05-07-2015, 10:59 AM | #1 |
839
Rep 3,855
Put the wrong gas in my mower, am I fucked?
Yea, that happened. Instead of the 93 I put in it, I put in a mixture of oil + 93 that was for my 2 stroke bushwacker lol. It took at least 3/4 a tank of this bad gas. I forgot they were mixed. So I mow half the lawn, and it finally dies, and I can't start it up. Once I figure out that I put the wrong gas in, I dump all that gas out and unhook the fuel line that goes to the carb to drain it completely. Then I fill with premium 93. Now I can't start the mower, so I take off the air filter and start gently putting very small amounts of gas (like a few drops) directly into the carb, and that continues for 10-20 minutes. It's still sputtering, but I can keep it running as long as I'm doing this. After about 10 minutes of this, the mower starts running like new. It's not sputtering, and runs fine for 8-10 minutes at the normal RPM. I was able to cut some of the lawn and no problem. Then all of a sudden it starts sputtering again and eventually dies. I can start it up, but it dies again in 10 seconds or so. My next step is to clean the carb, anything else that needs to be done? Am I fucked here? I mean, I have a full tank of fresh 93, I emptied the fuel line, and got it running for 10 minutes and cut some of my lawn with it, what could possibly cause it to cut out after that!?
05-07-2015, 11:04 AM | #2 |
I'll get back to you
7546
Rep 2,132
You put 93 in your lawnmower?
Me too. Check the spark plug
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/ Countermeasure enthusiast. |
05-07-2015, 11:12 AM | #3 |
273
Rep 1,883
Drives: 2011 E92 M3
Should be fine, as mentioned above check the spark plug. Oil/gas mix for a 2 stroke engine won't really mess with the 4 stroke mower engine all that much except some people say it might cause some smoke. Not a big deal though.
'11 BMW E92 ///M3 - ZCP and DCT
'15 Ford F-250 - Lariat, 6.7 Powerstroke Turbo-diesel |
05-07-2015, 11:38 AM | #7 |
7546
Rep 2,132
My bushwacker and blower are electric (Li+) so no worries for me.
2018 Stinger GT
05-07-2015, 11:49 AM | #8 |
839
Rep 3,855
05-07-2015, 12:04 PM | #10 |
18603
Rep 9,436
Super + stabilizer goes in every gallon I get for the mower.
I once had access to an oil that worked for 4 stroke but was also compatible with 2 stroke, so you could just mix and not have to worry about your oh-so-attentive sons putting the wrong fuel into a machine and burning it up. Can't find that product any longer, the shop where I bought it went out of business. |
05-07-2015, 12:36 PM | #11 |
2482
Rep 9,004
I don't think you should run higher octane in them, I'm sure it's probably like a car where the combustion cycle in a car, where if it isn't tuned to run on 93 - you'll not have a complete combustion and actually lose power and mileage.
05-07-2015, 01:00 PM | #12 |
is probably out riding.
6062
Rep 2,292
Fill tank with straight octane booster. Mow lawn in half the time.
05-07-2015, 01:08 PM | #13 |
839
Rep 3,855
05-07-2015, 01:38 PM | #14 |
6062
Rep 2,292
Seriously though, best case you fouled the plug, which is no big deal. Worst case you clogged a fuel filter, (if there is one) which is also no big deal.
Pull the plug and soak the tip, without bending it, in gasoline to get all the oil off, let it dry, reinstall. Or just get a new plug. Once you get it sparking again, it'll likely smoke until it burns off all the oil in the combustion chamber.
05-07-2015, 01:40 PM | #15 | |
839
Rep 3,855
05-07-2015, 06:03 PM | #18 | |
1590
Rep 803
85 on my lawn engines. I do oil change and tuneups every year or more. Tired of buying new mowers.
Beware of Jeff Oliver the fraud at Highland Expedition Outfitters (aka HEO or HEOutfitters) located in Cosby TN.
05-07-2015, 08:26 PM | #21 |
839
Rep 3,855
Haha 93 for me. Anyways, problem fixed. Took the carb off and emptied all the gas I could out of the metal bowl at the bottom of it. Managed to put it back together (that's the amazing part), started up on the first pull and back to normal.
