      08-26-2016, 03:39 PM   #177
Flying Ace
Flying Ace's Avatar
5051
11,907
Drives: Taycan GTS, 997.1 & 991.1 GT3s
Originally Posted by hl0m4n View Post
i only have x2 cards in my wallet: debit card + amex plat.
amex plat is my first and only card and i am a member for almost a decade now.
if i were to get the chase reserve card and cancel my amex plat, what will happen with my credit score, credit limits, etc?
my current limit on amex is $40k with an additional line of credit available.
Originally Posted by KingOfJericho View Post
You shouldn't have a limit on your Amex Platinum at all. Also, what you should have done is use the Amex Everyday Preferred card (which is an actual credit card, not a charge card) in conjunction with your Platinum to accelerate your point accumulation. That's what I did and it rocked.
You also ALWAYS keep the credit card with the longest history. What you should do is downgrade your Platinum to a gold then open the Chase Sapphire Reserve.
Originally Posted by fecurtis View Post
Yup, that's exactly what I do.
I think specifically on AMEX Plat, it's hard to tell how it would affect credit. Amex Plat is a charge card with credit balance features IF it is extended to you.
Best way to tell if it affects credit is to run an actual annual credit report to see if it shows up as a revolving credit account on your on report.
If it does, that means it is viewed as a credit product. And in this case, if you cancel this card, it'll have some impact. My thoughts on cancelling (again IF this card shows on the credit report and is seen as a credit account) are:
- always open up a credit line first before closing one. So you may need to open up a $40k credit limit card first before closing out this $40k limit one. (again AMEX is a charge card, the $40k isn't technically a credit limit, it's a charge limit, so it goes back to whether this is seen as a credit account or not). And $40k is an estimate, b/c it's in the technical sense of what "credit" actually means. Remember $40k is a fluctuating figure based on past spending and payment history on that card.
- if you close the AMEX, b/c it'll be your older credit account, it'll affect your FICO. FICO has a factor on average age of credit accounts. There's no counterbalance to this affect. Only possible way to deflect this is that you may have another credit card of similar age or older.
My suggestion is, you probably have a ton of AMEX MR points for all your years of spending. You've invested heavily into MR program. Don't change now, unless you deplete your MR points. Remember you need a MR card to retain all your MR points, or it'll evaporate the moment you cancel Plat, unless you've already transferred all the points out. A cheap MR retainer card is the AMEX Everyday no annual fee card.
IMO, Chase UR and AMEX MR programs are almost the same. You can achieve the same results through both program transfers. I thought long and hard about signing up for this card last night, and it's about commitment to one program. So are you ready to switch to Chase UR? Remember, if you do cancel this reserve card, you'll also need a Chase UR retainer card as well.
My thoughts on this card vs AMEX Plat, which I also have:
Originally Posted by Flying Ace View Post
My take on this new card is:
- similar to Amex Platinum
- can get almost all of your AF back in year 1
- no value in paying AF in year 2, so have a backup plan when you do cancel
- not better than Amex Platinum in terms of airport lounge access. Plat also gets priority pass + Delta lounge + it's own Centurion lounge, the latter the best in the business.
- Amex platinum gets you gold status at rental cars and Hilton's. Basically getting you free upgrades and free breakfast.
- Amex MR points are a bit of more hassle to transfer than UR
- you can get all your AF back in year 1 on Amex, whereas you still have a $50 left over on Reserve card
      08-26-2016, 03:50 PM   #178
Flying Ace
Flying Ace's Avatar
5051
11,907
Originally Posted by BMW F22 View Post
So confused- can we use the digital card for Priority Pass or no? I called Chase Benefits and PP and they said that it's only if you buy direct through PP. Yet others have said that Chase told them we can use PP digital card.
I would contact PP regarding this. Regardless, I think you need to sign up and get your physical PP card first, which in itself is a separate process. Then you may be able to do the digital version, but that's up to PP program rules which you have to follow up with.
I rarely will use any PP lounges, so I decided to just use the card.
      08-26-2016, 03:54 PM   #179
KingOfJericho
KingOfJericho's Avatar
2458
7,341
Drives: Yes
2010 135i Coupe  [5.26]
I haven't seem it mentioned here but the CSR travel credit is MUCH better than the Amex Plat because it doesn't force you to pick one airline and it works for ANYTHING flagged as travel. If I don't hit it before year-end, I'll just charge my December monthly train ticket. It's a no-brainer.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold
      08-26-2016, 03:57 PM   #180
Flying Ace
Flying Ace's Avatar
5051
11,907
yeah agreed, especially for churners, you can get $600 back before you cancel after year 1. That itself covers the AF, everything else on top of it (PP, GE) is just gravy.
