03-17-2008, 10:25 PM | #1 |
boku no namae ha...
346
Rep 11,023
Drives: 2006 BS 330i
Location: S. Bay Area, CA + Newark, NJ + ChiCity + True Blue
Pontiac G8
http://www.pontiac.com/g8/index.jsp?cmp=08olag8
does anybody like this car? haha i'm just curious. i think it looks allright....
looking for a PreLCI Black Sapphire e90 front bumper without license plate holes
"Akimbo shotguns. Broken wrists anyone? And don't give me that 'it's just a game' bull****. Where the **** are my akimbo interventions then?! One scope on each eye mother****er!!" |
03-18-2008, 12:40 AM | #6 |
16
Rep 135
03-18-2008, 06:14 AM | #9 | |
110
Rep 3,120
03-18-2008, 07:50 AM | #10 | |
D to the X to the B!
360
Rep 2,106
Anyway, at least you guys have the 6 speed slushbox. Over here in Dubai, they sell the Lumina SS aka Pontiac G8 with the old 4 speed auto
11 corvette C6
03-18-2008, 11:04 AM | #11 |
1246
Rep 12,446
The VXR8 (same car, Aussie version) looks worlds better.
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
03-18-2008, 11:44 AM | #12 |
boku no namae ha...
346
Rep 11,023
the aussie one has the corvette engine right? or so i read a while ago.
03-18-2008, 11:53 AM | #13 |
The Designer
Rep 233
I don't know about the G8. Performance is great but I don't see why everyone is in a big circle jerk over the design. It's ok but doesn't make me go "WOW". From the side view it's rather plain and the back is boring. The front probably looks the best.
03-18-2008, 11:57 AM | #14 |
1246
Rep 12,446
I think so...
03-18-2008, 12:02 PM | #15 |
1246
Rep 12,446
And here's some comparison pics to show you how much better the Aussie version looks (although the Pontiac isn't half bad either).
03-18-2008, 12:04 PM | #16 |
1246
Rep 12,446
Gotta love fender flares. The one's on the VXR8 look great in real life.
The G8 would look worlds better with a spoiler like the one the VXR8 has.
03-18-2008, 01:22 PM | #17 |
not afraid to call it like I see it
32
Rep 316
the word on the street is to wait for the LS3 version of this car. It will be called the G8 GXP.
"Engine performance The heart of the G8 GXP is the 6.2L LS3 small-block V-8, currently rated at 402 horsepower (300 kW)* and 402 lb.-ft. of torque (546 Nm)* pending final SAE certification. This engine is the newest member of GM's small-block V-8 family. It features a revised, larger-bore cylinder block, high-flow, L92-style cylinder heads; larger-diameter pistons; unique camshaft and camshaft timing; revised valvetrain with offset intake rocker arms; high-flow intake manifold; and high-flow fuel injectors. The LS3 engine has an aluminum cylinder block with cast-in-place iron cylinder liners. Larger bores help create a 376-cubic-inch displacement. The block casting also features revisions and machining in the bulkheads to enhance its strength and improve bay-to-bay breathing. New pistons were designed for high-rpm performance. New, high-flow cylinder heads aid engine breathing and are based on the large port and valve design found on the LS7 engine and other GM L76 engines. The larger-capacity, straighter intake port-design optimizes intake flow to the combustion chamber, an effect augmented by large valves, measuring 2.16 inches (55.0 mm) on the intake side and 1.59 inches (40.4 mm) on the exhaust side. Pending final testing, the G8 GXP is expected to deliver 0-to-60 mph performance of about 4.7 seconds, and a quarter-mile time of 13.0 seconds at 108 mph. Six on the floor A new six-speed Tremec TR6060 manual transmission is optional on the G8 GXP. This next-generation manual smoothly transfers the engine's power and torque to the rear wheels with a reduction in shift throw. The transmission features a host of refinements including premium gear synchronizers; stronger gears, housing, and bell housing; a single-piece counter shaft; and machined gear teeth. The standard Hydra-Matic six-speed 6L80 automatic transmission is technologically advanced and robust. It uses a clutch-to-clutch operation and an integrated 32-bit transmission controller to deliver smooth and precise shifts. The six-speed has a generous 6.04:1 overall ratio that enables a "steep" first-gear. The result is strong launch acceleration along with "tall" overdrive ratios that lower engine rpms for better fuel economy and reduced noise. A 3.27 final drive ratio comes with automatic-equipped GXPs, and a 3.70 gear is matched with the manual transmission. A limited-slip differential is standard. " |
03-18-2008, 02:32 PM | #18 | |
12
Rep 50
It's kind of like finding out your grandpa recently learned how to pop-lock |
03-18-2008, 03:15 PM | #19 | |
I am Gundam
199
Rep 1,211
03-18-2008, 03:47 PM | #20 | |
boku no namae ha...
346
Rep 11,023
i think i like the aussie front better but the g8's rear is pretty damn tasty
03-18-2008, 03:50 PM | #21 |
I am Gundam
199
Rep 1,211
The pics Loyalist posted is comparing the G8( VE Commodore) and the HSV Commodore which is a performance trim of the Commodore. What sucks is that the GXP G8 doesn't look more like the HSV.
