07-28-2015, 06:24 AM | #89 |
***** noob
1440
Rep 10,477
Guys forget it
OP is a joke, no matter what facts you have...he write you a bible He probably bet his life on Seattle and had an early celebration..... Then that pass play made him insane
2006 325xi (Sold)
07-28-2015, 05:02 PM | #91 |
2132
Rep 3,553
Im not sure you really countered anything I said, but rather took the Wells approach of, you say one thing, but Im going to just say something else and take that as the gospel.
As to the science, which is the biggest and key thing here that the report basically says science proves that the balls wouldnt have deflated, here are 2 articles to read. And if you say " Well the 4 balls from the Colts that were tested tested at higher psi than the Pats (albeit, 3 still below the 12.5 limit, but no one cares about that right?)," keep in mind that these balls were tested at the end of halftime, after the balls had a chance to warm up in the equipment room. Discusses the differences temperatures make on ball psi https://www.sciencenews.org/blog/cul...y-over-science Discusses why the method used by the Wells Scientist was flawed http://www.foxsports.com/nfl/story/n...d=441003075768 |
07-28-2015, 05:54 PM | #92 | ||
1090
Rep 5,660
I've had some time to try re-thinking about the points above...and I have some questions? Green: Where are the data that show the "near equal" pressure readings as given by the gauges? I just finished looking at the air pressure readings for each Pats' and four Colts' balls, as measured by each gauge I see one ball measured by one gauge whereby the pressure shown for the Pats' ball is similar to any of the pressures measured for any of the Colts' balls. The data I see are in the table titled "Measured pressure (in psig) of footballs, recorded at halftime of AFC Championship Game, January 18, 2015." Blue: What is the "scenario" that is easily "mimicked and exceeded?" I understand what it means to "mimic" a scenario; I don't understand what it means to "exceed" a scenario, although I do understand that quantifiable things can be exceeded. So, before I can re-consider my thinking on the matter, I need you to tell me please what "scenario" it is that has both qualitative and quantitative dimensions such that it can be mimicked and exceeded. Red: The two officials who measured each of the Pats' balls and four of the Colt's balls did use two different gauges. No question about that. My questions are:
In spite of what you may think, I do closely read the posts to which I respond. Occasionally I misconstrue the writer's points, but I (almost) never reply to comments I've not taken the time to read thoroughly. And when I do reply, my replies are thorough and reasonably well thought out, especially considering the venue. I rechecked CSU87's three posts in this thread and I don't see that he has identified any specific statements quoted from the Wells report with which he takes exception. Since you see where CSU87 did "abundantly and clearly" indicate which specific statements, conclusions or premises with which he takes exceptions, kindly please point them out to me. Here are his posts:
Now I don't at all mind that someone not read my posts; they tend to be long; I know that. Plus, they are rarely easy to skim, and that is intentional; I don't want low quality replies. I'm quite okay with having a discussion with one or two folks who are willing to take the time and make the effort to have a comprehensive discussion. All the other folks who don't want to read my post and engage on a comparable level...I have no problem with that. I only ask that if one doesn't thoroughly read my post, don't comment on it. I give everyone else exactly that courtesy and it's all I ask for in return. All the best. P.S. In grad school, I was for a while an English instructor. Many years have passed since then, but even now, I have no trouble telling, based on what they write, that one has read and understood whatever they write about. One need not have been an instructor, to tell, however. Folks who participated in extemporaneous forensics competitions know exactly what I mean. It's patently clear within as little as 30 seconds when a speaker really doesn't fully grasp the topic/content of which s/he must speak.
Cheers,
Tony ------------------------------------------------------------------------------------------ '07, e92 335i, Sparkling Graphite, Coral Leather, Aluminum, 6-speed |
07-28-2015, 05:57 PM | #93 | |
115
Rep 581
that, it turns into professional wrestling ..... cheating is cheating. |
07-28-2015, 06:06 PM | #94 |
2132
Rep 3,553
if we could only be as smart as you.
