      08-06-2008, 02:04 AM   #1
gmoney
34
240
Drives: 335 Coupe
SATA drive question...
Hey computer experts here... I accidentally dropped my external WD hard drive. it only fell a few inches onto my carpet, but it was enough where now I can't access my music. So I thought about slaving it on my desktop, like I have done in the past with IDE drives, but it's proving difficult.
I purchased a SATA to IDE adapter, as well as a SATA PCI card, and no luck; the drive isn't detected in My Comptuer, or in BIOS. Is it because I'm connecting it to a MB that's just too old? Is is a drivers issue?
How can I try accessing my SATA drive from this PC? Thanks!
      08-06-2008, 02:26 AM   #2
solefald
Nigerian Prince
solefald's Avatar
Vatican City State
400
2,180
Drives: '11 F25
'11 BMW F25  [0.00]
There may be a setting in BIOS to enable SATA bus first, before the drives actually show up. There also may be a simple driver that came with your PCI card, that will make it show up in Windows. But PCI device is a PCI device. It has to meet specs, so it should work in every computer with PCI slot available.
      08-06-2008, 03:43 AM   #3
.:bHd:.
.:bHd:.'s Avatar
Armenia
367
1,149
Drives: E92 335i MT
The problem may not be from your computer but your WD hard drive. If you have a MyBook you're fucked my friend. I have the 2TB studio edition and I've been able to use the eSATA port on it once. Ever since that either my Macpro doesnt see it or it makes my comp crash. Like it wont start lol. I will never ever buy another WD product again. Its the second one that has sucked balls already.
      08-06-2008, 07:51 AM   #4
clark192
clark192's Avatar
Bahrain
17
230
Drives: 2006 325i (EU)
sucks to be you man, but ive got 2 drives in my tower and both run flawlessless now for 2+ years. not a single complaint, and they are both nice and silent.
to the OP...does the drive spin? thats the first clue its still working. if its not....well then you had better take it to a recovery shop if you really want whats on it. if it is spinning, then i would suggest opening the case (i think for the MyBooks you have to break it open, after unscrewing it the case) and try getting a SATA to USB converter from eBay for like 15 bux, and running it as an external drive that way. you might have damaged the onboard controller for the case and the HDD might still work. if that doesnt work, then you just might be SOL, sorry man.
      08-06-2008, 11:07 PM   #5
gmoney
34
240
Drives: 335 Coupe
Thanks clark192... I'll try that :-)
      08-06-2008, 11:27 PM   #6
nOLd
nOLd's Avatar
18
202
Drives: 2008 Z4 MCoupe Interlagos Blue
Also make sure that your power supply is SATA ready if not you can buy a power cable adapter
      08-07-2008, 12:03 AM   #7
.:bHd:.
.:bHd:.'s Avatar
Armenia
367
1,149
Drives: E92 335i MT
I agree with you on that.. I had a WD internal drive on my old pc that my bro still uses and not a problem with that. It's their external drives that suck lol especially the mybook
