09-17-2019, 03:55 PM | #859 | |
![]() 832
Rep 1,596
N54Yankee2705.00 |
09-17-2019, 04:10 PM | #860 |
![]() ![]() ![]() 10787
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
If you think that the mid-engine Corvette is a new idea, think again. It’s been 60 years in the making.
The idea of a mid-engined Corvette is not new. In fact, it was 60 years ago this year when the first functioning prototype based on that very idea was put together. Known as 1959 CERV I (Chevrolet Engineering Research Vehicle), this open-wheel single-seater rocket was the brainchild of Zora Arkus-Duntov, a Belgian engineer of Russian descent who joined Chevrolet in 1953, just after the birth of the first Corvette. https://www.motor1.com/features/3603...gine-corvette/
09-17-2019, 04:13 PM | #861 |
![]() ![]() 2705
Rep 1,916
Hack- Chevrolet and Corvette doesn’t boast Times at the Ring that aren’t official. Mule runs there to polish the cars that come off the line at Bowling Green not to brag before a production car runs it. I can’t remember a Corvette test car with a published Ring time.
Car makes are always making their cars better, it’s warfare and you need to keep evolving to stay ahead. Stagnancy breeds losers. Don’t know what Meros motivation was for making such comments but maybe his departure wasn’t as amicable as we were led to believe, regardless. The C7 Z51 Ring run(Mero driving) was never published because the new Carrera S beat it by a second and Chevy didn’t want that out there. Mero wanted it made public by Chevy declined. 0-60 they published but the car still isn’t finalized yet and I’m sure they’re still tinkering with things to shave Times and other perf numbers besides, every car maker lets out a little info at a time to keep the buzz going. No surprise there. I don’t think I’m going out on a limb saying that the new Z51 will do a good deal better then the C7 Z51 at the Ring I’m confident that the 8 will easily undercut the C7 Z51 7:39 by at least double the 5 sec you think maybe even quadruple. Mid engine shows it’s prowess in turns and the Ring has a whole bunch of them. The new cars lower center of gravity, Cd, stiffer chassis, better down force, likely better brakes, more power and likely at a higher rpm due to those beautiful Longtube headers as opposed to cast manifolds. I think this car is going to be a stunner on tracks. Corvette has been about performance for most of its life and I think it’s still the primary concern and especially now that they’re throwing the gauntlet down with the mid. Sure selling more cars is always a concern, it is a business after all. I wager that when we look back at the end of C8 lifespan at the track the cars from Z51,Z06, ZR1, Zora or whatever else they put out will all have numbers better then many of cars in their fighting weight classes and they’ll sell lots of them in the process be it old, middle age or young while taking many checked flags. That’s the way it should be.
"The Constitution was never construed to authorize Congress to infringe the just liberty of the press, or the rights of conscience; or to prevent the people of the United States, who are peaceable citizens, from keeping their own arms.” Samuel Adams Last edited by N54Yankee; 09-17-2019 at 04:19 PM.. |
09-17-2019, 04:22 PM | #862 | |
Midlife Crises Racing Silent but Deadly Class
1834
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
What took longer for me to get used to is the way the throttle responds and how torque is delivered, but that's no fault of GM or Corvette engineering team. The torque surges instantaneously and down low. It's great for acceleration, but horrible for fine control in corners. I need to relearn how to drive as evident by my sh*tty driving. This happened 2 laps in a row. It's hard to finesse 460 ft-lbs of torque that comes on at less than 2,000 RPM. I get so used to the bulk of the torque not being available until 4,000 RPM that I'm having a hard time wrapping my head around how quickly the back-end can come out. That's not going to change with mid engine. The back-end actually rotates quicker and easier with a mid engine design, because more of the weight is centered around the center of gravity rather than at each end of the car. A mid engine car will allow for easier and BETTER control of the slide, so you won't be tank slapping the car across half the turn, but a better driver it will not make you, in fact, if you don't know what you're doing, a mid rear engine, rear drive will bite you faster than a front engine, rear drive. But GM's stability control system is off the charts good. Yes I tend to drive without it on track, and anyone getting the C8 for track use, I'd recommend leaving at least some semblance of performance traction management on for track use.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
Red Bread4353.50 |
09-17-2019, 04:27 PM | #863 | |
1834
Rep 5,337
As for the old "older people are the ones that can afford Corvette" argument, that doesn't explain WHY Porsche 911, Cayman and Boxster demographic is 12-20 years YOUNGER, because both of those cars cost MORE than your typical Corvette. ![]() Corvette does not need to attract 20 year olds. They need to attract 35-40 year olds that are SUCCESSFUL. At least in a large enough percentage that these guys can and will be buying Corvettes in the next 20-30 years.
Viffermike1832.50 |
09-17-2019, 04:32 PM | #864 | |
1834
Rep 5,337
![]() Just in that statement alone, you confirmed my suspicion. There's actually no hard rules in place that says GM does not publish mule times. If the C8 base mule breaks the 7:20 of the Z06, you bet GM would be out there shouting it from the mountain top. GM refused to publish the C7 Z51 Ring run BECAUSE PORSCHE BEAT IT. That's how marketing works. Someone already stole your thunder. You think GM won't find a way to "leak" the C8 ring time if it's as speculated significantly faster than the C7 Z51 or Grand Sport times? ![]() Yes, I am just guessing, but I am also a life long marketing executive with experience in the Automotive Aftermarket (no not automotive manufacturing). I know how this works. I still think that those other performance figures are not published or leaked by GM because they weren't the paradigm shift we all thought it would be.