I may not be an english instructor, but I am a professional bullshitter and its patently clear within as little as 30 seconds when a speaker only accepts their conclusion as absolute and wont accept any other conclusions, and then continues to just throw a ton of extra fluff to cover up that fact. Im not going to go through the Wells report and pull out quotes, because, frankly, i dont care nearly as much as you do apparently. All my posts have been pointed towards the fact that the report does not clearly show any wrongdoing. You bring out little excerpts that fit your theory, but ignore the ones that dont. Doesnt matter anyway, as the case will get overturned in court. The NFL hasnt had the best track record when their suspensions appeals are heard by actual courts, and not Goodell court. And since you like examples, Adrian Peterson, Ray Rice, Jonathan Vilma.... |
07-28-2015, 06:07 PM | #95 | ||
***** noob
1440
Rep 10,477
Is it ok to be caught cheating, abosalutely not ok. I just think its always targeting on New England because they have been so sucessful for over 13 years. These offensive are done by all NFL teams
2006 325xi (Sold)
07-28-2015, 06:18 PM | #96 | |
1090
Rep 5,660
And you see, that's why I have yet to accept your arguments. So far, you've made only unsupported assertions. Well, any fool can do that. You gripe about proof, yet offer no specific examples of proof that supports your claims. Red: I'd suspected as much, but I'd refrained from saying so. I no longer have to wonder what grade of BS-er you are. You've told us all in no uncertain terms. All the best.
Cheers,
07-28-2015, 06:25 PM | #97 | |
115
Rep 581
I don't agree with the targeting of New England. It could have been Dallas and I believe the punishment would be similar with the same evidence because the NFL is protecting the integrity of the game for its brand and fans |
07-28-2015, 06:36 PM | #98 | |
181
Rep 2,210
What Brady did? Did you read imaginary texts? Were you in the bathroom with 'the deflator'? Educate yourself for crying out loud. The fact is the math has been done by a number of universities and scientists that the PSI level of the balls (barely below minimum) were the expected behavior with the climate and timing of tests. |
07-28-2015, 06:40 PM | #99 | |
115
Rep 581
07-28-2015, 06:44 PM | #100 | |
181
Rep 2,210
I still don't understand your point. I could of easily quoted this post as well...
Again, 3 of the 4 Colts balls were also below the legal limit and they KNEW they were going to get tested. Explain that. |
07-28-2015, 06:46 PM | #101 | |
115
Rep 581
07-28-2015, 06:49 PM | #102 | ||
2132
Rep 3,553
I have gone through the report, but as I'm on my phone, copying and pasting isnt practical. Those links there more probable than not, disprove the Wells Report. A true debater uses all available information and not just one item. |
07-28-2015, 06:58 PM | #104 |
***** noob
1440
Rep 10,477
Ok, im not protecting Brady but if balls are deflated...it could also be the RB or a WR that wants them deflated. Im just saying lol
2006 325xi (Sold)
07-28-2015, 07:09 PM | #105 | |
1090
Rep 5,660
Had you bothered to educate yourself on what the Wells report actually says, rather than reading the comments of sports editorialists and parroting them here, you might have a different view? Had you read the report rather than relying on the soundbites you see or hear, you'd know that Exponent used the scientific method to empirically analyze the balls and the gauges. The nature of the questions they addressed include but are not limited to:
I'm not going to list out all the testing they did. I'm not going to explain to you what approaches they used or how they incorporated into their testing the stuff you claim they didn't. If you "educate yourself" by reading the damn report, you too would quite likely be considerably more skeptical about what you've read that various sports editors have written about the impact of temperature and the allegedly overlooked role it played in the 2015 AFC Championship game between the Colts and Pats. All the best.
Cheers,
07-28-2015, 07:13 PM | #106 | |
2132
Rep 3,553
07-28-2015, 08:58 PM | #108 | ||
1090
Rep 5,660
You claim to have read the Wells report. Why are you citing some third party's commentary? Having read the report you should be able to see as plainly as I can that the people you are relying upon have not, could not have read the report. Read the Wells report content I've copied and pasted below. After you've done so you too will realize that these writers on whose opinions you've based your have quite simply been misrepresenting facts to you. I can't say why they are doing so, but I can with no trouble at all see that they have. You will too if you just take the time to read what I've shared below. [PUMA = PUlled it outta My Ass; or in other words, she's gonna be loud and strong, and it don't matter if she's wrong.] Re: the Science News article:
The ranges listed above were based either on weather reports, measurements made by Exponent, or information provided by Paul, Weiss, and represent the lower and upper bounds for the realistic ranges of these factors.
