      04-27-2018, 07:37 PM   #1
Breno_Piece
Euro Noob
Australia
52
REP
16
Drives: F30 328i M-Sport
Nissan Variable Compression Turbo Engine!
(can't embed, soz)
If this works well it could be a game changer.
What do you think?
Kyngofpop641.00
      04-28-2018, 10:36 AM   #2
Never_Enough
2,242
REP
2,476
Drives: Satan's Chariot 2.0
Nissan...zzzzzzzzzzz
      04-28-2018, 02:20 PM   #3
Red Bread
4,459
REP
9,160
Drives: Smog machines
Originally Posted by Incontinentia Buttocks View Post
Originally Posted by Breno_Piece View Post
(can't embed, soz)
What do you think?
Yep.
Saab did this thirty years ago.
We've been over this. No they didn't. This is like claiming that Mercedes built Wankel cars because of one show car.
It was also less than twenty years ago:
https://en.m.wikipedia.org/wiki/Saab...ression_engine
      04-28-2018, 03:53 PM   #4
Shredicus
Shredicus's Avatar
538
REP
1,122
Drives: E92 M3
Now lets combine this with Toyota's Dynamic Force innovation, Mazda's HCCI tech, BMW VALVETRONIC and hybridize it for maximum reliability and ease of maintenance
      04-28-2018, 03:55 PM   #5
Mr Carrots
770
REP
628
Drives: Bmw
Can't wait to see what this beast does @ 200 WHP mated to a CVT and econobox chassis!
      04-28-2018, 05:22 PM   #6
Shredicus
Shredicus's Avatar
538
REP
1,122
Drives: E92 M3
My mistake. Nearly twenty years ago, not thirty. Saabs VC engine won awards in 2000 and was a year from production. It was scrapped when GM took over. Looks like Nissan has merely plagiarized Saabs design. As the old saying goes, "there's nothing new under the sun".
The mode of operation for altering compression seems quite different though.
SAAB:
To alter the combustion chamber volume, the SVC 'lowers' the cylinder head closer to the crankshaft. It does this by replacing the typical one-part engine block with a two-part block, with the crankshaft in the lower block and the cylinders in the upper portion. The two blocks are hinged together at one side. By pivoting the upper block around the hinge point, the volume of the combustion chamber can be modified. In practice, the SVC adjusts the upper block through a small range of motion, using a hydraulic actuator
Nissan:
The pistons in the VC-T engine are connected to rods that are attached to one end of an elliptic device Nissan calls a multilink. The multilink is mounted on the crankshaft where the connecting rods normally go. The other end of the multilink has a short rod that is connected to a shaft. An electrically controlled actuator twists the shaft, causing the multilink to tilt up or down slightly. When the end of the multilink closest to the piston is tilted up, the piston travels to the top of the cylinder. That is high-compression mode, 14.1.
http://www.autozine.org/technical_sc...ssion.html#SVC
And Porsche has an entirely different concept as well:
Porsche and Hilite conceived a way to adjust the apparent length of the connecting rods, the metal arms that connect to the crankshaft and drive the pistons up and down. A solenoid allows small oil-pressure-driven rods and an eccentric adjuster to raise or lower the bearing supporting the piston. The patent diagram appears to show a high and low position currently, not a variable height.
The car starts off with the piston in the high position. When the turbo begins injecting pressurized air, the piston drops to the low position. That reduces the compression ratio momentarily, allowing for more turbocharger boost and more power. The Porsche-Hilite design appears to be comparatively simple, at least compared to other variable-compression-ratio efforts that date back a century.
LobB4895.50
Biginboca3795.50
      04-28-2018, 09:41 PM   #7
Breno_Piece
Euro Noob
Australia
52
REP
16
Ideally it'd be in a new S-Chassis (or similar) and with larger displacement. would be nice to see Nissan make decent sports cars again.
      04-28-2018, 10:53 PM   #8
bmwchue
240
REP
812
Drives: 2013 bmw 328i
They do it's called a gtr
LobB4895.50
Biginboca3795.50
      04-28-2018, 11:11 PM   #9
Questofthetune
Questofthetune's Avatar
449
REP
775
Drives: 13 GT50014 AW M235i(sold)
2014 BMW 235i  [0.00]
Lmao I said the same thing out loud - the GTR is a monster
bmwchue240.00
      04-29-2018, 04:55 PM   #10
rjd_F30
rjd_F30's Avatar
2,018
REP
3,682
Drives: 2013 335i 6MT
I'm in full support of anything that can save the internal combustion engine from extinction by way of EV's. Papa bless you Nissan, this is a big step in the right direction.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
