05-28-2019, 06:49 PM | #1 |
31
Rep 199
Mirror cap removal?
Has anyone managed to remove the mirror caps on their M340? I got some gloss black vinyl to cover the hideous gray but they seem to be a bit more difficult to remove than the F22/30 caps I removed in the past. Not sure I want to go hulk mode unless I know they actually pop off as expected.
05-28-2019, 09:23 PM | #2 | |
216
Rep 274
I am also going to have to remove mine when I order the carbon fiber ones and interested to hear how it goes. |
05-28-2019, 10:31 PM | #3 |
31
Rep 199
No I haven't. I'll have to give that a try. On my M235, there was enough of a lip to get a hold of to just pop the caps off. The M340 doesn't seem to have a good place to get a trim tool in to pry. I'll see if the glass removal yields better results tomorrow.
05-29-2019, 05:07 PM | #4 |
31
Rep 199
Well it is nowhere near as easy. I was able to pop the glass off, removed some screws and still couldn't get the caps off. Seems to be more work than expected so before I go breaking something, I'll try to find some instructions. Since there are CF caps available, I'd imagine there are some instructions for them somewhere?
05-30-2019, 06:39 AM | #6 | |
216
Rep 274
Is there installation instructions for the G20 carbon fiber caps that I ordered? It would be helpful for the group here. |
05-30-2019, 09:40 AM | #7 |
284
Rep 402
I ordered primered mirror caps, had them painted, and then had the dealer remove the cerium gray caps and install the painted ones. They said they tried but were unable to remove the original mirror caps without breaking some of the tabs off.
05-30-2019, 09:53 AM | #8 |
50
Rep 243
That's kinda crazy that they couldn't remove the stock ones without breaking tabs. I wanna replace the stock ones with cf but if that's the case it may not be worth it if I can't put the stock ones back on when I have to return the lease.
05-30-2019, 10:02 AM | #9 | |
31
Rep 199
I had the glass off, gloss black surround off, about 6 screws out and still couldn't even remotely get it off without feeling like I was going to break something so I aborted and put it back together. If I had to guess, I'd say the whole mirror may need to come off if you don't want to break something. |
05-30-2019, 12:04 PM | #11 |
2713
Rep 7,300
Hello!
Unfortunately, BMW has not yet provided us with a PDF Installation guide on removing and adding the new CF Mirror Caps. -Britney |
CrownRoyal79284.00 vicfalc09216.00 |
06-02-2019, 06:08 PM | #12 |
216
Rep 274
Just had mirror glass off there are about 4 different wired connections on the back. There are two tabs on the top circled in red. I popped those but still couldn't get the mirror cap off. My CF ones are coming Thursday...I am going to look at the tabs on those and see how they click in and hopefully that will help determine how to get them off.
Preciseyyc162.00 |
06-11-2019, 12:57 PM | #13 | |
76
Rep 67
05-13-2020, 09:27 AM | #19 |
37
Rep 58
I got it off without taking the mirror by tilting mirror down and the. Popping top two clips and prying it off. Worked well without breaking any clips and saved risking cracking the mirror. Unfortunately, one of the mirrors wasn't a fantastic fit so going to try and get it replaced. Otherwise they are fantastic.
G20 M340i portimao blue
01-16-2021, 10:20 PM | #20 |
Driver
102
Rep 659
Did anyone go the route of vinyl wrapping the mirror caps without popping them out?
The indicator area makes me think the cap will have to get taken off to do it, but I hope I am wrong.
2009 E92 335i
2012 E92 335is 2015 F30 435i 2018 CLA250 2021 G20 M340i (current) |
03-19-2021, 02:46 PM | #21 | |
Rep 4
Did you apply transparent protective film on your mirror cap housings? I was wondering if bmw applied it after manufacturing |
03-19-2021, 02:51 PM | #22 | |
Rep 4
I need to show to my friend in local service. This thing is really got me thinking. What is the point of that film etc |
