03-29-2017, 06:09 PM | #1 |
2545
Rep 3,968
Alignment
Car goes in Friday for the 1,200 mile service. It has a "slight" pull to the right. I'm trying to decide if I should even bring it up. Over the years I've had so so experiences with alignments (sometimes making a minor thing worse). What would you do? I notice it primarily over 40mph.
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual 2023 X3 M40i - loaded sans Park Assist |
03-29-2017, 06:19 PM | #2 | |
1622
Rep 3,402
03-29-2017, 06:39 PM | #3 |
this is the way
18429
Rep 8,582
Check your tire pressure. If that's good all around I'd have them check why it's pulling being it's so new and assuming you haven't gone over any pot holes etc. I've had more alignment issues with indy shops than the actual dealership, that's been my experience at least.
03-29-2017, 07:56 PM | #4 |
2545
Rep 3,968
I noticed the pull when I picked up the car and still notice it with the snows on. I'm told by the dealer that it can't be "checked" - has to be loosened up and put on the rack. True?
03-30-2017, 12:25 AM | #5 |
106
Rep 59
Maybe it has to do with the break-in process, as I remember, you where adamant to do the standard break-in process and rather suggested following this: http://mototuneusa.com/break_in_secrets.htm as you mentioned in some other thread (http://f87.bimmerpost.com/forums/sho....php?t=1343178).
I followed the standard break-in process and have never had some kind of pull either left or right. I'd ask them to check the differential. |
03-30-2017, 12:29 AM | #6 | |
2545
Rep 3,968
Ps, let's put our cars on the dyno? Put your money where your mouth is.
03-30-2017, 12:37 AM | #7 |
106
Rep 59
You know the diff needs to be broken in? I'm not talking about power, I'm talking about the diff and as you know it uses a different oil before 2000km/1200miles. It could be a reason, look into it. No need to be passive-aggressive.
03-30-2017, 12:48 AM | #8 | |
2545
Rep 3,968
You might have asked if happens under power or when coasting or if it started when I left the dealer or later on. But to tie this to how thy car is broken in, that's just outstanding. Made my night.
03-30-2017, 12:56 AM | #9 | |
106
Rep 59
doug_9992544.50 |
03-30-2017, 02:08 AM | #10 |
Moderator
29803
Rep 13,144
Also mind the road where you notice this phenomenon. Some roads are deliberately constructed with a very subtle inclination in order to better canalize rain. This may cause the impression that a perfectly aligned car is very slightly out of spec (while it's merely the road). No joke.
///M is art ↔ Artemis
Corinne1171.00 MerlinPurple688.50 |
03-31-2017, 09:49 PM | #11 | |
95
Rep 176
Also, not sure how true it is but I've been told that manufacturers try to counter this by purposely "misaligning" which, if you're on a perfectly flat road will itself cause some pull. |
04-01-2017, 01:18 AM | #12 |
2545
Rep 3,968
FYI
Appears I'm not alone http://www.bimmerfest.com/forums/sho...d.php?t=962374 Dealer said today the only way to "check it" was to align it. To me, not worth the risk, so I passed on it. As noted in the above thread, almost more of a drift than a pull). Left lane (with angle to left) car is straight. Middle (crown of road), is drift to right, and right is almost a pull.
04-04-2017, 03:24 PM | #13 |
2052
Rep 3,714
I got a courtesy/free one time alignment at my 1200 mile service since my wheel was crooked. If your dealer is decent they can get this pushed through for you.
If you think the wheel is crooked or the car is pulling/drifting you probably need an alignment. I don't know about you but if I buy a 50K+ sports car I'm not going to try and save $150 bucks and drive it around with a crooked alignment. Last edited by CosmosMpower; 04-05-2017 at 12:42 PM.. |
07-10-2017, 08:24 AM | #15 |
697
Rep 665
Hey guys my car has 1100km and the steering wheel has been slightly off center since delivery when it had 26km. I think the actual alignment is fine just the wheel is a bit off center. I'm very sensitive to these things and it really annoys me. Should I have them take a look or do I risk a worse problem or damaged or scratched steering wheel?
07-10-2017, 03:17 PM | #16 |
230
Rep 254
If I were you I'd take it to the dealership. If you're really worried about the steering wheel getting scratched, unlike a scratch in paint, they can easily replace the steering wheel. Don't have to worry about color matching etc
