01-29-2008, 01:16 PM | #1 |
![]() 353
Rep 4,484
Sports Car International 135i review...
maybe a bit old news, but did you see it?
As I had speculated and said, it's weight distribution (not as close to 50/50 as the 335i Coupe or Sedan even) and taller overall height makes it roll and understeer pretty badly. Unlike the 335i Coupe which can easily be power oversteered and doesn't plow as much, they were a bit disappointed by the 135i's track ability. They also weren't impressed by it's 6 piston brakes either, said they faded pretty significantly. They seemed to like the car and thought it had potential but would need minor mods (rear sway bar and track pads) to start to make it a bit more of a neutral track car. As a couple other mags have seen so far, they seemed to have weighed the 135i and 335i Coupe and found they were about 130 lbs apart. Strangely they stated BMW stated the 135i and 335i Coupe both had 0-62 mph times of 5.3 seconds. I thought that BMW listed the 135i's 0-62 kph time as .2 seconds faster and it's 0-124 kph time as .1 seconds faster than the 335i. That might have changed a bit in final testing, IDK. But I'd still think the 135i is around .1 seconds faster to 60 (being it's lighter) but may not be any faster to 120 mph since it's less aerodynamic. The 135i also has 10 mm skinnier tires which might make it a bit harder to launch as well without wheelspin. Anyway, I was somewhat surprised by the 135i's ability on the track doesn't seem to be up to the 335i Coupes stock for stock. I knew the fact it was more front heavy and taller would hurt it's handling a bit, but thought it would be offset by it's lighter weight. |
01-29-2008, 01:51 PM | #3 |
pull my finger to get your kinder® surprise
![]() 152
Rep 10,455
At first, I thought the advantage of 135i's lighter curb weight would 'outweigh' the disadvantage of its ugliness. But as more news articles are coming out, it seems the weight difference is minimal.
Well, who knows maybe 135i will grow on me like an ugly girl with a nice personality.
01-29-2008, 01:52 PM | #4 |
![]() 152
Rep 10,455
be that as it may, the 135i is being marketed as a truer sporty car than the 335i.
01-29-2008, 05:28 PM | #5 |
![]() 353
Rep 4,484
Yes, as do pretty much any front engine car, but not nearly what the 135i supposedly does. The 135i Coupe has about 2% more of it's weight over the front wheels than the 335i Coupe does. Rotating the 335i around with the throttle is easy, Sports Car International stated they thought the 135i would be also, but said they really could not, trying to use the throttle to get it to rotate they stated just resulted in the front end plowing even more. Again, I'm sure there are three things working against the 135i here. More weight on the front wheels Taller car which makes center of gravity higher, which mean more roll Shorter wheelbase so it's less planted But as Canuck stated, it's the fact the 135i is being marketed as the sportier car. I've had my doubts all along after seeing the 135i's dimensions/specs. And after talking to the #2 guy of BMW USA seconds after the 135i's North American debut here in LA and seeing more mag tests of the 135i, that just does not seem to be the case. I'm sure with a bit of modding it will be even better though, but as Sports Car International eluded too, many will spend the extra $5K and just get the 335i Coupe. Just based on looks alone the 335i Coupe is worth $5K more to me. ![]() |
01-29-2008, 05:44 PM | #6 |
![]() ![]() ![]() 320
Rep 8,049
Drives: E92 M3
01-29-2008, 08:29 PM | #7 | |
![]() ![]() 446
Rep 6,967
How about a non-professional review from a 335i vert owner.
