04-14-2024, 07:33 PM | #1 |
161
Rep 203
Charging Door Won’t Unlock
The other day I pull in to my garage and walk around to open the charge port door and it won’t open. I unlock/lock the door 50 times. Nothing. Try the real key, the digital key…nothing. I started the car and took it for a quick ride around the block and when I pulled back in the port door was unlocked. Figured oh well.
It’s happening again now! The @#$!@# door won’t unlock. Any tips on what I can do? Thanks in advance. |
04-14-2024, 07:46 PM | #2 |
111
Rep 118
there should be something in the setting to unlock the charging flap. hopefully it will work for you.
SkykingUSA1310.50 |
04-14-2024, 07:51 PM | #3 |
2477
Rep 592
I also read a post on another forum about an i5 user who took delivery and his charging port door stuck shut. It needed a fix at the dealer/replacement. If it’s not obvious from the settings, it’s probably worth a check-in with the dealer.
SkykingUSA1310.50 Tek-dad160.50 |
04-14-2024, 07:57 PM | #4 |
360
Rep 99
I've had this issue sometimes, I just locked the door (for the car) and unlocked and the charging door would open.
04-15-2024, 10:42 AM | #5 |
3953
Rep 2,395
This happened to me last week. Car was unlocked, parked in our garage. Charger door would not unlock. I locked and unlocked the car with digital key+ and even went and got the actual key fob...charger door would not open. I tried locking and unlocking from inside the car with the door lock buttons....charger door would not open.
Then randomly, the charger door let me push to open it :/ It has not happened again, but could have been an issue if trying to public charge and being critically low. |
04-15-2024, 06:37 PM | #6 |
2754
Rep 808
This finally happened to me today. I tried unlock, lock, toggled settings in the car, walked away, came back, etc. I finally turned on the car and then turned it off. That worked. This time.
04-15-2024, 09:00 PM | #7 |
161
Rep 203
It’s crazy right? When it happens there is no way to get the port open! So far it’s happened twice to me.
04-16-2024, 09:42 AM | #8 |
338
Rep 174
Happened once to me, I lock and unlocked the car and then it worked. Perhaps they should have made it a mechanical switch accessible from inside the vehicle. Sort of like a lot of cars have to pop open the gas tank cover.
deutsch1003952.50 SkykingUSA1310.50 |