      08-26-2016, 04:00 PM   #181
BMW F22
BMW F22's Avatar
3677
9,783
Drives: ///M235i
I called and got the run around. since it's a new program Not everyone has the correct info. I don't care anymore as a CSR rep told me that I can pay for the access and then get reimbursed after so I will do just that in the meantime.
      08-26-2016, 04:02 PM   #182
Flying Ace
Flying Ace's Avatar
5051
11,907
What I'm getting at is, PP is the ultimate authority on this policy. So I wouldn't believe what anyone else tell you. Go directly to the source. Of course, you haven't gotten your CSR card yet, let alone you PP membership (which take a week to recieve and confirm based on my AMEX Plat experience).
      08-26-2016, 04:08 PM   #183
BMW F22
BMW F22's Avatar
3677
9,783
Drives: ///M235i
Yeah for sure. They said 2-3 weeks which would be too late for my plans. The important thing at this point is to get the CSR card so I can put my tires purchase on there. Lol
      08-26-2016, 04:10 PM   #184
Flying Ace
Flying Ace's Avatar
5051
11,907
yeah, sorry! I wish we could share PP, that would be awesome, then I would lend it to you.
I'm betting you're also going to miss the window on GE application too?
      08-26-2016, 04:29 PM   #185
BMW F22
BMW F22's Avatar
3677
9,783
Drives: ///M235i
Yup. Sounds like GE appointments are booked months out. Nothing I can do at this point. I will apply for it when I get the card and use GE for future trips.
      08-26-2016, 09:36 PM   #186
BayMoWe335
1228
2,132
Drives: 2010 E92 335i 6MT
Got it yesterday via UPS.
      08-26-2016, 09:46 PM   #187
BMW F22
BMW F22's Avatar
3677
9,783
Drives: ///M235i
Curious. Did you get a box or a regular envelope? If box, what was the shipping weight of your package? Looks like they are shipping cards to those that were approved on August 23rd and shipping weight is 2 lbs.
      08-26-2016, 10:24 PM   #188
GotNotch
16
Drives: 2016 M235i
Was this expedited shipping?
      08-26-2016, 10:31 PM   #189
BMW F22
BMW F22's Avatar
3677
9,783
Drives: ///M235i
I believe all cards are being sent via expedited shipping. Got my shipment confirmation earlier today and it's with UPS Next Day Saver. Those that applied on August 21/22 got theirs Wednesday/Thursday. Aug 23rd applicants started receiving theirs yesterday, today (or at least got shipping confirmation).
      08-27-2016, 11:34 AM   #190
BayMoWe335
1228
2,132
Yes, but it still took them time since I was approved Monday.
      08-27-2016, 11:46 AM   #191
BMW F22
BMW F22's Avatar
3677
9,783
Drives: ///M235i
Box or envelope?
      08-29-2016, 05:13 PM   #192
ASAP
ASAP's Avatar
11101
9,198
Drives: '23 X3 M40i
So here is a slight profile of me-
Travel across the atlantic every year.
Easily would quality for that 100K points in 3 months.
Do other quarterly traveling within USA.
Want TSA Pre Check
Go out to eat quite a bit...
Is this a card for me?
      08-29-2016, 05:42 PM   #193
T.Stanley
31
192
Drives: 2011 E91 M-Sport - RWD 6MT
Want TSA Pre Check
Short anwer is yes.
ASAP11100.50
      08-29-2016, 05:53 PM   #194
Flying Ace
Flying Ace's Avatar
5051
11,907
Want TSA Pre Check
ASAP11100.50
      08-29-2016, 07:24 PM   #195
BayMoWe335
1228
2,132
Box or envelope?
UPS Next Day envelope.
      08-29-2016, 07:36 PM   #196
BMW F22
BMW F22's Avatar
3677
9,783
Drives: ///M235i
I meant if your card came in a nice box or a regular envelope. Apparently the demand was so high that Chase started sending cards out in those regular mail envelopes instead of the nice boxes that people who applied the first few days received. Crazy demand for this new card.
      08-29-2016, 07:57 PM   #197
BimmerRookie
BimmerRookie's Avatar
471
1,318
Drives: E93 Cavalier Z24 M3
I was expecting a box, but received mine in a UPS envelope
      08-29-2016, 08:18 PM   #198
///F80M3
///F80M3's Avatar
659
1,095
Drives: 16 AW M3
Is it metal like CSP?
2016 M3
Alpine White / Sakhir Orange
BM3 Stage 2 / AWE Exhaust (Non-Res) / VRSF Cat-less Downpipes / CG Precision Valve Control / AFE Drop In Filters / 20% 3M Tint / Blackvue DR650GW-2CH / Escort Redline (Blendmount)
