      02-22-2024, 07:37 PM   #7305
Donatello.
How's My Driving?
Donatello.'s Avatar
1289
1,123
Drives: Hellcat & Miata
Originally Posted by bagekko View Post
I finally shot my Shield Plus I dropped the gold faxon threaded barrel into long ago, it ran great no issues.
Mine ran great w/the Faxon too. I need to be a better shot with this thing. I almost blamed the barrel till I put my can on it & the bullets magically went where I wanted LOL
      02-26-2024, 11:29 AM   #7306
andrewmr
529
322
Drives: 2020 M4
Anyone here have any Canik products?
Any opinions?
Looking at the TTI Combat due for release next month.
      02-26-2024, 12:18 PM   #7307
Shiza
Shiza's Avatar
1207
1,002
Drives: M3, X5, Ram 2500, Wrangler
Any opinions?
I have a TP9sfx, it's a tack driver. Fit and finish is great. Polished feed ramp from the factory. Mine has been very reliable but I've heard of ppl with issues so YMMV.
      02-26-2024, 12:25 PM   #7308
Donatello.
How's My Driving?
Donatello.'s Avatar
1289
1,123
Any opinions?
I've owned many. No issues other than they wouldn't run reliably in stock form with a can
2018 Charger Hellcat
2019 Miata 30th Anniversary
2021 CX-5 Signature
2009 Mazda6
      03-11-2024, 04:50 PM   #7309
Donatello.
How's My Driving?
Donatello.'s Avatar
1289
1,123
So much for building a lighter AR....
My goal was to be under 6 lbs with optic (PA 5x micro prism w/PA mini reflex red dot).
Without any accessories or optics (But with stock installed) it is 5.7 lbs
PA advertises the 5x & 3x micro prisms as weighin 8 oz. No way in hell.... (Put the optic setup on the scale & 1 lb!) I may as well just go back to an LPVO smh...After I added the optic setup listed above, the Centurion hand stop & rail covers & VTAC 2 pt sling, the weight shot up to 7.1 lbs!!!!
After I added the Surefire SOCOM MINI2 can, we are at 7.9 lbs.....
I know I can shave a few more ounces by going with the MFT stock, PSA BCG, lighter FH & a lighter buffer setup. However, I went with this FH because of the SOCOM MINI2 and the buffer setup because it will be suppressed full time.
Full parts list below.
Ruger stripped lower
B5 Type 23 grip
Geissele ambi safety
Stag LPK
V7 takedown pins, grip screw, ejection port cover & rod & end plate & castle nut
Centurion 14.5" lightweight hammer forged barrel
Magpul enhanced trigger guard
Toolcraft BCG
Warhammer CH
B5 Bravo stock
Centurion rail covers & hand stop
Odin works extended mag release
CMMG Zeroed bolt catch
Larue MBT-2S trigger
2A Armament upper receiver
2A builder series buffer tube
Midwest micro gas block
Centurion gas tube
Strike FA
Geissele Super 42 H2 buffer & spring
Midwest 12.6" Ultralight handguard
Surefire closed tine FH/suppressor adapter
2021 CX-5 Signature
2009 Mazda6
Torgus3806.50
chowser512132.50
      03-12-2024, 07:45 AM   #7310
chowser51
chowser51's Avatar
2133
2,885
Drives: F33 430 and F39 M35i
Wonder if just the optic without the mount weighs 8oz?
That's kind of shady to list it without the mount weight.
      03-12-2024, 12:16 PM   #7311
GLU_WEIN
GLU_WEIN's Avatar
373
606
Drives: 2018 M5 / 2011 X5 35d
It would be an awesome project to restore those stocks.
Originally Posted by nosbocaj View Post
Any K98k collectors on here? I went down the rabbit hole a few years ago and was luckily able to pull myself out. K98k collecting is both extremely expensive and very difficult as the market is riddled with fakes. Finding a period correct, 100% matching and legitimate rifle is a painstaking process. I was lucky to find these two, which I'll never shoot and will likely keep for as long as I can. Even 80 years later, the quality of German craftsmanship is evident all over these rifles.
