      10-12-2007, 02:39 PM   #67
321
Stay a while and listen...
22
375
Drives: vr4
Any DTL % figure is going to be inaccurate unless you dyno on a engine dyno and a chassis dyno. If its ~235whp w/ the sti and >270whp w/ the 135i then the Sti won't fare very well.
      10-12-2007, 02:44 PM   #68
Propagator
14
810
Drives: 2011 328i LMB 6MT
Originally Posted by MrRoboto View Post
Is the current STI around 21% DTL? I thought I read that over on NASIOC. That should put the stock WHP at ~235.
I highly doubt that anyone in NASIOC, or any other car forums, knows the DTL down to a couple of percent like that. You don't know what your crank HP has to be since there's a quite a bit of fluctuation from the factory, and then of course dyno numbers are meaningful only as a relative indicator when compared very carefully. The matter gets even worse when you start comparing RWD cars to AWD cars, since they can never even use the same dyno. Also, DTL probably is a function of RPM as well.
The only way to really know DTL is to take out the engine, measure the crank output, put it back in, and use the exact same calibration to measure the wheel HP under the exact same condition.
Sorry, I know I'm repeating things that most of us already know, but I think DTL is one of the less scientific subjects that people talk about in car forums.
      10-12-2007, 02:51 PM   #69
321
22
375
Drives: vr4
You can start a whole forum on this subject! This gets debated to the death!
(i agree w/ you) *flame suit activated*
True! However we can say with some semblance of accuracy that AWD will have more DTL than RWD
      10-12-2007, 03:23 PM   #70
9600baud
77
Drives: Feet
Its starting to grow on me... the red-out tails with a a mean rear skirt can make up for its visual shortcomings.
      10-12-2007, 03:25 PM   #71
ducati
11
394
Drives:
Originally Posted by MPower View Post
I should add an addendum to my statement: "and without turning it into nothing buy a metal box." Clearly, the obvious solution is to remove every seat but the driver's, remove all the sound deadening material, remove the AC, etc. That probably wont cost you much but all you will have then is something closer to a race car than a real road car. This is what I meant when I originally posted "ruining driveablility".
I knew that's how you'd take it, and honestly, to the extent he's done it... I agree. I mean, no rad fans? The car would be toast here.
But if you critically look at his list, you can see a LOT of weight can be removed without sacrificing comfort or driveability at all. For instance, in the trunk:
Run low intercooler sprayer fluid - about 8 lbs (used to cool IC + spray the windshield)
Spare tire - 30.25 lbs
Spare tire bolt and cap - 0.25 lbs
Spare tire cover - 4.0 lbs
Jack extension handle located under spare tire cover - 0.75 lbs
Jack - 4.0 lbs
Tools w/ carry case - 1.5 lbs
All trunk trim - about 4 lbs
Spare tire rubber pads - 0.25 lbs
Trunk springs - 2.0 lbs
That's 55 pounds. Add a can of fix-a-flat (.25) and a AAA card (.0001lb) and you have no downsides, really.
Really honestly take a look at that list. There's some interesting stuff in there.
But I agree: you can go too far.
      10-12-2007, 03:28 PM   #72
BForbes
Moderator
BForbes's Avatar
Bahamas
600
4,240
Drives: BSM 135i/AW E90 M3
Thank you Ducati for explaining to MPower that its not that hard to shed some weight.
- 04 Honda S2000(gone)
      10-12-2007, 03:29 PM   #73
BForbes
Moderator
BForbes's Avatar
Bahamas
600
4,240
I cant wait see those 3 cars stock for stock going at it.
      10-12-2007, 03:31 PM   #74
ichiban
ichiban's Avatar
107
2,012
Drives: 08 135i
Stock 06 STis are putting down around 220 awhp on the GST dyno.
      10-12-2007, 05:03 PM   #75
imported_MPower
Zoom Zoom
38
1,069
Drives: 2022 M3 6MT
I dont see how you are going to get 150 pounds off of the car without removing something of practical use, especially if the 135i does not come with a spare wheel and tire. But like I said, I've got a 20 dollar note on my fridge that says you wont be able to do it with reasonable terms. We'll just have to see.
Diminishing returns, my friend. The first 50 pounds are going to be a lot easier to remove than the last 50.
