11-08-2014, 06:49 PM | #1 |
Rep 24
Winter setup with no sensors: light is not on?
I have a 2015 228i M Sport. This morning I swapped the OEM wheels with my new winter wheel/tire set. I did not get sensors with the winter set, but to my surprise when I drove the car to test the new tires the sensor light was not on. Not sure if that is normal. I thought that the TPMS light would stay on without sensors.
11-08-2014, 08:41 PM | #2 |
***** noob
1380
Rep 10,479
Interesting as I have winter without tpms also (not on the car yet)
2006 325xi (Sold)
11-08-2014, 10:38 PM | #3 |
102
Rep 775
I can't see your location however Canadian cars use axle rotation to measure the tires. It's not a reading, just a measurement to tell if the tire is going flat.
So canadian cars do not have sensors.
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com Current: 2015 Cayman S on HRE P101 |
11-09-2014, 09:13 AM | #4 | |
312
Rep 862
Drives: '19 M2 '21 X5
Canadian cars use FTM which uses the abs system to estimate deflation. They have nerfed Tpms from the vast majority of the line now. My salesman was telling me yesterday that the reliability of the system was horrible and would basically go of anywhere below -20C. Which makes sense because that's how thermodynamics works. Ftm works much more reliably in canada. |
11-09-2014, 12:45 PM | #5 |
431
Rep 1,115
Pretty sure we have the sensors. My light is on now, ever since I changed over to winter wheels and tires. I tried the reset multiple times and it didn't work. Also when I got my rear wheels swapped for 8" wide the tire shop said they swapped the sensors over.
11-09-2014, 01:06 PM | #6 |
9
Rep 347
There is no TPMS in Canada. The problem could be caused by the Wheel Speed Sensor (used by Flat Tire Monitor, TC, ABS) being thrown off by a change in your overall wheel/tire diameter. You went down to a 17" wheel, so you need to compensate with a higher sidewall height to maintain the same overall diameter and rotational speed as the 18" wheel had. Otherwise, if the variance is large enough, the WSS reads a higher rotational speed and attributes that to wheel spin.
F22 * (N55 + 6MT) ÷ PSS = FUN
11-09-2014, 01:42 PM | #7 | |
256
Rep 1,040
11-09-2014, 02:14 PM | #8 |
Rep 24
I do have a USA spec model that came with 18" stock wheels. My winter set is 17" with 205/50/17 winter tires (same overall diameter as 18" 225/45/18). I drove ~ 15 miles with new tires and still no light. I will let you know if light comes on after 100 miles. Thanks.
11-09-2014, 02:19 PM | #9 | |
431
Rep 1,115
11-09-2014, 02:30 PM | #10 |
Rep 24
I did not reset the sensors. Just swapped the wheels and the light was not on. If light does not come on if I don't reset the sensors it's actually better (one less annoying light on the dash...)
11-09-2014, 02:46 PM | #11 |
431
Rep 1,115
I reset mine thinking it would start flagging every wheel as being low. It kept chiming that my summer tires were low on cold morning and I'd have to reset it.
11-10-2014, 08:52 AM | #12 |
431
Rep 1,115
Tried the reset again with no luck. It seems to be working while the car is parked in the garage near my summer set, but once I'm driving for 10 mins it shows the TPM error.
11-11-2014, 06:16 PM | #14 |
256
Rep 1,040
Was good while it lasted. Kinda like those who have decatted downpipes and need to get a state emissions check. Clear the check engine light with a cheap OBDII reader and drive it immediately to the inspection center before it triggers again.
