03-13-2017, 02:04 PM | #1 |
Driver
465
Rep 1,002
Lumpy idle anyone?
B58 is my first ever 6 pot BMW and although only picked up 5 weeks ago my first impressions are very positive! The only slight disappointment is that idling when fully warm, i am really aware of the engine running as the car shudders slightly! Not excessively, but when I owned my e90 (148hp) & e92 (170hp) 4 pots, there were many occasions when I hit the start button to turn on the engine, only to find I'd just turned it off because it was already running... those engines were so smooth at idle that when waiting for someone to get in the car, I'd forget I'd already started up!!
Is this normal, maybe just because it is so much more powerful an engine? I've always understood that a six should run smoother than a four!? it is totally smooth on the move!! Last edited by nozydog; 03-13-2017 at 02:14 PM.. |
03-13-2017, 02:07 PM | #2 | |
220
Rep 579
03-13-2017, 02:46 PM | #3 |
514
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
I haven't noticed any shudder on my car since I got it. How warm does the weather need to be for you to notice?
It could be that the other cars you've had idle at a higher RPM so they seem smoother. Lower RPM can introduce slight harmonic vibration or shudder as you may call it.
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
03-13-2017, 02:47 PM | #4 | |
10
Rep 81
nozydog465.00 |
03-13-2017, 03:57 PM | #5 | |
Driver
465
Rep 1,002
03-13-2017, 04:40 PM | #7 | |
514
Rep 1,055
I understand your view but Germans hate idling so I bet they want to keep gas consumption as low as possible - just enough to keep it purring without wasting gas. 650 RPM idle is definitely low but it's normal for this engine My previous car had a 4 pot but it was a low revving NA engine (less than 7,000 RPM redline) but had the same amount of torque as it had hp (155hp/152ft-lb)... it would idle as low as 550 RPM sometimes lol
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch Last edited by DrifterX; 03-13-2017 at 04:46 PM.. |
03-13-2017, 05:53 PM | #8 | |
Driver
465
Rep 1,002
03-15-2017, 05:40 PM | #9 |
1665
Rep 4,921
The issue is it runs REALLY lean all the time. That "lumpy" idle is just a bi-product of the ECU trying to maintain idle at an AFR that an engine should never run at.
Perfectly normal. My 2008 GMC does the same. I don't remember my n54 having as much shutter though, but I believe it ran a bit richer than the B58 does. |
03-18-2017, 11:34 PM | #10 | |
252
Rep 674
03-19-2017, 10:12 AM | #11 | |
421
Rep 844
03-23-2017, 08:18 AM | #12 |
222
Rep 777
Unfortunately the lumpy idling is the only downfall of the B58 engines, It only happens when the car is cold so it shouldn't be that big of a worry. I hope they fix this issue with updates for the transmission hopefully.
Instagram: Bmw_Captivate
2020 Portimao Blue M340 X Drive and adaptive suspension. Mods: custom exhaust, VRSF Catted DP, Injen intake and Chargepipe. |
03-23-2017, 09:06 AM | #13 |
86
Rep 151
It's a high compression motor that runs lean. It will be more pronounced on cold start. Lumpy idle at that time is normal. Even at operating temps the idle will shake here and there because the car is trying to main a certain a/f ratio (much harder to do when ambient temps are low). If you have no codes/cel, don't lose sleeep over it.
04-03-2017, 06:02 PM | #14 |
11
Rep 49
Drives: BMW 340i xDrive
I notice really lumpy idle one cold starts. Would happen for 10-15 seconds during the same interval on start up. Shakes the car side to side. Read up its normal but seems odd...
04-06-2017, 06:48 AM | #17 |
126
Rep 484
Drives: 440 xi MPPSK JB4
Location: Socialist People's State of NY - Long Island, NY
Funny... my new 440 is smooth as butter even when cold... shock how smooth it is... has mppsk though
How you all break in the motor? I drive like I stole it right out the dealer... |
04-06-2017, 07:33 AM | #18 |
220
Rep 579
I planned on doing a 1500 mile break in but the dealer told me that it is not needed and that they "come broken in from the factory".
Current: 2021 M340i
Previous: 2020 X3M Comp BM3 E30 & 2016 340i 8AT DME Stage 2 | FBO/Catless Meisterschaft Catback | Ohlins R&T |
04-06-2017, 09:55 AM | #19 | |
3003
Rep 6,063
04-07-2017, 02:20 PM | #20 |
74
Rep 126
Yessir
2017 340i xDrive
MPPSK More to come |
04-21-2017, 02:43 PM | #22 |
139
Rep 638
I never had a rough idle, but I did notice a weird sensation. When I'm cruising around town at 50-60mph and press the throttle just enough to sit at 1500-2000 and not have the car downshift, I notice an obvious hesitation and the rpms fluctuate. Anyone notice this? It's very subtle.
Just bought it last week, 250 miles on the clock. |
