04-17-2024, 08:49 AM | #1 |
1832
Rep 492
First significant problem
My front camera has a terrible haze over it. At first I thought it was probably due to a dirty lens but, sadly, such was not the case. I suspect it's a defective photo sensor so I made an appointment to have it checked out and probably replaced. As reluctant as I am to have the dealership service department mess with the car, this is something that really does need to be addressed as it really renders the AR view in navigation useless.
Anyone else having a similar camera image problem? Last edited by PsychDoc; 04-17-2024 at 10:56 AM.. |
04-17-2024, 08:54 AM | #2 |
2568
Rep 616
No issues for me - fingers crossed for an easy fix.
04-17-2024, 09:14 AM | #3 |
4051
Rep 2,435
So sorry, you are experiencing this. To date, I have never had an issue with any BMW exterior camera. Sadly you have this, but luckily this seems to not be the norm. Keep us posted and good luck!
04-17-2024, 10:28 AM | #4 |
2906
Rep 849
No problems for me. Did you run it through a car wash where it could have been damaged? It’s the one offset on the front grille, right?
04-17-2024, 10:58 AM | #5 |
1832
Rep 492
No, but a standard car wash shouldn't pose a hazard to the front camera anyway. After all, we often drive through pouring rain.
04-17-2024, 11:37 AM | #6 |
2906
Rep 849
04-17-2024, 11:40 AM | #7 |
1456
Rep 526
Keep us updated. It looks like moisture might have gotten into the camera behind the outer lens or something. Good luck.
04-17-2024, 03:59 PM | #8 |
147
Rep 86
Yeah it does look like moisture did you really get good look at it with a light or flashlight to see if there's any moisture inside the lens condensation
Nighthawks750.50 SkykingUSA1455.50 |
04-17-2024, 04:33 PM | #9 |
824
Rep 672
Pretty sure the camera that generates that image is behind the rear view mirror, not on exterior of car. You’ll see the wipers pass it when they are on when the AR is on. Is it possible there is moisture in that area? That’s certainly what it looks like to me.
04-17-2024, 05:21 PM | #10 |
98
Rep 62
The camera in the AR view is one in the windscreen not the grille
04-17-2024, 05:51 PM | #11 | |
1832
Rep 492
04-18-2024, 06:49 AM | #12 |
1832
Rep 492
[Update] So I had no idea that the AR camera was actually behind the rear view mirror. I had naturally assumed it was the view from the camera in the front grill. So, because I didn't see any dirt or other obstruction on that camera assembly in the grill I had to assume there was a problem with the sensor behind it. Anyway, fast forward to this morning I went down to my car and because it's raining here in NY I put on the wipers and confirmed that you can see the wipers briefly go through the field of view of the AR camera. Then I realized that the AR view was working perfectly with a nice clear view forward. There must have been some dirt on the top of the windshield which was cleared when the wipers were engaged. So all is well and I (sheepishly) canceled the appointment I had made with the dealership's service department.
Boy, do I ever feel stupid. LOL Thanks for the the responses which guided me to this "solution.". |
15
digriz153.00 PJH2433.00 RichardInCA2568.00 MrDit338.00 Sisyrx251.50 deutsch1004051.00 Scrapula2905.50 LVBMW1562.50 scas12385.00 SkykingUSA1455.50 DaveAMN48.00 MadMax777824.00 Ossian90.00 Nighthawks750.50 ando2005.00 |
04-18-2024, 12:10 PM | #13 | |
197
Rep 59
PsychDoc1832.00 SkykingUSA1455.50 |
04-19-2024, 02:53 AM | #14 | |
1456
Rep 526
Glad you figured it out Doc before bringing it in!
04-19-2024, 07:05 AM | #15 |
824
Rep 672
Glad to help! And glad it wasn’t a problem after all.
04-19-2024, 08:04 AM | #16 | |
1110
Rep 781
Bluegrass Bimmers
Current: 2019 G30 540i M Sport | 2022 & 2018 G01 X3 xDrive30i Past: 2017 F30 340i M Sport/6MT | 2013 E70 X5 3.5 | 2011 E90 ///M3 6MT | 2005 E46 330i ZHP 6MT | 2001 E53 X5 3.0 | 2000 E39 528i Sport/5MT | 1998 E39 528iA | 1997 E38 740i | 1993 E36 318is |
Scrapula2905.50 SkykingUSA1455.50 |
04-19-2024, 08:36 AM | #17 |
1832
Rep 492
SkykingUSA1455.50 |
04-19-2024, 01:56 PM | #18 |
1110
Rep 781
One other comment on the front camera in the grill...those cameras are pretty robust. I had to replace the one on my G30 (located in the center of the grill on that generation rather offset in the G60) from a rock chip/crack in the outer lens and it required dealer coding because I didn't know BimmerCode well enough to activate it myself. Only use that at parking speeds and the crack just distorted the view rather than having no camera view. It's possible a photo site could go bad in one of those, but more likely a crack in the lens on the front.
Bluegrass Bimmers
SkykingUSA1455.50 Scrapula2905.50 |
04-20-2024, 12:18 PM | #19 | |
751
Rep 153
05-15-2024, 03:32 PM | #20 |
Rep 1
Front camera in grille broken
On my way home from the dealership with my new 2024 540i xdrive, I found that the cover on the front camera located in the grille was broken. Probably a stone kicked up and broke it, since it was fine on delivery. The camera still works, however the image is distorted due to the broken cover. Does anyone know if this cover can be replaced, or if the entire camera has to be replaced? I have the M Shadowline trim, so the grille, camera and all sensors are covered with black plastic (or glass). Any knowledge of part numbers would also be helpful.
05-15-2024, 04:32 PM | #21 | |
1832
Rep 492
