04-01-2024, 11:21 AM | #23 | |
9
Rep 4
Our car is driving as drunk from one lane to another. Left to right, never straight on. I got 2mln km experience, and several premium cars behind (changed to 530e right from MB e 220d, 2 years old now). I really know how car should drive and how steering wheel should work. That is just technical issue, nothing to consider as" turn on keep lane assistance" etc. Btw, when you torn on drive assistant it also goes from left to right makes me feel sick. |
04-03-2024, 09:55 AM | #24 | |
423
Rep 101
It is steering/power assistance issue. When steering is operating normally, it’s good. But I’ve done drives commuting back and forth to work (40miles, mixture of roads) and there’s no consistency to when steering wheel gets “stuck” when not moved- whether that be dead centre or off centre eg. on sweeping curve. |
04-03-2024, 11:42 AM | #25 | |
41
Rep 10
Good luck getting it fixed, this should be a priority for your dealer |
SkykingUSA1437.50 |
04-03-2024, 01:40 PM | #26 | |
423
Rep 101
All commenting is good, you never know what could help! |
04-05-2024, 10:08 AM | #27 | |
9
Rep 4
FYI- it is rather not steering column, as I got already changed to new, and nothing get better... |
SkykingUSA1437.50 |
04-05-2024, 11:22 AM | #28 | |
822
Rep 243
I'm taking mine in on Tuesday but honestly don't have high hopes for solving the issue. BTW, lately I've noticed a new symptom - after sitting all night charging, the steering makes this dull click once I start turning right. So I turn on the car, drive straight to pull out from carport, turn right, it clicks right before I turn. What's weird, it only happens once during the day, mornings only, as if the steering unlocks. |
SkykingUSA1437.50 |
04-05-2024, 11:42 AM | #29 |
54
Rep 15
I got a new 540 not quite two months ago and while I noticed the steering pressure was much lighter at very low speeds, I haven't had any problems adjusting to it. I also haven't noticed any problems at higher speeds.
elbmw821.50 SkykingUSA1437.50 |
04-07-2024, 02:05 PM | #30 |
47
Rep 14
Hi All,
What a relief to see this post ... that I'm not alone. I informed my dealer 2,5 months ago, they tried do find out themselves, but they are not 100% convinced. They problem is really only noticeable at 125 km/h or 77 mph. And they just drove for 10 seconds at that speed. The workers over there over overloaded. My problem is exactly as described above : impossible to keep lanes in manual mode. I always use 'driving assistence' and you can feel the car making constant corrections. But the danger is when the diving assistence switches off, eg. no road signalisation, or I touch the brakes ... at that moment it is very difficult to control the car, imagine there happens a car accident in front of me, how can I avoid a collision ??? My idea is that there is something wrong with the alignment? The dealer want to check this, but they are also thinking of replacing the stearing colon, a 48-volt type due to the stearing back wheels. I have a i5 edrive 40, with M-performance pack (a bit lower) and stearing back wheels that can turn 3% or so. What is your setup ? Last edited by MaVaGe; 04-08-2024 at 04:16 AM.. |
SkykingUSA1437.50 |
04-08-2024, 10:59 AM | #31 | |
423
Rep 101
I have M60 (rear wheel steering same as you) and my issues are completely RANDOM it seems. As I mentioned in earlier post, I drive the same route to and from work, with different roads and speeds from 30-70mph. There is no consistency to when the steering gets “stuck”….. My thoughts were also tracking issues. But it even feels like the wheels are all moving independently from each other sometimes….it’s such a difficult issue to describe! 😩 |
SkykingUSA1437.50 |
04-09-2024, 07:17 AM | #32 | |
47
Rep 14
Wheel alignment issue ??
