12-07-2021, 12:07 PM | #881 | ||
![]() ![]() ![]() ![]() 551
Rep 446
Drives: 01' E46 325i / 16' F80 M3
Bartledoo2698.50 |
12-07-2021, 12:14 PM | #882 | |
![]() ![]() 1086
Rep 334
deleted_397282_c43ae5ea84151.00 Bartledoo2698.50 |
12-07-2021, 12:40 PM | #883 | ||
#buildnotbought
14885
Rep 5,637
Also, the supposedly "speeding up before the brake check" doesn't show on the multiple video feeds. Because from your points highlighted on the graph, that speeding up would have been from 100 to 200kph; which would either mean a doubling of the revs or shifting up 1 or 2 times. Both dont happen as can be seen in the video feeds. Also that "speeding up before the brake check" would have happened over a stretch over 100M. Not seen on video. The crash happened at 5300m.
12-07-2021, 01:01 PM | #884 |
![]() 1681
Rep 2,038
Honestly you couldn’t make it up, the entire rest of the field said that the move in Brazil shouldn’t have been allowed and should have been sanctioned but nope the FIA and the stewards left it even post race.
Today we get the interview below. Basically he did drive Lewis off the circuit in Brazil and it was fine, I did the same in Jeddah and I get punished what gives. Sorry didn’t we all say it wasn’t clear, so basically both moves should have been punished. Ah well onto the final chapter of the season. https://www.motorsport.com/f1/news/v...razil/6858307/ |
3798j13979.00 |
12-07-2021, 02:16 PM | #885 | |
![]() ![]() 3459
Rep 3,422
For anyone who hasn't moved on to Abu Dhabi, the reason it matters is it shows VER's braking pre-impact wasn't particularly heavy. Not really out of line with the entire decel, and certainly not unavoidable by a trailing driver leaving margin for error. When an F1 car hammers the brakes it creates cliffs in telemetry speed data. Compare the following to the speed trace pre-impact on the Jeddah chart ![]()
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
GuidoK14884.50 |
12-07-2021, 02:31 PM | #886 | |
#buildnotbought
14885
Rep 5,637
But that doesn't say much. I mean, you can slow down from 101kph to 100kph with 10g, or a 100g if the car allows, but you'll still be only slowing down from 101 to 100kph, you're just doing it really fast. If you cant dodge that, you're clearly too close to the other car ![]() It is the amount of speed that you slow down abruptly, and that that significantly happened (a proper brake check is at least? 25kph? slowing down?) doesn't really show from both the data and the video footage.
M5Rick73140.50 ///M Power-Belgium74116.50 |
12-07-2021, 02:33 PM | #887 |
![]() ![]() ![]() 8200
Rep 8,202
I'm highlighting your over use of the term balls, and you referring to it like it's the most important trait a driver can have, and max is superior to Hamilton because he is "ballsy". Well it's not the case, being smart and calculated is more important/valuable than trying to push the envelope to be the fastest at all times. This is why max hasn't been able to wrap up the championship yet, because when you're always on edge mistakes happen - shunted in Silverstone and messed up this last qualifying.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
12-07-2021, 02:38 PM | #888 | |
Rep 8,202
Everyone else gets blue flagged when theyre lapped, keep fighting that and you get a nice drive through.
12-07-2021, 04:09 PM | #889 | |
![]() ![]() ![]() ![]() 73141
Rep 23,160
12-07-2021, 04:24 PM | #890 |
Rep 8,202
Max had all early season to be calculated when the RB was significantly faster than the merc, if he had done so at silverstone the championship would be over. But he wanted to be "ballsy" and never give an inch, and thus got shunted and dnf'ed. If he had decided to live another day and backed off the story would be over now.
SenorFunkyPants2551.50 |
12-07-2021, 05:09 PM | #891 |
Fleet Mechanic
13979
Rep 2,015
Drives: E86 3.0si
Garage List '19 VW Golf R [10.00]
'55 Ford F100 [0.00] '08 Z4 3.0SI [8.50] '66 Triumph TR4A [0.00] '85 Corvette [0.00] '64 Corvette [10.00] '68 Triumph GT6 [9.50] |
This tweet impressed...Not my words (but I'm so aligned with the thought):
"Verstappen is the embodiment of how not to be a sportsman." |
12-08-2021, 01:49 AM | #892 | |
Rep 23,160
12-08-2021, 02:13 AM | #893 | |
Rep 8,202
Second in response to "back off for what", this is where race iq and maturity comes into play, in the term live to fight another day. Max should have realized he was ahead by alot in the championship so he has more to lose, thus he should have played it safe and back off to avoid any damage. But Max lacks the maturity to do so and wants to fight every single second even when it is not beneficial or wise to do so, as shown by him battling a back marker in Ocon at the end of the race for literally no reason at all.
Steeler2468.50 deleted_397282_c43ae5ea84151.00 |
12-08-2021, 02:23 AM | #894 |
Rep 23,160
So, we have here the moments Mercafia did not investigate.
https://www.gpblog.com/en/news/10066...ink=inarticle1 |
///M Power-Belgium74116.50 GuidoK14884.50 |
12-08-2021, 02:26 AM | #895 |
Rep 23,160
More Mercafia confusion.
12-08-2021, 03:04 AM | #896 | |
Rep 23,160
If Max listened to some of the advice on here then he'd only have half the points he has now at this stage, what you fail to take on board f87 is that you cannot change a persons character and remember where the rest are...nowhere. |
12-08-2021, 03:41 AM | #897 | |
![]() 1681
Rep 2,038
Max on the other hand has been in more bad and dangerous situations this year than ever before. Maybe the team have given him unrealistic expectations on him that has applied pressure that makes the bad judgements. Look at when he tagged Ocon in Brazil years ago as a back marker. He had lots to lose but his brain wouldn't let him, but to be the best it needs to. To win you have to finish, you can be amazing but if you don't cross the line it doesn't matter a jot. Max could have won now if he had backed out of the Silverstone incident, exactly as Leclerc did in an IDENTICAL overtake but he didn't. So we go into the final race, nobody quite clear what is or isn't allowed but its quite clear Max will try anything under the son to do 'Whatever it take regardless of the rules to win'. And that is why many love him but also why neutrals and fans of other drives think he doesn't deserve to be winner because of the way he drives. |
Steeler2468.50 |
12-08-2021, 03:55 AM | #898 | |
Rep 23,160
12-08-2021, 04:09 AM | #899 | |
![]() ![]() 1086
Rep 334
12-08-2021, 04:19 AM | #900 | |
Rep 23,160
Outgoing AR driver Kimi has said that F1 is now too political with Alonso backing that up confirming other drivers other than ham are treated differently by the gov body. |
12-08-2021, 04:28 AM | #901 | |
![]() ![]() 1086
Rep 334
12-08-2021, 04:50 AM | #902 |
Rep 23,160
