive rate rear springs in favor of a much more predictable linear rate spring design. This allows for a more compliant feel while still being able to enjoy the benefits of a stiffer setup such as the reduction in body roll. The end result is a sleek lowered stance that provides improved handling to go along with its stunning visual appearance. The springs combined with progressive bump stops and other components increase travel that allows the car to be lowered an incredibly low 2" in the front and 2-1/8" in the rear. However, in order to retain the ride quality synonymous with Dinan suspension kits the recommended drop of 1" in front and 1-1/8" in the rear is advised. For suspension connoisseurs or those that are just simply very particular, suspension packers are included to fine tune handling and comfort by changing the clearance of the progressive bump-stops, something no respectable race car is without. Features/Benefits:
*Note: Due to the extensive lowering possible, and the increased suspension travel, the installer must carefully evaluate tire clearance under all situations. Safety will be compromised if all precautions are not taken. Dinan is not responsible for any property damage or injury. |
07-04-2019, 11:09 AM | #2 |
383
Rep 161
Can you clarify what dimensioned ride quality means exactly? Does it also impact performance aspects? I'm looking for about a 1.5in drop for reference.
07-05-2019, 12:33 AM | #3 |
15
Rep 36
I have "ruined" a few cars with dropping and/or stiffening too much, but any suspension changes to a car over 4,000 lbs have always been awesome. I bet this kit, with the least amount of drop, is awesome. Just my $0.02.
07-06-2019, 11:14 AM | #4 | |
575
Rep 754
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48 JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18 IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires |
07-08-2019, 07:51 AM | #5 | |||
3932
Rep 3,134
The below photo as well as the one in the original post are with the recommended drop of 1" in the front and 1.125" inch in the rear. Please keep in mind the car is also running 20's with 285/35s in front and 295/35's in the rear. |
07-08-2019, 11:48 AM | #6 | |
575
Rep 754
Yea, the pic in your first post was from the front. This picture from the side is perfect and I can see the wheel gap much better. And I like the 20's on it a lot! Car is sitting nicely
