2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions DIY: Removing Sunvisor Decals
      01-13-2015, 07:44 PM   #1
NEUE02
NEUE02's Avatar
267
554
Drives: M235i
I can't stand looking at the unsightly Sunvisor Warning Decals so I thought I would create a little how-to for others showing what I feel is the easiest way to remove them. (WARNING: Remove OEM warning stickers and mattress labels at your own risk. Death, injury and hefty fines may result.)
Items needed:
-91% Isopropal Alcohol (70% is not strong enough)
-Small sponge
-Plastic pry tool
-T20 Torx driver
1. Using pry tool carefully unsnap the hinged screw cover.
2. Remove screw with Torx driver
3. The hinge is now loose but must be rotated forward and pulled out of the rectangular mounting hole. Note electrical connector that is snapped into the side of the hinge.
4. Pull the electrical connector free from the hinge. Now unsnap the two halves of the connector and remove the visor from the car.
5. Soak the sponge in the alcohol and soak the decal. Be patient. Keep it wet. You can even walk away for a couple minutes if you desire. After 3-5 minutes the decal will start to shrink and loosen.
6. Scratch a corner loose with your fingernail and start to slowly pull upwards. Keep soaking the decal as you pull. Work slowly, the goal is to pull the decal off in one piece. It will all pull off in about 1-2 minutes.
7. You will end up with the entire sticker shriveled up in one piece with no residue left on the visor.
8. Much better!
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S
Appreciate 14
      03-20-2015, 05:16 PM   #2
aldrichg
13
Drives: 2015 M231i Glacier Silver
2015 M235i/F22  [0.00]
2015 X4 28i/F26  [0.00]
Nice DIY
Done in 5 minutes. You're tip on the stronger alcohol concentration is the key, I think. Didn't even know it came in more than one strength. I wonder, will this tip work with alcantra covered visors like in the X4?
      03-21-2015, 11:42 PM   #3
eatsmeetswes
21
Drives: 228i
Thanks for the post! Been meaning to do this for a while and finally got around to it today.
      03-22-2015, 09:18 AM   #4
338FREAK
10
34
Drives: Midnight Blue 2015 BMW 228XI
One question, anyone notice any discoloration after time due to the alcohol penetrating the visor?
      03-22-2015, 10:23 AM   #5
horsepower_and_hounds
1837
4,203
Drives: BMW
Did mine today ...took me way more than 5 min but I think I purchased some falsely advertised alcohol
      03-22-2015, 12:44 PM   #6
NEUE02
NEUE02's Avatar
267
554
Drives: M235i
No, never have seen this. Been successfully using this procedure for well over 10 years.
The Stable
      03-22-2015, 07:21 PM   #7
338FREAK
10
34
Sounds great thanks!
      03-24-2015, 06:31 AM   #8
mcom
26
78
Drives: 2015 Alpine WT M235i Vert
Thanks for posting, pics and all very easy laid out process....looks simple and I too hate those warning stickers... Got everything apart... almost.
Step 4 has confounded me.. I cannot figure how and where to pry or where they come apart/unhook....perhaps poor eyes, but can't figure it out.. don't want to break it as it seams at least over engineered to be difficult, lol.
any suggestions would be helpful!
      03-24-2015, 07:38 AM   #9
NEUE02
NEUE02's Avatar
267
554
Drives: M235i
To split the small connector from the large connector I inserted an Xacto knife down the side of the small connector and into the large connector only about 1/8" then simply pried outward to pull the small connector out. It takes some force but it will separate and does not break. It needs some force to overcome the internal barb. You could try a tiny jewelers screwdriver, too. It just needs to be very thin.
hoppy6698127.00
      03-25-2015, 08:10 AM   #10
pete1713
20
93
Drives: 2015 M235i
This is a great post, thanks for the detailed process and photos. Works like a champ. My label didn't actual shrivel or anything, after 5 or so minutes I just started gently rubbing one corner with fingertip, it started rolling up with no issue.
