12-30-2015, 04:57 AM | #47 |
Mr. OEM
565
Rep 803
Perfect chassis? Well looking through pink glasses makes everything look perfect. Let's not forget about cracking subframes.
I mean every model has its problems of course, but that was pretty bad. And a Vanos that turned out even more problematic than the previous (which is in the end, just bad seals). Breaking oil driver tabs and cam gear sprocket bolts shearing. Design wise it's a great car. Very "out there". Maybe a little too much for my personal taste. I guess that's why I bought an E36 M in the end instead of the E46 (and I wanted a cabrio and I don't like the E46 in cabrio shape). However I do recall that when I first saw the concept pics of the E46 M3 way back when I didn't own a BMW or any car for that matter myself, I found it the best looking car ever.
'1998 BMW M3 3.2 Cabrio • Alpinweiß III auf Schwarz • Deutschland-ausführung • 1 von 12 • SMG • SRA • PDC • AUC • GSM • HK • UURS • IHKA • FGR • MFL • |
12-30-2015, 05:16 AM | #48 |
188
Rep 869
E46 is one of the best then e30 then f80 then unfortunately e9x m3 the most disappointing one for me
12-30-2015, 06:28 AM | #50 |
56
Rep 141
M3 is one if the GOAT.
06 M3 vert alpine white on cinnamon - sold
06 M3 vert alpine white on red - sold 06 M3 vert alpine white on red - sold ( my 3rd) 05 M3 coupe alpine white/ cinnamon - 18k miles! 2011 550xi alpine white on ivory (sold) 2013 640i black sapphire metallic on cinnamon 2014 Cayenne GTS |
12-30-2015, 07:09 AM | #51 |
Emperor
1617
Rep 2,765
e36 owners are in no position to get judgey about subframe mount point tears, with the e36's front shock tower failure, rear shock tower failure, RTAB pocket failure, sway bar mount point failures, and subframe (itself, not mount point) failure.
2005 M3 Coupe, 2004 M3 Wagon, 2001 M5 Sedan, 2008 M5 6MT Sedan, 2012 128i M sport |
12-30-2015, 07:14 AM | #52 | |
Emperor
1617
Rep 2,765
next car is almost certainly an e38 750iL (want a V12 before the world stops making them). Then... my wife is going to kill me if we don't get a Z3 M coupe as her fun car/ One day we'll have to get a Z8, just so we can have one of everything they made in 2001
12-30-2015, 08:24 AM | #53 | |
674
Rep 784
12-30-2015, 08:28 AM | #54 | |
3646
Rep 3,131
Drives: G06/G20/F30/F15/F10/E90
12-30-2015, 08:47 AM | #55 | |
7914
Rep 11,785
BECAUSE CSL! |
12-30-2015, 08:49 AM | #56 | |
7914
Rep 11,785
12-30-2015, 08:52 AM | #57 | |
7914
Rep 11,785
12-30-2015, 09:18 AM | #58 | |
Emperor
1617
Rep 2,765
e30 chassis is a tank, though. It was the last of "test it till it breaks, then make it stronger" instead of "computer model is to be theoretically good"... which was a process they didn't get entirely right till the e9X (with the e36, especially in Z3 form, being the first, getting the worst of it, as seen in all the chassis mount points I mentioned above). S54 (e46) has no oil pump issue... are you thinking of the oil pump nut on the S52 (e36 M3 US)?
12-30-2015, 09:45 AM | #59 |
1609
Rep 8,073
Drives: 11 E90 M3 Individual
Loved the video.
I have an E46 and E90...love them both for different reasons.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
12-30-2015, 09:48 AM | #60 | ||
1609
Rep 8,073
12-30-2015, 09:50 AM | #61 | ||
7914
Rep 11,785
Control arms on the E30 M3 were a little bit of a weak point for racing but agree none of the chassis issues that plagued E36,E46 and MINI models for a decade or so. Of course, the E90 M3 V8 is also proving to be just as "fragile" as the S14 with respect to not making it 100k miles before a rod bearing failure. What was the issue on the E46M3 that causes them to extend the warranty on the S54 ? I searched briefly and found this. 01-02 M3 will automatically got it. For 03 models, it's VIN specific. |
12-30-2015, 10:31 AM | #63 | |
Emperor
1617
Rep 2,765
Beyond that, the S54 has two failure points that can bite you , though you can fix both of them in an afternoon for dirt cheap: 1) cam bolts loosen. This is fixed by installing new ones to the factory torque spec with loctite blue. If the originals never loosened you can reuse them, but they cheap enough that nobody does. 2) vanos oil pump drive tabs sheer. This is caused by too large of holes in the oil pump disk. You can get a redrilled oil pump disk for $150 post core return, which is drilled to S50B32 tollerances, and solve the issue. Once addressed, they're forever fixed (as in, you're fixing the design fault, not resetting the clock on a wear item). I've done 50+ cars for forum members at this point-- it's a 4-5 hour job once you're done it a couple times. First time you do it, set a day aside for it (you do have to retime the engine when done, so don't want to rush).
12-30-2015, 11:47 AM | #64 |
259
Rep 300
Here is my 04 e36 M3. I have kept it and has only 8000 miles on it. Will continue to keep this car as it is one of the most gorgeous BMWs ever made. Still engine and driving is very excited.
12-30-2015, 12:01 PM | #66 | |
345
Rep 946
