F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > B58 340i/440i Downpipe Install
GetBMWParts
      01-29-2017, 11:22 AM   #1
KD07
55
182
Drives: 340i
Just wanted to get some input from those that have installed the downpipe themselves. Any advice or things I should know about before trying to do it myself at home without a lift? I would be going catless, so anything I need to do or buy extra for the O2 sensor? I have a jb4 to clear the code so not worried about that. Probably will be going with the VRSF 4.5" simply because it's the lowest priced one.
Thanks, anything you can tell me is appreciated.
2016 340i - 6MT // M-Sport // JB4 // BMS Intake // AFE catback
      01-29-2017, 06:46 PM   #2
Mike@N54Tuning.com
BimmerPost Supporting Vendor
4927
116,037
Drives: 2007 335i, 2015 M3
Without a lift is not fun
Mike
      01-29-2017, 07:10 PM   #3
SingleturboVert
49
202
Drives: E93 335i
Mike
After doing my N54 DPs on jack stands back when I had my E90, the back of my head hurt like crazy from laying on the concrete so long
      01-29-2017, 09:44 PM   #4
KD07
55
182
Drives: 340i
Mike
I have heard the N54 was horrible, and the N55 wasn't much better. I've also heard that the B58 was the easiest people have ever experienced. Anything I should plan on doing in terms of an extra bung or anything for the O2 since it'll be catless?
      01-30-2017, 10:13 AM   #5
335xiRT1
47
693
Drives: 2007 335i
It's deff. Easier than n55 and n55
I just did it last week.
From under the hood I was able to unplug O2 sensor plug and remove the 2 bolts holding the downpipe in place and also loosen the v-band clamp on the turbo.
Then just go underneath loosen clamp that holds downpipe onto exhaust, and take off bolt that holds exhaust up. It's right behind the downpipe/exhaust connection.
And finagle the downpipe out. Took me little over a hour.
KD0754.50
sly1types431.50
      01-30-2017, 01:57 PM   #6
shawntech
The Wolf
shawntech's Avatar
256
992
Drives: stuff
  [0.00]
2019 BMW M850i conv ...  [0.00]
can it be done with the front wheels on ramps? i'm OCD about marring things up and I don't have a lift at home.
-2019 BMW m850i convertible
-2021 Dodge Charger Hellcat Redeye Widebody
      01-30-2017, 05:53 PM   #7
Mike@N54Tuning.com
4927
116,037
It can be done..
Mike
      01-30-2017, 06:38 PM   #8
mike@x-ph.com
mike@x-ph.com's Avatar
24454
191,382
Drives: 07-335/12-328/18-M4/21-M4CP
It can be done but a lift will make your life easier
Here is a review we got today
Mike was very helpful getting my order in. The JB4 and BMS intake take a whole 5-10 minutes to install. Intake makes a noticeable whistle by itself, but the JB4 unleashes the beast with the b58. Catless downpipe was difficult to install on the ground. Ended up taking it to a lift to finish the install. Had to remove the center brace of the car to drop the exhaust enough to slide it onto the downpipe. Pro tip for install: remove the air box and loosen the vband and remove the sensors and bolts from up top. Much easier to remove the nuts and bolts from above.
https://x-ph.com/sale/
Phone number 702-494-9435
KD0754.50
      02-01-2017, 03:49 PM   #9
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
3442
79,211
Drives: C6 Z06, 09 335i, 10 335xi
Yes it can be done on ramps.
KD0754.50
      02-02-2017, 10:35 AM   #10
SingleturboVert
49
202
Drives: E93 335i
Well for your sake I hope it is better!
KD0754.50
      02-03-2017, 09:26 AM   #11
Mike@N54Tuning.com
4927
116,037
LOL.. Well it can't be worse then the N54 / N54 XI installs..
Mike
      02-03-2017, 01:37 PM   #12
jpsimon
Team Zissou
jpsimon's Avatar
3084
10,198
Drives: 2022 AWD M3 Comp - SMB
Anything is better than an AWD n54. We ended up sawzalling one of the downpipes in half to get it out because we didn't feel like dropping the whole subframe to make room.
b58 should be ezpz compared to that
MaximusJ305.00
      02-03-2017, 05:34 PM   #13
PushingRedline
16
97
Drives: 2017 340xi M-Sport
So I am gathering b58 is easier then n55? I remember trying to get the OEM dp out on my n55 335xi and we gave up. Had to pay a shop to do it. Hoping when the time comes we can do the b58 ourselves.
      02-03-2017, 06:34 PM   #14
KD07
55
182
Drives: 340i
I have yet to hear of a bad experience with the b58 DP install. Looking forward to hopefully purchasing and installing soon.
      02-05-2017, 01:22 PM   #15
BASELINE
136
401
Drives: A few...
If your car is a XDrive and you're installing an ER 4.5 DP, get some washers for the subframe ready or it won't clear properly.
KD0754.50
      02-05-2017, 02:44 PM   #16
335xiRT1
47
693
Drives: 2007 335i
VRSF 4.5" clears no problem
KD0754.50
      02-05-2017, 11:01 PM   #17
KD07
55
182
Drives: 340i
I don't have xdrive, mines RWD. So not worried about the problems others have mentioned on these forums. Thank you for the heads up though.
      02-05-2017, 11:22 PM   #18
HitmanHearns
98
315
Drives: 14' Infiniti Q50 / 16' Audi A4
I did the downpipe in a total of 1 hour.
I rolled the car onto ramps. Took the stock one off and put in the ER downpipe. I never took the exhaust off either. Still stunned how easy of a install it was....
Appreciate 5
      02-06-2017, 02:10 PM   #19
Mike@N54Tuning.com
4927
116,037
Thats pretty good time without a lift.. Impressive!
Mike
      02-06-2017, 02:32 PM   #20
mike@x-ph.com
24454
191,382
Nice!
      02-06-2017, 06:40 PM   #21
E90ROXS
E90ROXS's Avatar
225
677
Drives: E90
and I paid $280 for it. FML
      02-07-2017, 09:11 AM   #22
Mike@N54Tuning.com
4927
116,037
These are now included with the kit. ER has two part number for XI and RWD
Mike
f30post
