      04-25-2024, 03:56 AM   #1
footie
footie's Avatar
1133
8,020
Drives: i5M60
i5M60 Active Cruise control
My i5M60 was sitting on the driveway waiting for me on my return from holidays so very new to it but having had the i4M50 I assume most aspects of the active cruise control would be the same but it doesn’t appear to be the case.
With the i4M50 when in cruise control it read the upcoming speed signs and allowed you to preset these as you approached so it slowed or increased the speed accordingly but this doesn’t appear to be available on the i5 or is it hidden in a menu I just haven’t found yet?
SkykingUSA1363.00
      04-25-2024, 04:55 AM   #2
Stokkes
Grand Pumba
Stokkes's Avatar
153
82
Drives: On Order: i5 M60 IOMG/SWV
Should be supported. If you look at page 214 of the manual I believe it does show it being supported. Don’t have my car yet but the autonomous systems (assuming you have the correct packages) should be more advanced than the i4.
https://f30.bimmerpost.com/forums/at...mentid=3280966
Ordered: i5 M60 Isle of Man Green (Apr 6, 2024)
Status: Production # received (Apr 11, 2024)
SkykingUSA1363.00
      04-25-2024, 07:51 AM   #3
footie
footie's Avatar
1133
8,020
Drives: i5M60
I think I have discovered it in the menu you have mention, yes it appears to be more advanced than the i4, with the i4 you had to make the adjustment to the incoming speed manually but on the i5 you can set it either manual adjustment or automatically.
Have yet to try it out and will report back.
SkykingUSA1363.00
      04-25-2024, 10:40 AM   #4
scas12
367
101
Drives: Audi SQ5, i5 M60
What's a speed limit?
Scrapula2811.00
SkykingUSA1363.00
      04-25-2024, 11:07 AM   #5
Deho
252
98
Drives: 2023 MINI Countryman SE
The thing that protect your life and the lives of your loved ones.
LVBMW1451.50
SkykingUSA1363.00
      04-25-2024, 03:52 PM   #6
footie
footie's Avatar
1133
8,020
Drives: i5M60
Ok as I said earlier the system does indeed allow you to set the incoming speed either manually or let the car do it automatically.
There’s a lot new to learn with this car compared to the i4M50, something good and others which are a backward step. Like I said I arrived home from my hols to the car sitting in my drive, I basically ordered the car without even driving it so the other day was the first impressions of the car and it’s a quite a difference to the i4. Firstly is the size, having come from an M5 Competition so expected the same but this feels a bit bigger and harder to place on the road but this only lasted a couple of days. Comfort or maybe isolation is a better word because you are WAY more isolated from the road in the i5 which was one thing I wanted so very happy.
Count yourself luck if you live in the US because over here in the UK and Europe we have this new law that speed warning is always on whenever you start the car and it’s a total pain, plus it’s not a simple two button press to turn off, I don’t know why they can’t make the turning off as simple as switching off DSC, make a button for this purpose even if you have to press it for 5 seconds to deactivate.
Deho251.50
Scrapula2811.00
SkykingUSA1363.00
      04-25-2024, 05:02 PM   #7
digriz
144
35
Drives: i5 M60 Carbon Black
I watched a number of youtube videos that seemed to suggest that if you start the car and then keep the SET button on the left steering wheel stalk pressed for a few seconds, the speed warning should be disabled until the car is turned off.
I cannot try this but I hope it works for you.
Cheers!
SkykingUSA1363.00
      04-26-2024, 01:15 AM   #8
tjsf2011
14
Drives: BMW X4
Cheers!
I can confirm that it actually works and that is much easier and faster than other brands where you need to get into many menus to deactivate the warnings..
SkykingUSA1363.00
      04-27-2024, 03:39 PM   #9
footie
footie's Avatar
1133
8,020
Drives: i5M60
Tried pressing the SET button on the steering wheel and indeed if you keep it pressed for a few seconds on the HUD it confirmed the Speed Warning is deactivated.
I must say the more I drive it the more I am enjoying this car. A seriously polished driving experience.
SkykingUSA1363.00
digriz144.00
scas12367.00