09-17-2019, 04:43 PM | #865 | |
1834
Rep 5,337
You may very well be right. It's a car that no one outside of GM has access to, and those that do, have a press embargo put on, so we won't really know unless third party instrumentation is done. And at the end of the day, I would actually be HAPPY if I am proven wrong, as I have been proven wrong before on a wide variety of topics. What I will say is this. I love bench racing as much as the next guy. And this "discussion" is healthy. But I'm not a betting man, so I won't take you up on your wager. But my gut tells me it's a lot of smoke and mirrors still.
09-17-2019, 04:55 PM | #866 | |
![]() ![]() 2705
Rep 1,916
The Carrera S beating the C7 was an official Corvette run time, it’s the first time I’ve heard of that the company declined to put it on the big board, I don’t recall another time that was done by Corvette, do you? I’m all ears. I think you’re really jumping the gun here thinking that they already have these performance numbers locked down already. Even during the unveiling they locked the engine compartment down because the construction wasn’t even completed and didn’t want the press to get pics. You give them to much credit to get stuff done fast like a NASCAR pit crew, don’t even be surprised if there’s a delay in the roll off. I’m guessing here also and I’m confident that this car will far surpass your low set bar. We won’t have too long to wait, if there’s no holdups that is. I’m going to say here for posterity it will be at least 15 sec quicker around the Ring faster then the Z51 C7. Official C8 time vs the C7’s 7:39 that is. Just saw your second post so I’ll just tack it on here. I recall you stating another day why go with the mid because the C7 did so well against the completion with the front engine. You’re right it did and beat cars a lot more expensive then it was. So did the C6 variants. Why are you so skeptical when the past 19 years the company demonstrated they know what they’re doing to compete very well and surprise many in the game? The proof is in the pudding and on the track timer.
"The Constitution was never construed to authorize Congress to infringe the just liberty of the press, or the rights of conscience; or to prevent the people of the United States, who are peaceable citizens, from keeping their own arms.” Samuel Adams Last edited by N54Yankee; 09-17-2019 at 05:02 PM.. |
09-17-2019, 05:15 PM | #867 | |
1834
Rep 5,337
The part we provided to them had to go into those mules for their 100,000 mile testing. The production specifications were locked down more than 12 months before the first part was shipped to the tier 3 supplier for assembly. Unlike product development for a chair or a toaster, car manufacturers (at least the big ones) have specs locked down years before the vehicle start rolling down the production line. Product planning happen 5-7 years in advance and when you see camouflaged mules on the road, they're not testing for performance or tune or numbers, they're testing for mandatory miles and regulatory requirements. *NOTE: The part we developed isn't vital to the car's operation, as evident by not being even involved directly but through a tier 3 supplier. Originally we were suppose to supply the part and assembly directly, but by regulatory standards we had to be qualified into one of the tier structures and it would have been cost prohibitive for us for the certification process. But that's neither here nor there and not important to the discussion. Like I said, based on my experience, I am confident and comfortable saying that GM absolutely knows what all the performance data lies with the C8. What they chose to publish and NOT publish can be parsed 1,000 ways.
Viffermike1832.50 |
09-17-2019, 06:02 PM | #868 | |
![]() 740
Rep 1,087
lols murphy's law strikes again ... |
09-18-2019, 09:16 AM | #869 | |
![]() 1798
Rep 973
I didn't realize this part flew so far over your head you had to turn to ranting and ad hominems. Step outside, I think there are some clouds you can yell at. |
09-18-2019, 05:59 PM | #871 |
![]() 740
Rep 1,087
09-18-2019, 06:15 PM | #872 |
![]() ![]() 2705
Rep 1,916
In a game where tenths of a second matter it’s very important.
"The Constitution was never construed to authorize Congress to infringe the just liberty of the press, or the rights of conscience; or to prevent the people of the United States, who are peaceable citizens, from keeping their own arms.” Samuel Adams |
09-19-2019, 01:17 AM | #873 |
![]() 1867
Rep 1,340
Pretty excited about this car. It’ll bring everyone else down a notch. Unfortunately, with how affordable the C8 is supposed to be, it’ll fall into the hands of many noob drivers and will likely contend with the mustang for record crowd plowings per year.
09-19-2019, 02:37 AM | #874 |
![]() 740
Rep 1,087
The C8 is NOT affordable. Including insurance, very few people can afford it. As for "crowd plowings", it's no different from those likes Lambo, Ferrari, M4 ...
09-19-2019, 05:18 AM | #875 |
![]() 832
Rep 1,596
C8 is not a mustang.
FuriouslyFast860.00 |
09-19-2019, 09:03 AM | #876 | |
![]() 860
Rep 407
Drives: Miss Daisy
But yes, most people cannot buy a $60-70k car |
09-19-2019, 09:25 AM | #877 |
![]() 17
Rep 91
imagine writing this and not being self aware. Oh no, Its going to be attainable by plebs!
09-19-2019, 10:32 AM | #878 | |
![]() 1798
Rep 973
As for insurance costs, you can't really compare them. Age, record, credit, ZIP code, miles driven, etc, etc. Home and car insurance in Oklahoma is stupid expensive because of all the wind/hail damage we get. |
09-19-2019, 10:34 AM | #879 |
Emperor
1624
Rep 2,720
Plastic body panels (every corvette) don't suffer the hail damage-- should help with insurance rates
![]() 2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
09-19-2019, 10:37 AM | #880 | ||||
![]() 1112
Rep 264
In 3 years auto trader will be littered with these thing for around $30,000, just like it is with C7s The C8 will absolutely put a new level of performance in the hands of people who have never had it before. Handling in a mid-engine car is a bit more tricky at the limit, the limits are very high, so you have to be doing something very stupid to get there, but once you are there things can go very wrong very fast. |
