01-27-2015, 12:49 PM | #45 |
Hi
![]() 92
Rep 280
Drives: Maserati Ghibli, E92m, FTR
I for one would like to see cold hard sales figures to support that BMW Xdrive outsells Quattro. I for one don't buy that for a second.
01-27-2015, 12:59 PM | #46 | |
![]() ![]() 24
Rep 1,190
![]() Most of the AWD systems rely heavily on computer intervention (except for the aforementioned STI, which is different than the other subaru AWD systems). The computer will either cut power, open/close a clutch that controls power to the rear wheels (as does xdrive, at least the versions I read about in the 2008 models) or brake wheel(s) to get the power where the computer determines it should be sent. From what I recall the xdrive system has the front axle connected to the output of the transmission via a chain system that cannot be decoupled. There is then a clutch pack that power must go through from the transmission to get to the rear wheels. The only way I can see the claim "100% of power to either axle" being true is if you take into account the brakes on one axle being applied, momentarily, to stop the wheels on that axle. Then the power has no where to go but to the other axle. I wonder if the xdrive system is different across all BMW models or if it's just computer programming.
2011 VW GTI 4dr-6mt-Sunroof-Nav-Xenons
OLD: 08 335i AW/CR/Poplar 6mt-ZSP-ZPP-ZCW-iPod-iDrive-PDC-Style 230s w/FK 452-Dinan LSD |
01-27-2015, 01:04 PM | #47 | |
![]() ![]() 103
Rep 252
Drives: Anything with a locking diff
I understand. Believe it or not, I never drove a FWD or AWD car. Every car I had was RWD. So I never really experienced understeer except for the standard, small understeer when exiting a corner with throttle. I don't know, would you say it is terrible, or annoying, the understeer in xDrive, if there is any? |
01-27-2015, 01:04 PM | #48 |
![]() ![]() 1127
Rep 1,648
I can almost guarantee for the roller video they disabled the DSC system on the audi. If it was enabled it would have engaged the brakes on the spinning wheel allowing the open diff to transfer torque to the other wheel on the ground. It's a BMW video so wouldn't surprise me.
As for the "real life" test vid in the snow/ice above there are other factors that come into play as well. Tire type, tire pressure, gearing, and driver ability all are factors. I used to see plenty of soccer mom's in their bmw/audi SUVs slide down hills bc they just flat out didn't know how to drive in the snow. Meanwhile I'd be passing them up hill in an 88 sentra starting in 2nd gear with shitty goodyear snow tires. I wouldn't base a car purchase on one marketing awd hype over the other. If you suck at driving no awd system will save you. |
01-27-2015, 01:09 PM | #49 | |
![]() ![]() 1127
Rep 1,648
Performance wise, it all relies on how they tune the system and its sensors. |
01-27-2015, 01:33 PM | #50 | |
Moderator
![]() 7468
Rep 19,366
Keep in mind, while in the US there are only a couple models where Quattro isn't standard (one of which is the A4, by the way), worldwide, all of their passenger cars and, I believe, some of their SUVs are available without Quattro (in which case they are FWD). So, when you take the two above together, it is not hard to see how BMW could theoretically be selling more AWD vehicles than Audi. It certainly doesn't confirm it, but I have no trouble at all believing it could be the case. |
01-27-2015, 02:16 PM | #51 | |
![]() ![]() 16
Rep 165
Audi uses more then one system, depending on model, but name them all Quattro. |
01-27-2015, 02:20 PM | #52 | ||
3160
Rep 9,134
01-27-2015, 02:29 PM | #53 | |
![]() ![]() 16
Rep 165
![]() I'm not 100% sure due to memory loss but as i recall the key is after 2008 models its an electronically controlled multi-plate clutch that makes the difference compared to older, or other systems, in terms of system speed when distributing power between axles. ![]() |
01-27-2015, 02:47 PM | #54 | |
![]() ![]() 487
Rep 1,188
Drives: 2008 e92 335xi
Audi's Torsen Quattro system (on all models except A3 and TT, which use a garbage Haldex system that VW and Volvo use) is purely mechanical whereas BMW's system is electronic. In my opinion, the 2nd video does not represent real world driving conditions and is purely for marketing, especially considering it was done at a BMW dealership. Someone else made the point that there is no mention of the traction control settings in the test either. Probably not a coincidence. After driving in snowy Minnesota with an Audi A4 and a BMW 335xi both equipped with snow tires, I would take the Audi hands down. Oh, and don't forget that in terms of maintenance and reliability Audi never has issues whereas, although uncommon, you do hear about people having to replace their transfer case which is big $$.