http://www.1addicts.com/forums/showthread.php?t=3855 Quote:
01-29-2008, 08:53 PM | #8 | |
![]() ![]() ![]() 162
Rep 5,497
2007 E92 Montego Blue 335i
01-29-2008, 08:59 PM | #9 | |
![]() 353
Rep 4,484
The 335i Convertible is a tank, is noticeably slower than the 335i Coupe, is much more top heavy, squeaks and rattles (from what I've heard) and is not a performance car by any means. The 335i Convertible weighs 375 lbs more than the 335i Coupe. That's like having two full size adult males riding in a 335i Coupe all the time. That effects EVERY aspect of performance (from weight distribution, acceleration, braking, cornering, gas mileage, center of gravity...everything). I just think BMW should of made the 135i a stunning little handler of a car. Again, I was afraid it wouldn't be the minute I read it's specs/dimensions. The 335i Coupe on the other hand wasn't suppose to be such an impressive track car, but turned out to be and beats the MUCH smaller and lighter Z4M Coupe around some tracks including Virginia International Raceway. Doesn't sound like the 135i would. Last edited by Driver72; 01-29-2008 at 09:24 PM.. |
01-29-2008, 09:05 PM | #10 | |
![]() 566
Rep 4,021
Drives: 2008 335xi Coupe
And the 135i looks like a shoe, an ugly shoe.
"Aerodynamics are for people who cannot build engines"......Enzo Ferrari
01-29-2008, 09:29 PM | #11 |
![]() ![]() 43
Rep 1,349
+2. Like I said before, if you debadged it people would call it a Hyundai (of course till you rode in it). Obviously, we are all biased as we have 335i coupes or sedans. Still, it is what it is.
01-29-2008, 10:31 PM | #12 | |
![]() 566
Rep 4,021
Like Canucklion is saying....they are marketing the 1 series like it is going to be the new 2002.....it is ugly and not-light. Does BMW think we are all idiots?
01-29-2008, 10:42 PM | #13 |
![]() ![]() ![]() ![]() 1267
Rep 12,446
I wouldn't call it ugly. I'd say...superficially confused. With some proper mods, I'm sure it wouldn't look too bad. Fix those ugly headlights (Tii did a good job), change those droopy rockers, add a trunklid spoiler, a rear diffuser, and some new wheels. It's a lot of work, but I'm sure it'd pay off in the longrun.
I just see potential. That's all.
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
01-29-2008, 10:48 PM | #14 |
![]() ![]() ![]() ![]() 40
Rep 525
Tbone, I don't think it's butt ugly, it's actually growing on me. But you're absolutely right - it's not that light. I was expecting a lot lighter and nimbler. There's a lot of marketing hype with this vehicle, but I still think it will sell. The M sport package will help move along sales.
01-30-2008, 10:53 AM | #15 | |
![]() 152
Rep 10,455
BMWs that have grown on me in the past, Z4, 6-series.
BMWs that I have never grown to love: the 7 series with the wonky taillight. BMWs that I have come to tolerate: X3. I think 1er will fall into the same category as the X3, it's not horribly ugly, but it is pretty weird looking. There's not one aspect that I like about 1er's design. The headlights look so cartoonish and bug-eyed. The side profile is all pudgy looking, and the tails are pretty blah looking. Quote:
01-30-2008, 12:37 PM | #16 | |
![]() ![]() 154
Rep 1,938
I am actually in the same boat except for I still dislike the x3. I got to see 1 series at San Diego Autoshow and got to sit in it as well. It looks like an ugly fish to me and I could only like the car if it had full Tii setup. |
01-30-2008, 01:32 PM | #17 |
![]() 22
Rep 165
If BMW is truly trying to market this car as a performance machine, they are definitely not sending the right message with the looks of the car. It looks too cute and soft with a high upright roofline, cartooney headlights(like someone mentioned) and a droopy side character line(like some weiner dog). They should have made it look a bit meaner, I feel even the new TT looks more aggressive. I actually think the convertible looks better because you don't see the high roof line.
01-30-2008, 02:43 PM | #18 | |
![]() 152
Rep 10,455
hands down the new TT looks way better than the 1er
01-30-2008, 05:14 PM | #19 |
Rep 12,446
The TT isn't a direct competitor with the 1er though. RWD + >300bhp + somewhat useable rear seats = strange class of its own.
01-30-2008, 07:17 PM | #21 |
![]() 566
Rep 4,021
I wonder who would the contest for "fewest words per post" Canucklion or Epacy? ![]()
01-30-2008, 07:31 PM | #22 | |
![]() ![]() 446
Rep 6,967
As for looks, people will get use to it. E90 was the ugliest 3 series to date and guess what some people got use to it. Some people still hate it but who cares. Personally, I think BMW's design has gone down hill since the Bangle inspired refreshment rolled out. |
