06-17-2022, 09:49 AM | #89 |
12565
Rep 4,332
LEC confirmed 10 place grid penalty. 4th turbo installed.
///M Power-Belgium73011.50 irunalot1535.00 Killed by Death16774.00 GuidoK14367.00 E92inNC1912.00 M5Rick71690.50 |
06-17-2022, 10:27 AM | #90 |
73012
Rep 27,148
06-17-2022, 10:38 AM | #91 |
73012
Rep 27,148
06-17-2022, 11:02 AM | #92 |
1535
Rep 824
More information on the rule changes, nice to hear some other drivers other than Merc discuss the new cars. For Alonso to say this is the worst in 20 years says a lot.
06-17-2022, 11:39 AM | #93 |
47
Rep 86
06-17-2022, 11:42 AM | #94 |
47
Rep 86
Agreed. Still think they shouldn't have moved the minimum weight.
06-17-2022, 12:00 PM | #95 |
Fleet Mechanic
13536
Rep 1,985
Drives: E86 3.0si
Garage List '19 VW Golf R [10.00]
'55 Ford F100 [0.00] '08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [0.00] '68 Triumph GT6 [9.50] |
I'd like to point out the last two videos you've linked (Driver61 & TheRace) are two of the most correct and unbiased F1 information and opinion producers. I subscribe to both and I'm continually impressed by their even and factual delivery....it's nice to see them posted here.
06-17-2022, 12:09 PM | #96 |
73012
Rep 27,148
06-17-2022, 12:15 PM | #97 |
#buildnotbought
14367
Rep 5,572
...there goes my prediction of him winning....
06-17-2022, 12:25 PM | #98 | |
2827
Rep 4,445
Technical Directive TD039 A metric value is defined as a criterion for the extent of the oscillations. An analysis of how this parameter is determined is ongoing and will continue over the two practice sessions on Friday. The so-called "Az signal" for the vertical acceleration during the up and down movements is transmitted directly to the FIA control unit. Scrutineers can see at any time how hard the car hits the road at high speeds. It is still being discussed how the Az signal should be evaluated, whether peak values or average forces should be taken into account. The teams measuring these values for their own setup analysis are invited to share their methodology with the FIA. The teams still don't know what the rule holders consider an acceptable value. Acceptable value will be determined before 3rd practice. Test: Teams then need to determine the oscillations over three consecutive laps with DRS disabled at race speed. If there is a suspicion that the driver is deliberately driving slowly, the attempt is considered failed. The same applies when you close the gap on another car. Once the FIA has determined a "safe set-up" for each individual vehicle, the ride height, spring rates and damper settings, and aerodynamic configuration may no longer be changed. Exceptions include weather changes, adjustments to cooling needs, tire pressures, front wing adjustment. If a competitor wishes to return to a previously used setup, they must first demonstrate to the FIA that these adjustments meet safety criteria. All parameters such as vehicle height, suspension travel and the aerodynamic configuration must be submitted to the FIA in the voting sheets after the third practice session, together with the corresponding oscillation values. If a competitor is not able to reach the FIA required limits and thus a safe setup, he must use the setup that is closest to the limits and then increase the rear ground clearance by another ten millimeters without changing the suspension travel or the aerodynamic configuration.
06-17-2022, 01:02 PM | #99 |
73012
Rep 27,148
They discovered it Wednesday at Marinello that Charlie's PU was completely lost ..
But Ferrari is still groping in the dark what the cause of the blown PU and Turbo was .. This means that another blue smoke moment can happen at any time !
06-17-2022, 01:15 PM | #100 |
73012
Rep 27,148
06-17-2022, 02:11 PM | #103 |
73012
Rep 27,148
06-17-2022, 02:14 PM | #104 |
1535
Rep 824
06-17-2022, 02:22 PM | #105 | |
1535
Rep 824
06-17-2022, 02:32 PM | #106 |
12565
Rep 4,332
Part of Max's strength is understanding the components of his car. He immediately diagnosed the front roll bar over a curb. I don't think a lot of drivers know their cars as well as he does.
06-17-2022, 02:50 PM | #107 |
73012
Rep 27,148
06-17-2022, 02:53 PM | #108 |
#buildnotbought
14367
Rep 5,572
Where do those beavers come from?
(or whatever kind of critters they are?) I wonder if one will be a deciding factor on sunday....
06-17-2022, 03:06 PM | #109 |
#buildnotbought
14367
Rep 5,572
Longrun from VER looked very good.
He's gonna win. My new prediction: 1.VER 2.PER 3.LEC 4.SAI (rest unchanged)
06-17-2022, 03:09 PM | #110 |
12565
Rep 4,332
///M Power-Belgium73011.50 M5Rick71690.50 |
