03-30-2008, 11:24 PM | #1 |
QuickShifter
145
Rep 1,499
Python Programming
anyone here knows how to do python?
I'm trying to do this simple fuction input: num1 + num = results but i want the output be in pictures, so i decided to split num1 and num2 into digits by itself, so that i can apply the picture files to represent each number. now the problem is, after i split them into single digits, i can't get rid of the zero on the left side. ex. 01 + 01 = 2 ( i only split num1 and num2, so the results won't show 02) and, do i need to split results into single digits too? I believe doing that to the results would make the situation alot more messy.... help is appreciated thanks, |
03-31-2008, 12:42 AM | #2 |
183
Rep 266
Drives: 2019 M550i xDrive
Can you post some of your code so I can see what you mean? Are you trying to split the number using string parsing? How do you want to represent the output in pictures?
M550i xDrive
Mediterranean Blue with Ivory White Nappa, Gray Poplar, Driving Assistance Plus, Premium, Exec, Parking Assistance, Heated Steering, Front+Rear Heated Seats, 20" Individual V-Spoke wheels 759i, 19" Style 786M winter wheels, Euro Amber Rear Turn Signals 335i Coupe - Retired |
03-31-2008, 12:46 AM | #3 | |
Member
Rep 47
$ python Python 2.4.3 (#1, Jul 4 2006, 23:58:18) [GCC 4.0.2 20050901 (prerelease) (SUSE Linux)] on linux2 Type "help", "copyright", "credits" or "license" for more information. >>> "02" + "02" '0202' >>> 2 + 2 4 >>> "02" + 2 Traceback (most recent call last): File "<stdin>", line 1, in ? TypeError: cannot concatenate 'str' and 'int' objects >>> So, you may need to convert things to and from strings and integers. To go from string -> int use the builtin int() function, and to go from int to string you can use something like "%s" % 2 (or just put the integer or var in backticks also works).
e90 335xi / 6MT / titanium silver / black leather / premium / cold weather / sport / iPod
03-31-2008, 01:01 AM | #4 |
QuickShifter
145
Rep 1,499
i'm very noob with python, so my codes might look weird
import cgi form = cgi.FieldStorage() zero = open ( "0.jpg" ) one = open ( "1.jpg" ) two = open ( "2.jpg" ) three = open ( "3.jpg" ) four = open ( "4.jpg" ) five = open ( "5.jpg" ) six = open ( "6.jpg" ) seven = open ( "7.jpg" ) eight = open ( "8.jpg" ) nine = open ( "9.jpg" ) num1 = int( form["num1"].value ) num2 = int( form["num2"].value ) op = form["op"].value first_digit = num1 / 10 second_digit = num1 - (10*first_digit) secondfirst_digit = num2 / 10 secondsecond_digit = num2 - (10*secondfirst_digit) print """Content-type: text/html <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd"> <html><head> <title>Assignment 2</title> </head><body> """ if num1 > 99 or num1 < 0 or num2 > 99 or num2 < 0 : print "Error: Wrong number." else: if op == "+" : print "%s%s + %s%s = %s" % (first_digit, second_digit, secondfirst_digit, secondsecond_digit, num1 + num2) if op == "-" : print "%s%s - %s%s = %s" % (first_digit, second_digit, secondfirst_digit, secondsecond_digit, num1 - num2) if op == "*" : print "%s%s * %s%s = %s" % (first_digit, second_digit, secondfirst_digit, secondsecond_digit, num1 * num2) if op == "/" and num2 != 0 : print "%s%s / %s%s = %s" % (first_digit, second_digit, secondfirst_digit, secondsecond_digit, num1 / num2) if op == "/" and num2 == 0: print "Error: Undefined." if op == "+" and first_digit == 0 : num1 = second_digit if op == "+" and secondsecond_digit == 0 : num2 = secondsecond_digit if op == "-" and first_digit == 0 : num1 = second_digit if op == "-" and secondsecond_digit == 0 : num2 = secondsecond_digit if op == "*" and first_digit == 0 : num1 = second_digit if op == "*" and secondsecond_digit == 0 : num2 = secondsecond_digit if op == "/" and first_digit == 0 : num1 = second_digit if op == "/" and secondsecond_digit == 0 : num2 = secondsecond_digit print "</body></html>" dont' mind the indentations, copy and paste doesn't copy indents too i guess |
03-31-2008, 01:08 AM | #5 |
QuickShifter
145
Rep 1,499
03-31-2008, 04:27 PM | #6 |
Gangsta status
79
Rep 973
Drives: 2002 E39 M5, heavily modded
python man or man I haven't used that for awhillleee. Only used python for PERL
-TheLegacy
JDM-EDM-TT-V8-GANGSTA ALL THE WAY *Modded* "Ready for the Apocalypse" |
04-02-2008, 01:14 AM | #8 |
Member
Rep 47
Ok, think I understand what you're trying to do. You probably don't want to open the actual files, but instead just put an html image tage, like
<img src="1.jpg"> ...in the output. Your logic with the division by 10 to get the first digit and then subtracting that off will work, but only if the data coming back from the cgi form (like form["num1"].value) is in numeric form...I'd expect it to actually be string data that comes back. If that's the case, then it's much easier to just do: first_digit = form["num1"].value[0] second_digit= form["num1"].value[1] ...since strings can be treated like lists. Then you could just do print '<img src="%s.jpg">' % first_digit print '<img src="%s.jpg">' % second_digit ...to output the first number's images (and do the second number similarly). Does this make any sense? : )
04-02-2008, 01:31 AM | #9 | |
QuickShifter
145
Rep 1,499
btw, i have a HTM file linked to this python, so do i still need to do <> for hte img src? one more problem, i want to get rid of the zero on the first_digit ...'cause the equation comes out like 01+01 = 2, and i want to make it to 1 + 1 = 2 |
04-02-2008, 02:49 PM | #10 |
Member
Rep 47
Assuming again that the form data comes across as a string (I still haven't checked this but think it's true) you can just
do a regex to strip off the leading 0, like: >>> import re >>> >>> teststr = '02' >>> teststr = re.sub(r'^0', '', teststr) >>> print teststr 2 I'm not sure offhand if you need the <>'s or not in your system. Try it both ways and see which works.