Top: 1942 byf 42 hh block with a rare walnut stock. Most of these were lost to the Eastern Front, so finding one is a tough ask, even more so in walnut (production had mostly switched to laminate due to cost and durability).
Bottom: 1940 42 code dd block with a red glue laminate stock. This is a duffle cut GI bring back. In order to fit their rifles in their duffle bags, a cut was made on the handguard. This one has been professionally repaired luckily.
      03-12-2024, 12:17 PM   #7312
GLU_WEIN
GLU_WEIN's Avatar
373
606
Shot my buddy's Canik last year and it was surprisingly a great gun, the trigger was light and smooth.
Any opinions?
      03-12-2024, 01:25 PM   #7313
nosbocaj
nosbocaj's Avatar
783
488
Drives: 2023 M3 Competition xDrive
Aesthetically, I agree. However, that would actually destroy their value (by at least 50%, maybe more) and effectively ruin the rifles from a collectors point of view. The Germans marked every piece of their rifles with Waffenamts (you can see them on mine if you look closely). Refinishing the stocks would likely remove those stamps. With regards to collecting German made K98k's, value increases due to 1. rarity 2. percentage of serial matching components that are also "original" and period correct. Mine are both 100% matching and correct down to the smallest screw, which will have it's own individual marking or serial number. If you're interested in learning more, this is the best resource out there for collecting: https://www.k98kforum.com/
Long story short, the Germans built their rifles with extreme precision and detail. You can see why they couldn't keep up production, especially compared to the U.S. that could make a Garand for a fraction of the cost and time.
Current: 2023 IOMG M3Cx
Past: 2018 AW M2, 2010 AW M3
M2 LCI European Delivery
      03-12-2024, 06:57 PM   #7314
Donatello.
How's My Driving?
Donatello.'s Avatar
1289
1,123
I emailed PA & that is what they told me. Shady indeed. Just list total weight or weight of optic & weight of mount.
I have an ADM mount on order as well as a lighter BCG. SHould shave 7 or so oz off. We shall see!
      03-12-2024, 06:58 PM   #7315
Donatello.
How's My Driving?
Donatello.'s Avatar
1289
1,123
All of my Caniks have had great triggers. Especially my Rival S Chrome
      03-13-2024, 12:20 PM   #7316
Torgus
Slow.
Torgus's Avatar
3807
7,161
Drives: N54 6466 100% E85 + Meth
2007 BMW E92  [10.00]
2007 BMW E90  [0.00]
2006 BMW E91  [0.00]
Just grabbed one of these: https://www.primaryweapons.com/mk109...-upper-300blk/
Now its time to blow a grand on optics.
      03-14-2024, 09:21 AM   #7317
unluky
unluky's Avatar
7698
1,264
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
Finished my night hunter project. No blood on it yet, but it's finally ready for action. 2 weeks left in my states legal night coyote hunting season too.
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
Appreciate 6
Torgus3806.50
jmack548.50
Nuckle2282.00
Donatello.1289.00
      03-16-2024, 09:16 PM   #7318
Donatello.
How's My Driving?
Donatello.'s Avatar
1289
1,123
Now I have the itch for another optic & suppressor ready 9mm pistol after picking up a M&P 2.0 4" compact. Don't want any heavy pistols or DA/SA. No manual safety
2021 CX-5 Signature
2009 Mazda6
      03-16-2024, 11:33 PM   #7319
Donut Lord
Do Donuts
Donut Lord's Avatar
453
317
Drives: '12 BMW E92 M3
Any RPR owners?