In the garage: 2022 G80 M3 Manual - Portimao Blue
      10-12-2007, 07:37 PM   #76
ducati
11
394
Drives:
Alright, let's get another 100 in the STI. Piece of cake:
Deka ETX9 battery - 25.0 lbs (7.0 va. 32.0)
Hood liner - 1.0 lb
Front bumper cover unnecessary mounting brackets - about 2 lbs
R driver side floor mat holder - 0.25 lbs
Driveshaft protection plate - 4.0 lbs
Muffler heat shield - 1.0 lb
Spec C trunk - 11.75 lbs
Front brake dust sheilds - 2.0 lbs (1.0 lbs per side)
Rear brake dust shields - 1.5 lbs (0.75 lbs per side)
Kosei 17x9 ET 45mm w/ Michelin Pilot Sport Cup 245/40/17 tires - 28.0 lbs
Run a maximum of 35 L gas at a time- about 40 lbs
There ya go, 116.5 lbs. I picked stuff completely at random, things that really wouldn't affect "practical use" as you put it. I even specced in a Spec C trunk, which gets rid of the much-derided wing, and some easier-to-clean rims with WIDER THAN STOCK tires (go skinnier for less weight!). There are many more things in his list that don't affect "practical use," go look for yourself.
There is a breaking point, of course, but 150 lbs. 'aint it. I'd like a case of Augustiner, please, $20 is virtually worthless nowadays.
      10-12-2007, 09:42 PM   #77
BForbes
Moderator
BForbes's Avatar
Bahamas
600
4,240
Hood liner - 1.0 lb
Haha, i love it! Mpower still dosent get it. But its okay as he's not going to be driving my lighter un-drivable 135i.
      10-12-2007, 10:00 PM   #78
imported_MPower
Zoom Zoom
38
1,069
Drives: 2022 M3 6MT
Ive seen the list you are copying this stuff from. I agree, its impressive. But for much less, I can get much better overall performance by not worrying my ass off about the weight of the floor mat holder. That's where the comment about price originated from. Just with the cost of wheels, I can buy parts that will equate to much, much more performance.
If you want an Elise, buy an Elise.
Oh, and you have to do it for the 135i (though, technically, you still havent done if for the STi). And it's going to have to be a 20 dollar bill for now... I dont think I can stick a case of beer to the side of my fridge...
      10-12-2007, 10:24 PM   #79
Deutsch
52
249
Drives:
You don't have to be a jerk to get your point across man. Learn that not everyone has the same point of view as you do and get over it.
      10-12-2007, 10:44 PM   #80
imported_MPower
Zoom Zoom
38
1,069
Drives: 2022 M3 6MT
Because I disagree I am being a jerk? If you think I am being a jerk, I apologize. I am not trying to be. I am only disagreeing.
      10-13-2007, 03:10 AM   #81
ichiban
ichiban's Avatar
107
2,012
Drives: 08 135i
everyone has their own views. Some people enjoy being able to own a ligthened version of their car. With the Elise, the car is very unpractical. And to the 1er, the daily driving abilities are incomparable. The truth is, most light weight cars (miata, s2k, elise to name a few) are very cramped cars and 2 seaters. There is also the fact that some people like to work on their cars, and like to make their cars one of a kind.
      10-13-2007, 05:47 AM   #82
321
22
375
Drives: vr4
I CAN! (the trick is you drink the beer first!)
      10-13-2007, 08:33 AM   #83
ducati
11
394
Drives:
How do you know I haven't done it to my STI?
I don't think you're being a jerk, it's been fun to banter back and forth. You're right, the 135 is an unknown. With BMWs penchant for over-engineering things, though, I'm sure 150lbs. will be found by onehots2k.
      10-13-2007, 09:47 AM   #84
imported_MPower
Zoom Zoom
38
1,069
Drives: 2022 M3 6MT
Right now you are at 116.8 pounds... clearly, you could get to 150 as that list is very impressive. Now, are you saying that you have done these things to your STi?
      10-13-2007, 10:44 AM   #85
BForbes
Moderator
BForbes's Avatar
Bahamas
600
4,240
Exactly! I didnt fall off my chair and think about this yesterday. This has been in my head for months now and I've been on every bimmerforum looking at safe inexpensive ways its been done.
      10-13-2007, 11:32 AM   #86
ducati
11
394
Drives:
Actually, add the first 55 lbs. to the 116.5 and you're at 171.5. Well beyond the 150lbs. target. :wink:
Yes, my STI is on a weight loss program. I will be doing some things differently than the above list, as I personally want to run a full tank of gas. Sound deadening will be removed, for instance. My interior will look full stock, but I'll lose weight as I see fit. Not sure where I'll end up.
      10-13-2007, 12:00 PM   #87
imported_MPower
Zoom Zoom
38
1,069
Drives: 2022 M3 6MT
Personally, I couldnt tolerate that. My Miata had next to none sound deadening and it made for a long highway journey. But, as they say, that is me...
      10-13-2007, 03:02 PM   #88
ducati
11
394
Drives:
I owned an Acura Integra Type R (sound deadening removed from the factory) for about 2 years, drove it on some really long trips, and it wasn't that big of a deal. I thought I wanted something more "civilized" and "mature" and sold the thing for a Lexus. I've missed it ever since.
No biggie for me, as I love the sound of the mechanical marvels we drive.
Now I won't do an aftermarket (read: loud) exhaust with no sound deadening. That's my breaking point for a daily ride. So we all have limits
