05-24-2017, 02:49 PM | #1 |
46
Rep 50
Pass side A pillar rattle?
Anyone else have a rattle emanating out of where the pass a pillar meets the dash? Shows itself inconsistently on back roads. Emptied the glovebox contents just to be sure and its the same. Not speed sensitive.
05-25-2017, 12:50 AM | #2 |
101
Rep 246
I have rattle from the triangular piece in the door, which is vey close to where your rattle is? Mines not all the time though, just on rough surfaces. As i have hi-fi sound only and not HK sound. I will be installing the HK speakers at some point, so will be reseating everything then.
MJ |
05-26-2017, 06:06 AM | #4 |
538
Rep 624
I have it too. Was on the list of things when I left it in for service. They did not manage to find what it is or fix it.
05-26-2017, 01:18 PM | #5 |
Always +10MPH
1005
Rep 626
Yes. The interior rattles. A lot. The stiffer suspension doesn't help.
Can try to ask the dealer to try to find and fix it. But it doesn't always gets fixed. Do I care? Not really. Think about this, the M4 GTS rattles like crazy too. |
rainfall162.50 jessetaylor1172.00 |
05-27-2017, 09:57 AM | #6 |
816
Rep 3,957
Every BMW i have had rattles inside or just makes noises. The window noises around the edges are fricking annoying.
2021 M2 Comp Sunset Orange |Black with orange Stitching Dakota Leather|Executive Pkg|DCT
03-17-2020, 06:21 PM | #7 |
421
Rep 298
I have had it since new (2017). Just got it addressed; we'll see when I pick up the car today if it is fixed or not. Here is what the repair order says:
"customer states there is an intermittent rattle in the cabin when going over rough pavement. It is coming from the right side near the A-pillar customer going on test drive with shop fore man cc" Cause: Correction: TEST DROVE VEHICLE AND VERIFIED COMPLAINT. FOUND NOISE COMING FROM DASH AREA ON PASSENGER SIDE. REMOVED A-PILLAR AND PASSENGER AIR VENT. TEST DROVE VEHICLE AND FOUND NOISE STILL PRESENT. REMOVED CENTER VENTS AND TEST DROVE VEHICLE. FOUND NOISE STILL PRESENT. REMOVED DASH AND FOUND A BOLT THAT HOLDS SKELETON FRAME TO VEHICLE LOSE. TIGHTENED BOLT AND REINSTALLED DASH. TEST DROVE VEHICLE AND FOUND NOISE NO LONGER PRESENT. REINSTALLED ALL OTHER PARTS. TEST DROVE VEHICLE ONE LAST TIME AND FOUND NOISE NO LONGER PRESENT. |
03-17-2020, 08:57 PM | #8 |
421
Rep 298
Part two: picked up the car this afternoon, got five minutes into the drive home before the exact same rattle started again. Took it back to the dealership again. It has already been there for 8 days.
03-17-2020, 10:59 PM | #9 | |
10944
Rep 4,553
Drives: 2015 328d xDrive
bartginger421.00 NYC Bimmer259.50 |
03-18-2020, 12:51 PM | #10 | |
421
Rep 298
AndrewC198910944.00 |
03-22-2020, 07:59 AM | #11 | |
Gangnam Member
229
Rep 136
Current: 2015 BMW X5d | 2017 BMW M2 | 1976 BMW 90S
Gone but not forgotten: 2016 BMW 228i, 2014 BMW 228i, 2008 BMW 535xiT, 1998 BMW 328iC, 1991 BMW 325iC |
bartginger421.00 |
03-28-2020, 10:27 PM | #13 |
62
Rep 176
04-18-2020, 03:33 PM | #14 |
421
Rep 298
Part Three: another two weeks went by. I was told by the dealer the rattle has been fixed and was determined to be a loose screw in the "aftermarket" (actually, it's a BMW carbon accessory) passenger mirror cover. Does appear to have resolved the issue though, and I am grateful they did not have to resort to removing the windshield under the TSB I mentioned above.
