F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > F30/F32/F33 Classifieds (For Sale / Trade / Wanted) > Members Classifieds > Misc. Car Items > Bentley Manual for BMW 3 Series
Studio RSR
      09-30-2017, 02:16 PM   #1
Class5Kayaker
Class5Kayaker's Avatar
52
98
Drives: 2016 BMW F15, 2014 Porsche 991
BIMMERPOST / Classifieds
Asking Price:
Sold
Item Interest
ISBN-13: 978-0837617527
This is a "must-have" for any shade-tree mechanic out there. The only reason I am selling it is I recently sold my F30 and upgraded to a Porsche 991. Book is in great condition. No tears, etc. Has a couple of very slight smudges on a few pages from when I used the book during maintenance and repairs.
I am listing the book on Amazon as well, so please go there to purchase it if you're interested. It is the cheapest one listed and my seller name is the same as my name here on BimmerPost.
Link below:
https://www.amazon.com/gp/offer-list...condition=used
Official book description is as follows:
The BMW 3 Series (F30, F31, F34) Service Manual: 2012-2015 contains in-depth maintenance, service and repair information for the BMW 3 Series from 2012 to 2015. The aim throughout has been simplicity and clarity, with practical explanations, step-by-step procedures and accurate specifications. Whether you're a professional or a do-it-yourself BMW owner, this manual helps you understand, care for and repair your 3 Series.
The do-it-yourself BMW owner will find this manual indispensable as a source of detailed maintenance and repair information. Even if you have no intention of working on your vehicle, you will find that reading and owning this manual makes it possible to discuss repairs more intelligently with a professional technician.
Features:
•Maintenance procedures from changing the cabin microfilter to replacing and registering a new battery. This manual tells you what to do and how and when to do it.
•Front-to-rear fluid and lubricant service, including xDrive transfer case fluid and ATF.
•Cylinder head cover gasket and crankshaft seal replacement.
•Cooling system, thermostat and radiator service.
•Gasoline fuel and ignition system diagrams and explanations for turbo-valvetronic-direct injection (TVDI) engines.
•Diesel fuel injection system diagrams and explanations for turbo-direct injection (TDI) engine management systems.
•Service and repair information on BMW EfficientDynamics technology, such as Valvetronic, xDrive, TwinPower turbo, and DSC (dynamic stability control).
•Twin scroll (gasoline) and variable vane (diesel) turbocharger removal and installation.
•Step-by-step variable camshaft timing (VANOS) service.
•Suspension repairs, including wheel bearing replacement.
•Brakes, steering and ABS troubleshooting and repair.
•Heating and air-conditioning repair, including A/C component replacement.
•Body and hood repairs and adjustments.
•Electrical system service, with an easy-to-use illustrated component locator section.
•Comprehensive wiring schematics, including fuses and grounds.
•BMW OBD II diagnostic trouble codes, SAE-defined OBD II P-codes, as well as basic scan tool operation.
•BMW factory tolerances, wear limits, adjustments and tightening torques.
Engines (Gasoline):
•N20 engine: 320i, 328i, including xDrive
•N26 (SULEV) engine: 328i including xDrive
•N55 engine: 335i, including xDrive
Engines (Diesel):
•N47 engine: 328d, including xDrive
Manual transmissions (remove, install, external service):
•GS6-17BG (4-cylinder models)
•GS6-45BZ (6-cylinder models, RWD)
•GS6X-45BZ (6-cylinder models, with xDrive)
Automatic transmissions (remove, install, external service):
•ZF GA8HP45Z
2016 BMW F15 xDrive 35i - Imperial Blue Metallic
2014 Porsche 991- Sapphire Blue Metallic
Tags
bentley, repair manual
f30post