I suspect a problem with car/wheel alignment. E.g. Camber: https://www.ecu-repairs.com/how-do-p...ffect-your-car If there a suspension issue, the camber can change by the pressure on the front wheels : when accelerating less pressure, when slowing down, more pressure. Even more frontal wind can put more pressure on front wheels. So every ride has different feeling, exactly what I also reported. I'm an engineer and like to objectivate the problem, to measure things. So I bought a Newton meter, something like this:https://m.media-amazon.com/images/I/41uMPG6fYXL.jpg, but then for 20N. My measument on the stearing (20cm) converted to NM gives me these results: 70km/u => 8 N or 1,6 Nm 90km/u => 10 N or 2,0 Nm 125 km/u => 14 N (deadpoint !!) or 2,8 Nm !!! I also asked BMW Belgium to escalate this issue with the engineers in Germany. |
04-12-2024, 03:04 PM | #33 |
822
Rep 243
So I took my car in for service on Tuesday, the dealer had the car for 2 days.
As expected, they couldn't find any issues, told me to keep the nannies off to avoid any inconsistences in the steering feel and hope for an over the air update which might fix the issue. But I swear that the steering feel is much better now after the visit. It's heavier and more linear, I actually enjoy it now. Before, I always switched to sport mode on freeway to get at least some sort of improvement. But today I was on the phone and completely forgot to do so. I still noticed the overall improved feel and then realized that I drove 20 miles in personal setting, which is set to comfort, and it didn't bother me at all. I would not be surprised if the dealer actually reprogrammed the car, yet couldn't admit it to avoid any legal action against BMW. Dunno, that thought immediately popped in my mind after I tried to make sense of what happened. So for now, I really hope that the car will continue behaving this way 'cause I like it. One more thing, I purposely chose a G30 530 loaner to compare it to the G60 because I considered my previous G30 540ix to be the best BMW I've had to date. I hate to admit it, I really disliked the car. It looked and felt outdated, the materials felt cheaper (the car had sensatec interior and plastic dashboard) The suspension was jittery and felt as if it never settled, the base music is definitely not on par with the base HK system in the G60. Most importantly though, I also disliked the steering feel. Yes, it was definitely heavier in the G30 but I felt like the actual steering feedback was also absent as in G60. But the steering in G60 is noticeably quicker and more direct. It actually felt as if I was driving through molasses or something while in G30 That's how much slower and heavier the steering felt in G30 after driving the G60 for 5 weeks. So, I was pretty shocked to come to these conclusions as I truly enjoyed my G30 540ix for 3 years. Overall, I can confidently say now that G60 is a much better car and it also feels as it's a class above G30. |
04-12-2024, 04:35 PM | #34 |
1832
Rep 492
I felt some - very minor - non-linear irregularity in my steering and I made a service appointment for a week and a half later. Several days after I made the appointment I canceled it because I really couldn't replicate the problem and there really seemed to be nothing wrong with the steering. Haven't felt any irregularities with the steering since then and the car drives like a dream.
Regarding comparisons with the G30 the audio system in the G60 (B&W) is orders of magnitude superior to the base audio in the G30. Much more articulate and well balanced. Was your G30 loaner a 530 or a 540? After you get used to the superb B58, any 4 cylinder engine will disappoint. |
05-02-2024, 01:25 PM | #35 |
47
Rep 14
Hello All,
Good news !! My problem has been solved, they replaced the Steering Rack and the car is driving very fine now. Also on the highway (at 125 km/h) it's a joy to drive the car by hand. Very smoothly. And with the driving assistence activated, the steering wheel is stable and not rotating to keep the straight line any more. Hope you all can convince your dealer too. They technician drove my car and found the steering very bad at 125 km/h. The wheel alignment was not okay, but this didn't solve the problem. Then BMW Belgium allowed the replacement. I let the car for almost 2 weeks at the dealer but now ... completely satified. The car was like 'hoovering' above the road before, but is now soundly grounded to the road. Very good. Cheers ! Marc |
LVBMW1541.50 Scrapula2880.00 SkykingUSA1437.50 Dragonfly Trumpeter40.50 RichardInCA2562.00 alewifebp486.50 Mac545422.50 elbmw821.50 |
05-02-2024, 06:49 PM | #36 |
1438
Rep 521
That's great news! I'm glad you got it fixed and can now enjoy driving the car in the way it is supposed to be driven.
