02-20-2016, 06:38 AM | #1 |
16
Rep 55
Coding Fog Lights to Activate When Turning / Cornering
Hi all, been wondering about the above; is it possible on an F series?
BMW M240i Sport Auto, Mineral White / Coral Red, Professional Navigation, Driver Comfort Package, Sun Protection Package, Harmon-Kardon Loudspeaker System, Sunroof, Mirror Package, Heated Seats, 405M Wheels, M Performance Parts
02-20-2016, 10:49 AM | #2 |
Lurker from behind
9
Rep 42
Yes it is
You need to set ASP_ABA_AKTIVIERUNG from night_aktiv to aktiv. You'll find that from FEM_BODY
"Understeer is when you see the tree you are hitting, if you only hear the tree then it was oversteer"
Walter Röhrl |
06-13-2018, 11:33 AM | #4 |
120
Rep 210
I have fog lights and I have done the coding for cornering lights, however it doesn't work. I found a retrofit for it: BMW cornering light, part nr. 63132288285.
Can someone who has cornering lights working confirm if they have this hardware module ? |
07-10-2018, 11:10 AM | #5 |
NewFinishColumbia/detailer
604
Rep 2,096
The fogs on my 228 do this but I also have the lighting package with active steering.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
07-18-2018, 08:36 AM | #6 |
Rep 6
I successfully coded the corresponding fog light to activate when turning the steering wheel of my F22. The car has halogen headlights. They only operate when the headlights are on (manually or in Auto mode). The downside is that I could not adjust the headlight beam height with the rotary dial anymore. I made the following changes:
*FEM | 3062 | MAPPING_abbiegel_L_output | nsw_l *FEM | 3062 | MAPPING_abbiegel_R_output | nsw_r *FEM | 3066 | KL_ENABLE_LI | KL_Ein *FEM | 3066 | KL_ENABLE_RE | KL_Ein *FEM | 3073 | C_BLC_ENA | F20 (choose your vehicle) *FEM | 3073 | C_CLC_ENA | F20 (choose your vehicle) |