01-27-2015, 02:54 PM | #55 | |
![]() 1141
Rep 4,686
Drives: L'Orange
I would never drive an 'AWD BMW"......makes no sense. If i wanted AWD i'd go to those who do it best----Audi and Subaru. |
01-27-2015, 03:00 PM | #56 |
![]() ![]() 1331
Rep 1,886
A video of a few sliding around in slush: http://f15.bimmerpost.com/forums/sho....php?t=1084219
For some feedback on X Drive, I would troll the the X5 forum where users cover the pros and cons. This thread's video is a good, but merely a theoretical way of showing how X Drive works. I have an LX470 and an X5. The latter is very good, but if there is three feet of snow on the ground I feel less confident in the X5.
01-27-2015, 03:22 PM | #57 |
![]() 285
Rep 1,960
Not really. I had an A6 Quattro last winter and my xDrive 335GT this year, both on the same Continental DWS tires and they're definitely comparable. Both easily got out of their snowy graves with no issues and no shoveling. The BMW got a little sideways today while the Audi generally tracked straight, but they're both more than good enough.
01-27-2015, 03:24 PM | #58 |
Rep 21
Accidentally right now you can read on Autobild's online site the restults of a winter test of 10 AWD cars. Autobild itself says that they have compared apples to oranges
![]() - Ram 1500 - BMW X435d - Skoda Octavia Scout - Jeep Cherokee - Audi A6 Allroad quattro - Fiat Panda 4x4 Cross - Nissan Qashqai - Toyota RAV4 - VW T5 Multivan - Land Rover Defender http://www.autobild.de/bilder/zehn-a...282.html#bild1 |
01-27-2015, 03:27 PM | #59 | |
![]() 93
Rep 236
oh and yeah and i had the torque vectoring sports-diff. |
01-27-2015, 03:29 PM | #60 | ||
![]() 43
Rep 261
2010 E92 SSII DCT, Akra Evo, ESS Tune, Performance Spolier &Splitter, Edition Side Markers, AD08R
01-27-2015, 03:33 PM | #61 | ||
![]() 43
Rep 261
01-27-2015, 03:47 PM | #62 |
![]() ![]() 1127
Rep 1,648
I think if I had to choose I'd go with the quattro system (the non-haldex one). A mechanical setup designed for a mostly neutral split. Purely electronic systems feel a bit "synthetic" to me. I'd still drive the BMW over the Audi in general though since xdrive is more than capable.
01-27-2015, 04:27 PM | #63 |
![]() 412
Rep 1,356
Starting with gen 3 Haldex, it is now proactive and is no longer just FWD waiting for slippage to send power to the rear axle. It's all electronically controlled, just like xDrive and will send power to the rear axle depending on things like throttle position, incline, speed, etc. The TTRS, RS3 and RSQ3 don't seem to be too hampered using it.
21 BMW X5 xDrive40i
20 BMW M2 CS 19 Mini Cooper S Countryman ALL4 6MT |
01-27-2015, 04:29 PM | #64 | |
![]() 10
Rep 34
01-27-2015, 05:08 PM | #65 | ||
![]() ![]() 121
Rep 1,140
01-27-2015, 06:05 PM | #66 | |||
![]() ![]() 16
Rep 165