- 6mm CM
- Vortex PST 6-24X50 FFP
Is that you? or did you really get your wife to model your gun? lol
      03-17-2024, 07:57 AM   #7320
GLU_WEIN
GLU_WEIN's Avatar
373
606
Wife modeliing.. but she might as well be a part of the bimmerpost fam
      03-18-2024, 01:38 AM   #7321
ShapeShifter
ShapeShifter's Avatar
753
78
Drives: 2024 M440ix GC
PISTOLS:
Colt New Frontier Buntline .22LR/.22 WMR Case Hardened Steel Frame 7 1/2" Barrel
Colt 1911 WWI Government Model .45 ACP ( Production Year (1918)
Smith & Wesson 5904 Semi-Auto 9mm 4" Barrel
Kimber Pro Crimson Carry II .45 ACP 4" Barrel
ATI GFX9GI FX9 Firepower Xtreme 9mm 4.25" Barrel
Dan Wesson Valkyrie CCO 9mm 01965 4.25" Barrel
Dan Wesson Vigil 38 Super CCO (Special Order) 01837A 4.25"
Ruger SR1911 Model: 6758, Lightweight Officer 9mm 3.6" Barrel
Aero Precision M4E1 8" .300 Blackout Pistol Upper Receiver w/ ATLAS R-ONE Handguard & M4E1 Lower
RIFLES / SHOTGUN
Sako Forester, Action: L579, .243 Cal, Sporter Stock, (Production Year: 1965)
Henry Big Boy Color Case Hardened Side Gate .44 Mag, Lever Action, (Unfired)
Henry Big Boy Deluxe Engraved H006D3. 357 Mag, Lever Action, (Display Case, Unfired)
Rossi R92 Gold Series w/Black, 357 Mag, 20" Barrel, Lever Action
Mossberg Patriot Vortex .308 Winchester, Bolt-Action Rifle, Walnut Stock
Mossberg 590A1 Tactical 12GA 9RD 20" Model: 51663, Shotgun, (Unfired)
Mossberg 590 Retrograde 12GA 7RD 18.5" Model: 52151, Shotgun
Ruger SFAR, 7.62/308 WIN, 16" Barrel, Model: 5610, MSR
SHORT BARREL RIFLES (SBR)
Springfield Armory Saint Edge 5.56 NATO AR-15 10.3" Barrel
Aero Precision M4E1 Threaded 10" .300 Blackout Upper Receiver w/ ATLAS S-ONE Handguard & M4E1 Lower
SUPPRESSORS
Rugged Suppressors Razor 762
SilencerCo Omega 36M
Keeping things safely away from little prying eyes and touchy-feely hands!
2024 BMW M440ix Gran Coupe -SRG Metallic
2006 CTS Sport, 6 Spd - Blackberry
2003 F-150 Harley-Davidson 100th Anniv. Edition - Black
1988 Conquest TSi, 5 Spd - Black
Appreciate 5
Torgus3806.50
Donatello.1289.00
Mirko210.50
      03-18-2024, 02:47 PM   #7322
ezaircon4jc
ezaircon4jc's Avatar
5600
5,804
Drives: 2019 540i M Sport
Originally Posted by ShapeShifter View Post
PISTOLS:
RIFLES / SHOTGUN
SUPPRESSORS
Looking to adopt a son? I am available, both my parents have passed...
      03-18-2024, 03:40 PM   #7323
ShapeShifter
753
78
Thanks!....Unfortunately, I'm well beyond the rearing age.
      03-18-2024, 04:27 PM   #7324
nosbocaj
nosbocaj's Avatar
783
488
The time has come to finally go for my grail gun: the HK MP5SD. I'm sending my HK SP5 to Dakota Tactical for the full conversion. Should have it back in 3-4 months!
Torgus3806.50
Donatello.1289.00
      03-18-2024, 05:52 PM   #7325
ezaircon4jc
5600
5,804
I'm VERY low maintenance! Potty-trained and all!!
      03-19-2024, 04:38 PM   #7326
ShapeShifter
753
78
I have two kids that are always jockeying to be number one! They would go lockstep in their efforts to declare me incompetent. Besides, no one wants to be saddled with a high maintenance geezer like me.
