AWE TUNING BMW F2X / F3X N55 S-FLO CARBON INTAKE - Now @ www.n54tuning.com ON SALE!!! |
05-04-2016, 01:19 PM | #1 |
Joint Chiefs of Staff
4927
Rep 116,006
AWE TUNING BMW F3X / F2X 335I S-FLO CARBON INTAKE
Presenting the AWE Tuning BMW F30 335i S-FLO Carbon Intake: ORDER LINK http://www.n54tuning.com/awe-tuning-...on-intake.html 63.4% increase in air filter surface area Featuring the AWE Tuning ® S-FLO Filter Easy access design allows for filter inspection, removal, and replacement without removal of entire air box No extra couplers in system means smooth flow from filter to turbo inlet Fully-sealed carbon fiber box and filter combination Max gains of 16hp and 13ft-lbs of torque at the crank Perfect integration with OEM inlet ducting Retains stock mounting locations Plug and play MAF and breather locations UV stabilized resin and clear coat prevents yellowing from heat Included S-FLO Filter is durable and washable Featuring No Check Engine Light - Guaranteed Perfect Fitment - Guaranteed The carbon fiber air box The AWE Tuning BMW F30 335i S-FLO Carbon Intake is a fully enclosed carbon fiber air box made from high grade UV stabilized 2x2 twill carbon fiber to reduce yellowing from under hood heat. This air box mounts securely in the stock location and mates up to the factory air inlet pipes, perfectly. It boasts simple access for filter inspection and helps to deliver as much power as it does good looks. The AWE Tuning ® S-FLO Filter The included AWE Tuning ® S-FLO Filter is specifically designed to maximize airflow in the AWE Tuning ® S-FLO Carbon Intake. This increased flow unlocks impressive max gains of 16hp and 13ft-lbs of torque at the crank. The carbon fiber airbox and S-FLO Filter combination makes for an easily serviceable air filter without removing the airbox. The combo produces a more aggressive intake note than stock, with a distinctive turbo spool sound, all while keeping your car operating Check Engine Light free. What’s in the Box The AWE Tuning ® S-FLO Carbon Intake includes the carbon fiber airbox itself, the AWE Tuning ® S-FLO Filter, and all necessary mounting hardware. |
05-07-2016, 08:01 AM | #2 |
4927
Rep 116,006
05-09-2016, 07:37 PM | #3 |
4927
Rep 116,006
05-12-2016, 06:56 PM | #4 |
4927
Rep 116,006
05-14-2016, 03:42 PM | #5 |
4927
Rep 116,006
05-17-2016, 09:59 AM | #6 |
4927
Rep 116,006
05-19-2016, 05:08 PM | #7 |
4927
Rep 116,006
05-21-2016, 06:19 PM | #8 |
4927
Rep 116,006
05-23-2016, 08:32 PM | #9 |
4927
Rep 116,006
05-26-2016, 10:46 AM | #10 |
4927
Rep 116,006
05-29-2016, 05:09 PM | #11 |
4927
Rep 116,006
06-02-2016, 08:16 AM | #12 |
4927
Rep 116,006
06-04-2016, 03:51 PM | #13 |
4927
Rep 116,006
06-06-2016, 07:21 PM | #14 |
4927
Rep 116,006
06-09-2016, 08:20 PM | #15 |
4927
Rep 116,006
06-12-2016, 06:26 PM | #16 |
4927
Rep 116,006
06-15-2016, 01:44 PM | #17 |
4927
Rep 116,006
06-18-2016, 07:10 AM | #18 |
4927
Rep 116,006
06-20-2016, 06:44 PM | #19 |
4927
Rep 116,006
06-24-2016, 06:43 PM | #20 |
4927
Rep 116,006
06-27-2016, 04:29 PM | #21 |
4927
Rep 116,006
06-30-2016, 09:03 PM | #22 |
4927
Rep 116,006