Other: In the meantime, I have to ask you this. Why do you think I have any reason to lie to you or twist facts in any direction other than the direction they most easily want to go, so to speak? I've been very open about the fact that I'm not really even a football fan and that my primary interest in this matter issues from the ethics involved, not who was right or wrong. It doesn't even matter to me who the players in this situation are. What matters to me is that the ethical nature of our culture is such that "stuff" like the alleged events of Deflate gate are even alleged to begin with. What matters to me is that people don't behave with enough integrity to simply present the facts and let them fall where they may. What matters to me, though it's only tangentially related to Deflategate, is that our so-called leaders -- be they elected or appointed, private or public sector, people of action or people who report on and opine about others' actions -- our leaders are more desirous of proving their own point of view rather than simply giving us all the facts and data they have and allowing us to arrive at our own conclusions. And what matters to me is "the public's" willingness to let those so-called leaders do their data collection, data analysis, and conclusive thinking for them rather than doing it on their own and for themselves. That those things are what concern me is not a new theme for me here on B-post. You'll see that in topic after topic, my comments harken to one or more of those very same themes, and/or they demonstrate my faithful adherence to the values -- integrity, candor, objectivity, completeness, etc. -- that I claim just above are generally lacking. You see it in this thread. You'll see it in my "Where Do You Get Your News" thread. You'll see it in my "God and Darwin" thread and in the "Christianity" thread. You'll see it in my "Fake Watches" thread. What you'll also see is that I stay focused. For example, in this thread, you've seen that I refuse to even discuss "Spygate." It has nothing to do with the events and facts pertaining to Deflategate. I stay objective and I don't use the PUMA approach. I have in this thread very clearly said I don't know much about Spygate other than that it happened too far in the past to have any relevance to Deflategate. That I know nothing it is another reason I haven't written about it. You keep harping on the science associated with the ball pressures and temperature. I honestly don't think you read the bulk of the scientific testing that Exponent conducted. I don't think so because of the claims you've made in this thread. I took science classes in school and though I don't know every fact there is in science/physics itself, I know enough to tell just how rigorous Exponent's testing process was and I, just as you could if you'd read their document, can tell whether that process was rigorous enough. So, again I ask you, why do you think it is I who wants to advocate for a disingenuous "truth" or read and interpretation of the facts? I'm biased in some ways. I am biased, prejudiced even, in some regards, but football, Tom Brady, The Patriots, The Colts, and The Wells Report are not among them. In and of themselves, those things/people are meaningless to me. Indeed, the Wells Report's only value to me is that it contains a lot of information about the events of the 2015 AFC Championship game, enough of them that I can read the report for myself and tell whether it's authors and contributors did a fair and high quality job of assessing the situation or whether they did not do that. I don't need a third party writer to tell me what it says, or to interpret it for me, because I've read it. It's not a "hard to read document" and it's not even a long document. Because I've read it, I also know instantly whether a third party writer/commentator is in PUMA mode or not. All the best.
Cheers,
07-28-2015, 10:16 PM | #109 |
2132
Rep 3,553
I'm not looking at the 3rd party analysis, I'm looking at the results from numerous other science organizations that replicated the game conditions and show that their could have been 1.5+ psi loss due to the environment. You ignore this point, and focus on something that i never brought up.
You keep with your opinion that i did not read the report despite me saying the opposite; similar to what Wells did when given explanations that contradicted his hypothesis. Why would i lie about this? Anyways, i see you're from DC, and like most people in DC, you are firm in your opinion and won't listen to anything that doesn't support it. No sense discussing it further, since after this season when they actually will test balls in game conditions, we will see that balls indeed lose pressure through the game. Also, deflated balls obviously don't gain a competitive advantage since the Pats destroyed the Colts in the 2nd half after a relatively close 1st half. |
07-28-2015, 11:00 PM | #110 |
What goes here?
462
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Hahahahahaha Brady cheated and is sitting out 4 games. Sucks to cheat.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
