10-23-2023, 05:06 PM | #1 |
RichyX5
Rep 4
BMW X5 E53 2006 Battery drain
Hi Everyone,
My car was all okay for a year, has a near brand new battery It now goes flat after 2 weeks, so I hooked up amp meter to the negative terminal off battery and to the negative battery post Draws 5.3 amps initially then something goes into sleep mode and drops to 3.3 amps I traced to the panoramic sunroof fuse 58 without this fuse only draws 0.3 amps But the drain isn't on the feed in side it's actually after the sunroof ecu on the pale brown wire next to the red / green strip wire ( the 2 thickest wires) I have headlining and seats out atm so thought I'd try to track down The pale brown wire looks like it goes down the Right hand Drivers side A pillar, I found a wire that goes under the seat to somewhere but I'm really not sure if it goes anywhere else or if its the same wire. Can pull all other fuses out and it doesn't make any difference on Amp draw Hope someone can help me trace it |
10-24-2023, 06:48 PM | #2 |
1001
Rep 2,217
Try https://xoutpost.com/bmw-sav-forums/x5-e53-forum/
Good luck!
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
