02-11-2024, 11:33 AM | #1 |
102
Rep 29
Pre-Conditioning Confusion
I have read a lot of threads and I am getting mixed opinions on how the pre-conditioning works. After reading all the threads, I know that there are 3 types of preconditioning:
When at home: 1. Pre-condition to cool/warm the cabin (Also called Climatization) 2. Pre-condition to get the battery to an optimal temperature for the longest range When on-route to a DC charging station: 1. Pre-condition to get the battery to an optimal temperature for the fastest charging time That said, what I am confused about the how to enable the different pre-conditioning functions when at home. I have read that hitting the fan icon on the MyBMW app only enables climatization but not conditioning of the battery for departure. The only way to pre-condition both the cabin and battery for departure is to set a schedule time for departure. How true is this and does the fan button only enable climatization? |
02-11-2024, 11:55 AM | #2 | |
4720
Rep 2,689
You must set a departure time via the app (or in the car, if you remember) if you want the battery and cabin preconditioned! |
02-11-2024, 02:34 PM | #3 |
3924
Rep 961
Drives: 24 BMW i5 M60
I’m actually not clear if the departure time pre-conditions the battery rather than just sets cilimatization on a schedule. You can manually precondition the battery, but it seems that’s only really useful when going to do a DC fast charge. The exception is probably really cold climates, but I’ve only found battery preconditioning in the context of DC charging.
02-11-2024, 03:56 PM | #4 | |
4720
Rep 2,689
SkykingUSA2595.50 Trevor G1772.50 |
02-11-2024, 04:20 PM | #5 |
4720
Rep 2,689
02-11-2024, 04:25 PM | #6 |
3924
Rep 961
Was going to edit but deleted instead - but the manual is entirely unclear about all of that. I always see the range drop a couple of miles when I precondition (manually activating) - but this happens almost instantly and does not seem to be accompanied by a routine change in SOC.
02-12-2024, 11:29 AM | #7 |
4166
Rep 1,162
I never precondition, but it doesn’t really get cold here, often. It doesn’t matter for home charging. And for cabin temperature, it warms up to 70 degrees within minutes, even when it’s 40 degrees outside. It automatically turns on my seat heater and steering wheel heat when I start it up, regardless of asking Alexa to warm it up.
02-12-2024, 12:10 PM | #8 | |
4720
Rep 2,689
My i5 M60 has never once self activated the steering or seat heating, when doing pre-climate. How does yours do this, what did you do in settings? Thanks. |
LVBMW2364.00 SkykingUSA2595.50 |
02-12-2024, 02:03 PM | #9 | |
4166
Rep 1,162
02-12-2024, 02:15 PM | #10 |
4166
Rep 1,162
It is in climate control and then select individual settings.
02-14-2024, 10:34 PM | #12 |
Chief Engineer
1773
Rep 405
Drives: 2024 I5 M60
The car pre-conditions the battery according to set departure times. Pre-conditioning in the app is for climate control. Setting a one time departure time in the app will pre-condition the battery also. The change in available miles is just temporary and adjusts back up once you start driving. Think of it like idling in a gas car. Your mpg goes down but you really are not using much gas. Once you start driving your mpg goes back up.
2024 i5 M60 Carbon Black / M Veganza-Alcantara Black / Grey Blue Ash Trim Dk Silv Acc / Executive Package / Driving Assistance Pro Package / M Sport Professional Package / 20" Bicol JetBl 938M AS NonRFT / Front and Rear Heated Seats / Front ventilated seats