      05-14-2015, 04:57 PM   #11
jtzako
115
Drives: 228i M-Sport
I hate those stickers, I may do this also.. fyi, the mattress label etc warning only applies to the mfg and original dealer. The consumer can remove them w/o consequences.
BM235iW97.00
      05-16-2015, 01:40 PM   #12
mcom
26
78
Step 4... Granted I am an idiot, I cannot figure out how to "unsnap the connector"... Can't even find a pic of what each sde looks like. Why on god's earch would someone make a cnnector so complex? Seems rediculous.
Have tried gently pulling, wiggling, even tried an exacto knife tip, (which broke the point off btw). I almost just cut the wires...
While I understand my place in the world, this stupid connector and the annoying stickers will not beat me! Help?
2015 M235i White with Black interior loaded except for DA+ and LSD
      05-16-2015, 03:14 PM   #13
NEUE02
NEUE02's Avatar
267
554
Drives: M235i
^^^ Hang in there! You can do it. IIRC the female half if the connector, the larger side, stays with the sun visor once removed. While holding the connector I inserted the blade into the flatter side of the connector. Insert the blade the tiniest amount. (I think you inserted it too far which just wedges things tighter) just "prick" the connector and it will pull out.
You're so close! Just use patience. You'll laugh once you see how simple it really is.
The Stable
      05-16-2015, 06:02 PM   #14
b_ack51
77
Drives: 2014 M235i
Thanks. This worked for me. Took a few extra minutes on one side though.
The connector was pretty easy. Thin flat head worked to separate the pieces. I should have taken a pic to remember where exactly I disconnected.
      05-30-2015, 10:58 PM   #15
krhodes1
1439
2,529
Drives: 2011 328i Wagon
2011 128i  [10.00]
2011 BMW 328i Touring  [10.00]
Do you suppose if I did this while I am still on my Euro Delivery trip that the port would "fix" it before re-delivery?
This was the second mod I did to my 328i wagon upon re-delivery. 15 minutes after I got it home. The very first was the ZHP shiftknob, which I did while the car was still on the turntable at BMW Welt!
'11 328! Touring - Tasman on Chestnut, 6spd manual, factory upside-down "i" option
'11 128i Convertible - Space Gray on Savannah Beige, 6spd manual,
also '14 Mercedes-Benz E350 wagon, '95 Land Rover Discovery, '74 Triumph Spitfire
      06-14-2015, 02:50 AM   #16
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
604
2,096
Drives: 2015 F31 xDrive
Doing this for sure. I really hate this stickers.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
wiggy1.50
      07-06-2015, 09:52 AM   #17
Anchored
64
197
Drives: E39
Wish there was not a shadow there :/
Anyone know if you can still order the Euro parts without the label?
      07-06-2015, 11:02 AM   #18
NEUE02
NEUE02's Avatar
267
554
Drives: M235i
Don't worry, there's is no shadow if done correctly. Follow the directions per above. I took this pic today.
The Stable
      07-07-2015, 06:22 AM   #19
1837
4,203
Drives: BMW
I have some shadowing but way way better than the yellow option
      09-03-2015, 12:17 PM   #20
steffenme1
steffenme1's Avatar
103
109
Drives: 2007 Z4 MCoupe
Did this last evening, there was some initial shadowing but that was because the sticker didn't come off very cleanly and left some residue behind. I found regular old acetone (not nail polish remover) quickly removed the residue left behind without much fuss.
Thanks for posting this up!
      10-09-2015, 05:47 AM   #21
JakePoole
JakePoole's Avatar
United Kingdom
15
Drives: BMW M235i
wicked tutorial, my torx bolts were t25 though, t20 was loose, looks so much better now thanks!
      06-24-2016, 06:44 AM   #22
rjwojcik
rjwojcik's Avatar
284
707
Drives: 2016 VW Golf GTD
I will be giving this a go soon. Great write up
2addicts
