03-27-2023, 07:13 PM | #45 |
![]() ![]() ![]() 2588
Rep 12,753
Drives: Z4 M, X5, GX460
Garage List E86 Z4 M [10.00]
F15 X5 35i [9.17] F10 550i (Retired) [9.17] F25 X3 35i (Retired) [9.43] E85 Z4 M (Retired) [9.44] E82 135is (Retired) [9.53] E90 328xi (Retired) [9.25] E86 Z4 3.0si (Retired) [8.95] |
Add me to the list of clowns. I always wondered the same, but more from a value perspective. We all get PPF preserves the paint, but the film inevitably gets dirty. So the answer is to ceramic coat the film, which will help keep the grime or any other imperfections that would otherwise damage your paint’s clear coat.
But unlike your original paint, PPF is not meant to be permanent and will need to be replaced in 5-7 years. I know most here don’t hold onto their cars that long so I’m in the minority. But seems like a waste to spend $1500 to coat a temporary film for a long term owner like me. I don’t argue the benefits of coating but I’d much rather paint correction + film and be done with it. Clearly I’m not a detailer so open to hearing (or learning) from other more knowledgeable folks. Last edited by 3002 tii; 03-27-2023 at 07:19 PM.. |
03-27-2023, 08:51 PM | #47 | |
![]() ![]() 6124
Rep 1,951
So if you want to coat your PPF I don't see why you would need to go the $1500 route. That PPF is brand new so it technically shouldn't need any correcting... if you can even "correct" PPF. So you can just buy some ceramic coating for probably under $100 and apply it yourself. |
fortysecond57.50 Patton2502952.50 |
03-27-2023, 10:03 PM | #48 | |
Rep 12,753
Not to further derail, but I learned my lesson hard way and now limit PPF only to the front & mirrors. The one time I had most of my car covered, someone tapped into my rear bumper while parking. The plate screws pierced through my film, causing it to lift. Self healing only goes so far but wasn't long before dirt/grime built up and the spot looked terrible. Paint was damaged either way but the film made it worse and was additional cost to pull it off. Now I cover front & hood b/c those are the areas most susceptible to debris especially when on track. I don't bother with any other panel. Back to original topic... ![]() |
03-28-2023, 08:43 AM | #49 |
![]() 4989
Rep 4,073
this thread ultimately boils down to having the money so why the fuck not right...
unless yall in debt and getting PPF and cermic coating it, then yall sick fucks |
03-28-2023, 09:39 AM | #50 | |
![]() 2953
Rep 2,365
03-28-2023, 11:22 AM | #51 |
15703
Rep 3,966
My god this thread is as bad as OT.
Ceramic coating takes 30 days to fully cure, but reaches 90% cure after 72 hours. I would never let water touch anything I ceramic coated in less than 72 hours. 24 hours is laughable. PPF is superior in every way vs ceramic coating, other than the hydrophobic properties. Ceramic coating PPF is definitely advised, and some PPF now comes pre-coated. |
03-28-2023, 11:34 AM | #52 | |
![]() 2953
Rep 2,365
03-28-2023, 01:54 PM | #53 |
![]() 4421
Rep 2,392
Paint correction and ceramic coat the paint, and then you would PPF it.
For me, PPF > Ceramic/Paint Correction, though I had both done as soon as I bought my car. I've already had the PPF on one of my panel replaced, and the paint looked pristine underneath the PPF, like it was freshly painted (and corrected). Once the PPF was reapplied, I had to wait a few days for it to "seal" to the paint, and then the panel looked great again too. But I like knowing my factory paint is protected. |
03-28-2023, 04:33 PM | #54 | |
![]() ![]() 58
Rep 50
03-28-2023, 05:41 PM | #55 |
your average JAMF
![]() 3642
Rep 4,236
Drives: '21 M2 Comp, '19 Golf R
To the OP: For the fat $$ they charged, did the dealer even provide you with any documentation from the ceramic manufacturer? If so, as they should have, then simply follow their recommendation. If NOT - huge red flag. I'd then be willing to bet that the lot boy who did the PDI wiped on some stuff out of a bottle that says "ceramic" somewhere on it (what automotive detailing product doesn't nowadays?) and called it a day.
'21 M2 Comp
'19 Golf R |
james1138146.00 Westside Guy7643.00 |
03-28-2023, 05:50 PM | #56 | |
your average JAMF
![]() 3642
Rep 4,236
'21 M2 Comp
'19 Golf R |
03-28-2023, 06:06 PM | #57 |
![]() ![]() 240
Rep 381
English please!
2018 MB E400 Coupe
2023 M340i X drive (Mineral White Metallic, Oyster Vernasca Leather, DAPP, Shadowline, PAP, Premium, Cooling & High Perf Tire, Adap M Susp, HK, Drive Recorder, Sensatec Dash) |
03-28-2023, 10:45 PM | #59 | |
15703
Rep 3,966
I do all of my ceramic coating in the Winter so the car sits for 90 days before it goes anywhere, but I understand that's unrealistic. IMO, just wait as long as you can before driving it, and certainly as long as you can before getting it wet. Who on earth told you to do that? It's absolutely wrong. Paint correction, then PPF, then ceramic coating. No installer worth their salt would put CC on a car before PPF, the film itself would have major issues adhering to the surface. |
03-29-2023, 05:39 AM | #60 | |
![]() 2953
Rep 2,365
If you keep spewing actual facts here, they’re going to get pissed off at you. PPF and Ceramic Coating is a waste of money. Didn’t you know that? Haven’t you seen that one of our very members on this thread spent all his school money on it only to be disappointed? Now he had a crappy looking car and he can’t construct a proper and in most cases, a comprehendible sentence. ![]() On a serious note let me back you up because what you said is correct. 1. Foam wash the car. 2. Paint correction 3. Foam wash the car. 4. Apply PPF. 5. Apply ceramic coating. Anyone who is actually interested in knowing the truth about this can simply use the Internet. There are tons of articles on this explaining the benefits of all these procedures and why it’s good for you to do them to cars that you actually care about the paint staying pristine for as long as possible. Third-party articles that don’t sell products as well as product manufacturing articles and dealer articles. Dozens of hours worth of videos and articles with information that are all pretty consistent with one another. At this point (2023) to say that PPF, and Ceramic Coating does not have benefits and is a rip off is the same as saying that you highly doubt a Boeing 747 will ever be able to get off the ground and fly. ![]() |
04-04-2023, 01:48 PM | #61 | |
![]() 146
Rep 244
04-04-2023, 01:51 PM | #62 | |
![]() 146
Rep 244
04-04-2023, 06:29 PM | #63 | |
Rep 604
Don't take it through an automated car wash either unless you want the coating wrecking. |
04-04-2023, 06:35 PM | #64 | |
![]() ![]() 6124
Rep 1,951
04-05-2023, 08:36 PM | #66 |
![]() ![]() 1227
Rep 2,383
I always Ceramic coat the PPF, it's part of my routine
