      02-02-2018, 07:50 PM   #1
dzvero
548
1,514
Drives: 2015 M$4 F82
Question Do I need double/single top plate for bearing wall or just beam?
Hi, Im removing part of bearing wall , see the pic attached. Question is do I need the double top plate or I can just use bigger beam ? I will use LVL either two 2x4 top plate regular KD + two sandwiched LVL 2x8 or I can use only beam of two LVL 2x10's ? I have to remove or replace the existing top plate - termites had a lunch . Thanks in advance.
      02-02-2018, 07:58 PM   #2
jgrote
16
Drives: 2011 35i
2011 BMW X5  [0.00]
Your codes may vary, but in FL your would still be required to have a double top plate.
      02-02-2018, 08:01 PM   #3
dzvero
548
1,514
In Cali
