03-22-2019, 07:02 PM | #1 |
17
Rep 164
OEM Brake Pad shortage?
Took my car to track a couple of times and wore through the brake pads. I tried to order online from discount shops and they called back and canceled my order because they could not source them. So I took to dealer, assuming they would have some in stock or at local warehouse. Nope. Car has been at shop for two weeks waiting for parts. Anyone else have this issue? Kind of annoying.
03-23-2019, 08:01 AM | #3 |
///M
6662
Rep 3,683
I used to track mine M3 and always had not one but two sets off pads and tires sitting in garage.
This is what happened if you wait last minute. If you are planning to track more often do the same, it saves you frustration.
Life is too short...enjoy your life
///M |
Aronis2277.00 |
03-26-2019, 01:48 PM | #4 | |
110
Rep 77
2018 Chalk F90 M5
2012 GTR Alpha X IG: @chalkf90m5 |
03-28-2019, 05:52 PM | #6 |
17
Rep 164
03-28-2019, 05:57 PM | #7 |
317
Rep 516
F90 isn’t scheduled for pads for 30k miles. Not many have that yet. 😈
I have my order in for a front set for another track weekend end of April. |
03-28-2019, 06:01 PM | #8 |
17
Rep 164
03-28-2019, 08:42 PM | #10 |
4086
Rep 5,237
I have an OEM set of pads with 2k miles sitting in my garage; if anyone is interested PM me.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
04-14-2019, 07:45 AM | #12 |
1839
Rep 1,328
I echo this. I'm on my second set of front pads, and installed my third set of rears at the track when I wore them down to to backing plates.
I have now turned off DSC, which was causing the premature rear wear (this chassis is pretty controllable), but the fronts have worn quite well. First set of front pads lasted me six track days and one set of tires. But I ordered a set of fronts from the dealer and they are on national back order. Come on pagid, get to making those pads. And make a set of decent track pads for this beast while you're at it. Shawn |
05-03-2019, 08:40 PM | #14 |
349
Rep 1,246
wow
