06-02-2016, 12:37 AM | #2 |
BimmerPost Supporting Vendor
3887
Rep 54,530
Drives: F80 M3
Same suspension and similar set-up so I want to take a shot in the dark and say yes. Are you aligning to OEM or performance street/track specs?
06-02-2016, 01:54 PM | #6 |
Dinosaur supervisor
3030
Rep 4,214
10-18-2016, 07:10 PM | #9 |
1421
Rep 2,560
Drives: Rapidly from A to B
Is there any adjustment for caster on the M2. I know there is no camber adjustment. Just wondering about caster. If not then what gets aligned besides toe on the front?
10-18-2016, 09:37 PM | #11 |
1421
Rep 2,560
Thanks. So if I were to install a Ground Control camber plate with prefixed settings or a TCKline camber plate with the same then there is no reason to get another alignment since caster and camber are all preset to one of 3 positions in each of them. Correct? Local shop is saying I need an alignment after install and I'm trying to understand why. I can understand with a fully adjustable camber plate but both of these only have preset settings so I don't understand the need.
10-18-2016, 11:36 PM | #12 |
4192
Rep 3,088
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [8.25] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
@metrickid can you repost the alignment sheet?
Or if anyone else knows the factory specs post them up please. Where are you guys getting alignment done? I installed a set of Eibach Pro Kit over the weekend and want to check its still close to OEM specs. Called around my area and some can't find the specs in their system, some responded its a new car which they don't have in their software yet. I called my dealer to make an appointment but its out in November 1st, are all dealers prepared to work on M cars or is it true some dealers are M certified?
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
10-19-2016, 09:53 AM | #13 | |
96
Rep 185
02-10-2017, 12:18 PM | #14 |
48
Rep 33
sorry to bring up an old thread. Car is pulling to the right so i need the oem alignment specs. Most alignment databases don't have the m2 specs
If anyone has them please send it to me or post here. Thanks |
02-13-2023, 09:36 PM | #18 |
New BMW owner
328
Rep 846
Prior the work.
2018 BMW M2 LCI BM3 Stage 2 + MPE + FTP charge pipe + MST V2 Inlet + TurboSmart DV + CSF FMIC + AA Hi-flow Downpipe + Turner Rear Shifter Bushing + Wiechers Strut Brace + Bilstein B16 PSS10 + Apex VS-5RS
02-13-2023, 11:34 PM | #19 |
86
Rep 75
Since this thread got bumped there is something I'd like to add:
When using a Hunter alignment system to align ALL modern BMWs there is a very commonly overlooked aspect of doing the job properly. If the shop is not/didn't measure the ride height of the car on the rack, they are doing "standard" (constructor) alignment. If you do the job right, and measure the ride heights like the machine tells you to, you'll get "adjustment spec" which is FAR more precise and is accurate based on the height the car is actually sitting at. If the technician skips the ride height part (which nearly everyone does) you'll generally get a "worse case" scenario for the rear and the machine will default to more toe in and more negative camber in the rear. This is why so many people have tire wear issues on modern BMWs, they take them to a shop that skips that step so they get "worse case" alignment. The best part is, you don't need to special tools to do BMW ride heights, just a measuring tape. Next alignment, ask the shop is they are measuring ride heights, if they don't know what you're talking about, may be a good idea to look elsewhere or educate them. |
vrooooom327.50 |
02-14-2023, 12:30 AM | #20 |
New BMW owner
328
Rep 846
No one measured the ride height. I mentioned that the car was lowered but they didn't measure. They used a Hunter. Should I bring this back? I was actually disappointed that the camber on the front couldn't be adjusted (my ignorance).
Would you happen to know where the ride height info is entered?
02-14-2023, 01:19 AM | #21 |
New BMW owner
328
Rep 846
After the work...
LEFT camber: –1°39’ (-1.65°) .......... RIGHT: –1°15’ (-1.25°) Difference of 26’ (0.40°)
02-14-2023, 01:46 AM | #22 |
New BMW owner
328
Rep 846
I'm moving it here since it's more appropriate w/ the topic.
The only 2 photos I've taken of the setup.
