11-26-2016, 08:11 PM | #1 |
Rep 28
what modification next?
Hi guys. So my current exhaust modification is an MPE (backbox only)
Personally i didnt notice a big difference from standard. Ive seen all these 140i have loud burble and pops with just MPE. So I want something that will give me a deeper and throatier sound and also the burbles when i rev. I dont want to have to remap it because of what i want. Whats are the options for me? |
11-26-2016, 08:12 PM | #2 |
1276
Rep 2,963
Downpipe or res delete
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
11-27-2016, 07:41 PM | #4 |
1276
Rep 2,963
Yep
11-28-2016, 06:58 AM | #5 |
Rep 28
Does any one know where can I find midpipes? Don't want to cut into the OEM pipe.
I know local custom specialists but seeing if there are any places that sell them already ? |
11-28-2016, 09:52 AM | #6 |
37
Rep 90
http://www.awe-tuning.com/awe-bmw-f3...i-440i-exhaust
(performance midpipe) https://www.remus.eu/front-silencer-20830.html http://www.dinancars.com/product/d66...ries&mid=1237/ There may be others, but I'm not aware. |
11-28-2016, 12:43 PM | #8 | |
136
Rep 401
I'd go catless DP. Add a bit of sound with the functionality of more power and better spool. Then if you want more noise you could always start removing the resonators....one at a time to make sure you don't overshoot your desired Db level. |
11-28-2016, 07:26 PM | #9 | |
BimmerPost Supporting Vendor
24439
Rep 191,342
Check the vendor section for Cyber Monday deals
11-30-2016, 10:05 AM | #12 |
Rep 8
2016 340i + JB4
I just got an Evolution Racewerks Downpipe, and I'm curious; won't I get a catalytic efficiency fault from the post cat sensor after install and driving? |
11-30-2016, 01:10 PM | #13 | |
24439
Rep 191,342
Post pics of the downpipe
11-30-2016, 05:43 PM | #14 |
Rep 8
Thanks,Will do Mike. About an hour ago I put 3.5 Gallons of E-85 in the tank, and filled the rest up with 91. Put the JB4 into Map 2 for the first time as I understood you could put it in Map 2 with E-85 for higher turbo boost. Right after leaving the gas station I got the drivetrain malfunction warning, and the acceleration was super sluggish... Turned car off, fired it back up, no more warning, so I put it back in Map 1 and it drove just fine. Can anyone explain why the 340i didn't seem to like Map 2?
11-30-2016, 05:51 PM | #15 | |
24439
Rep 191,342
11-30-2016, 06:18 PM | #17 |
24439
Rep 191,342
Per terry
Hey guys, Been plugging away on the B58 E85 tuning and have some information to share. First the good news. With sufficient octane the turbo hardware has plenty of room for more power. I turned boost up and was able to get around 440whp out of the car 100% stock on E40 with a much too lean AFR. I suspect the factory turbo with just a high flow intake added will ultimately support around 460-475whp. Now the bad news. It looks as if BMW has placed an IPW fuel limiter in to the DME firmware. This could be an attempt to hinder flash tuners or could simply be to avoid some sort of an injector or fuel system flow limit we don't know about yet. On previous models we've altered the DME's fuel pressure signal as a back door to to raise IPW. On this model when altering the fuel pressure the DME responds by lowering it's load target proportionally to keep IPW consistent. We can work around it fairly easily with a CANbus JB4 by dynamically altering the load back to the DME to be within its new lower range and add dutycycle to bring boost up. While we get the boost curve we want the IPW is fixed so AFR leans out. What this means is that pump gas JB4 tuning is no problem. Race gas only tuning may get a bit sketchy at higher power levels. Maybe around 400whp. And E85 tuning is for the most part a no-go at least for now. We're likely going to have to turn to something external like meth or TBI to further extend the fueling range. Work continues... The logs have been purposefully not posted as I've noticed some would-be competitors IP addresses reading these B58 JB4 threads.
nzivkovic500.00 |
12-07-2016, 01:32 PM | #19 |
107
Rep 498
If you are referring to the fueling issue copied from Terry above. Gapping the plugs won't do anything to help fueling and injector pulse width.
12-07-2016, 02:18 PM | #20 |
4927
Rep 116,006
