04-01-2023, 05:46 PM | #6953 |
2133
Rep 2,885
Drives: F33 430 and F39 M35i
I put less than 200 rounds through it and it had a few failure to feeds because of the hanging on the disconnector. It was in the NMH16xxxx serial range. Not sure of a born on date. It ran fine once I switched to hotter ammo (124 and 147 gr). Guessing it's the cerakote on the rails and disconnector. People were saying just rack the slide 1000 times to wear it in. I was planning on installing a flat trigger and an EGW ball head disconnector in it but was afraid to tinker since I have never worked on 1911/2011 guns. So I bought a cheap Tisas to practice on and installed a flat trigger and the EGW disconnector. It wasn't as scary as I thought. So now I'm going to install flat triggers on my Staccatos.
Here's the Tisas in final form. |
04-01-2023, 05:56 PM | #6954 |
292
Rep 350
^ Nice!
Love flat triggers on 1911 types. Consistent trigger pulls anywhere on the face of the flat trigger. For 1911/2011s with very tight tolerances you just need to keep sending rounds down range to break them in. Maybe like 500rnds at a time, clean & lube, send another 500rnds down range, clean & lube, repeat until it fires reliably. |
chowser512132.50 |
04-13-2023, 11:52 AM | #6956 |
Slow.
3806
Rep 7,161
Drives: N54 6466 100% E85 + Meth
I want to buy a preban AR10 in MA. That is what I have been up to researching. Also trying to find out how to make it weigh 7lbs or less w/ no optic.
Donut Lord452.50 |
04-14-2023, 08:05 PM | #6957 | |
2133
Rep 2,885
got a phlster holster in. the phlster holster was bought for the incoming Platypus but it fits in c2 just fine when i stick a tlr-1 on it. i have a few spare tlr-1hls that i don't use at work anymore. |
04-15-2023, 07:44 PM | #6958 |
Do Donuts
453
Rep 317
thanks for sharing!
04-17-2023, 11:29 AM | #6959 | |
611
Rep 243
Drives: 2022 BMW M340i
I have all the parts to build one, just lazy. I was going to do it on Sat so I could shoot it yesterday. Dont have mine built, so I cannot weigh it. so good luck with the weight.
2022 M340i XDrive, Oxide Grey Metallic/Tacora Red/Shadowline. 2004 330Ci (Sold), 2007 335i (Sold).. |
Torgus3805.50 |
04-17-2023, 12:22 PM | #6960 | |
Slow.
3806
Rep 7,161
https://www.reddit.com/r/AR10/commen...unds_stripped/ I have seen a number of lightweight AR10 builds. Some much more expensive than the others. I think I would go with a short 16'' barrel + muzzle brake. I don't need distance and accuracy here in the NE that a longer rifle will give me. I coudl always just swap barrels if I ever wanted a longer one. I would like to take an AR10 out hunting for whitetail this fall if all goes as planned.
chris_1001611.00 |
04-17-2023, 12:34 PM | #6961 |
1061
Rep 261
Here's my Hellcat before I swapped out the trigger along with a knife.
23 X3MC BGM. MSS. H&R 12mm spacers
20 4Runner 18 Cayman GTS 15 Beetle Vert |
04-18-2023, 06:09 PM | #6962 | |
873
Rep 1,122
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
I know there are some lightweight AR10 parts available, can't imagine what the build cost would be. After doing both my AR10s I was like holy cow they are heavy beasts, said to my buddy it would be work carrying it around the woods. Will use the luggage scale to weigh them and report, no way mine are close to 6lbs, have to be close to 10.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
Torgus3805.50 |
04-19-2023, 12:00 PM | #6963 | |
Slow.
3806
Rep 7,161
04-19-2023, 12:32 PM | #6964 | |
611
Rep 243
I think my 16" AR-15 with a Vortex PST 2 1-6 weighs a hair over 10 lbs. Honestly I just sling it when I'm on a hot range doing drills with other guys and such (we are slung and shooting for a few hours). I'm not hand holding it for long periods
04-19-2023, 01:48 PM | #6965 | |
Slow.
3806
Rep 7,161
I have considered hunting with just a red dot. However I think a red dot + magnifier would be as much weight as a lvpo right? I don't think I would want to shoot at 100 yards with a red dot only and no magnifier for a white tail.
04-19-2023, 02:26 PM | #6966 |
873
Rep 1,122
308 AR10 20" Barrel 15" Handguard with Scope no Mag - 9.7lbs
6.5CM AR10 22" Barrel 15" Handguard with Scope & Bipod no Mag - 11.4lbs The 308 has a $700 JP low mass BCG, both are all Aero HG, Lower, Upper. I am very interested to know the cost of a 7lb build, CF barrel, etc I would guess $3k+.
Torgus3805.50 |
04-19-2023, 02:58 PM | #6967 | |
Slow.
3806
Rep 7,161
https://www.thehighroad.org/index.ph...0-ever.822282/ <-- Claims all the way down to 4.5 lbs... https://pof-usa.com/firearm/revolution/ <-- I don't think I like all the Ar15 parts and it is 7.3lbs which is not exactly light for what they are charging. Here is a 4lber rather fugly to me: https://www.shootingillustrated.com/...0-on-a-budget/ 6.6lbs for $1338.85 is not bad...
Lucky John617.00 |
04-19-2023, 08:32 PM | #6968 | |
Law Enforcer
27183
Rep 22,724
Torgus3805.50 Murf the Surf22080.50 |
04-20-2023, 08:06 AM | #6969 |
Slow.
3806
Rep 7,161
Me too! I have their ultra light weight ar15 upper on my preban pwa commando lower. Nice and light. Their pencil barrels shave off a ton of weight.
04-20-2023, 11:21 AM | #6970 |
1061
Rep 261
I should really weigh this....
The kids love it though. Super easy for them and one-handed operation for adults if desired. 5.56
04-21-2023, 10:05 AM | #6971 |
1702
Rep 1,494
Drives: 2022 M440xi GC
I've got a poly lower AR that weighs just over 5lb without any crazy hardware.
Debraced my mp5k to comply with the dog shooting bastards new rule. It's fine, slings work the same, just opposite and it's even more compact, so suck it. |
Torgus3805.50 |
04-21-2023, 12:45 PM | #6972 | |
611
Rep 243
Just find a light weight scope and rings. you can do a light weight build, just have to do some research. As for using a red dot at 100, remember, a lot of game was taken with just iron sights. I've shot M1 Garands at 200 yards just using the stock iron sites in a few matches. I'm not suggesting a dot or irons, just food for thought.
04-23-2023, 11:32 AM | #6973 |
Slow.
3806
Rep 7,161
4.1lb
https://www.crownprecisionarms.com/the-elite-ar-10/ For that price it better be the cheapest. That is insanely light. |
04-28-2023, 11:29 AM | #6974 |
2133
Rep 2,885
My free sbr from a braced ar-pistol submitted on 01/17 got approved today 04/28.
submitted on eform 1 as an individual with paper prints mailed in. Waiting on one submitted as a trust with paper prints mailed in from 02/16. |
