03-18-2022, 02:55 PM | #618 | |
2462
Rep 11,669
After start of quali they can only change damaged parts , like for like.
'21 M2C Hockenheim Silver
NYG12557.50 |
03-18-2022, 03:00 PM | #619 |
12558
Rep 4,329
///M Power-Belgium72868.50 M5Rick71350.50 |
03-18-2022, 03:04 PM | #620 | |
2462
Rep 11,669
Locked for that weekend. Development mods (FIA approved) are still permitted between race weekends.
NYG12557.50 |
03-18-2022, 03:06 PM | #621 |
8016
Rep 8,064
Very interesting so far, Russell is bearing out Lewis and Latifi is beating Albon. The Ferrari so far looks legit too!
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242 |
irunalot1535.00 |
03-18-2022, 03:08 PM | #622 |
12558
Rep 4,329
03-18-2022, 03:10 PM | #623 |
12558
Rep 4,329
03-18-2022, 03:26 PM | #624 | |
72869
Rep 27,119
And the W13 brakes really s@ck ! I'm pretty sure ,this weekend It's MAX vs the 2 Ferrari's ! Meanwhile HAM's W13 was bucking like a wild rodeo horse !
03-18-2022, 03:41 PM | #625 | |
72869
Rep 27,119
And it has to be according the FIA Spec/Regulations . Meanwhile at Mercedes It's "Mission Impossible" ! If HAM pulls tomorrow a top-3 . Then he deserves an oscar for his hilarious Soaps !
03-18-2022, 03:41 PM | #626 | |
8016
Rep 8,064
1) since the body is so narrow the floor is extremely wide meaning it's easier to flex down. When it flexes down it seals the floor better increasing down force which causes the car to drop lower and that causes the distance between the bottom of the floor and track to become so small air flow detaches and stalls creating the porpoising effect. 2) the floor doesn't produce strong enough vortices to seal it as effectively as McLaren. This means Merc is more susceptible to wind, and can't run a high enough ride height. 3) the floor design itself seems to stall a bit more than others as Mercs ride height, as shown by the inlet strakes needing to be cut to increase air flow. So honestly I don't see how it could be a side pod issue, I've read up alot about it but no one seems to peg the side pod as the issue, porpoising is most definitely a floor issue. Because side pod air flow is easy to observe in CFD and the wind tunnel to see if it's doing what it's supposed to. But the floor isn't because you can't run ride heights super low in the tunnel. Ah I didn't know that. But I still think George will be right up there if not beating Lewis, look at his gp3 and F2 results he was one of the rare drivers to win both (like Leclerc) and he absolutely destroyed Albon and Norris in equal machinery.
irunalot1535.00 |
03-18-2022, 03:46 PM | #627 | |
8016
Rep 8,064
The only reason I personally see for Merc to go wide is to reduce floor width which will reduce floor flex.
03-18-2022, 04:04 PM | #628 | |
12558
Rep 4,329
1. The width doesn't matter as long as there's support points under the car. 2. True 3. This one I need to look at, can't comment. |
03-18-2022, 04:09 PM | #629 | |
1671
Rep 2,016
03-18-2022, 04:10 PM | #630 | |
8016
Rep 8,064
1) there's no under body supports, it's a 1 piece bit of molded carbon fiber. You can't have things supporting the floor edge under Neath because where would they mount? They can't cross over to the middle of the car because that'll restrict flow to the tunnels. So it's just a confirmed bit of carbon, and the larger the area the more it can flex when subjected to the immense pressure differential. 3) idk Merc has been reworking the roof of the floor etc to try to prevent stalling. But so far it's not helping too much.
03-18-2022, 04:18 PM | #631 | |
72869
Rep 27,119
Currently I see the Mercedes W13 Manta Ray Design as a complete failure .. Article 9.3.2
M5Rick71350.50 |
03-18-2022, 04:24 PM | #632 |
71351
Rep 22,744
HAM has come on again to say that he is not lying insisting the 13's problems run deeper than just set up.
///M Power-Belgium72868.50 |
03-18-2022, 04:28 PM | #633 | ||
8016
Rep 8,064
But I did say before I didn't think merc were sand bagging, they weren't sand bagging last year and they aren't sand bagging now.
03-18-2022, 04:28 PM | #634 |
1535
Rep 823
No team has used all of their CFD and wind tunnel time just to start the season. They all know they need to develop all year to be competitive.
The Merc looks like it makes gobs of down force but they are having issues getting it under control. The car shows some major flashes of speed as GR hit a few purple sectors especially in the S2 but could never get a good lap together. As far as Ham and Russ times, they were on different tires and Ham is holding back as he often does FP. When hes that far back its on purpose. Like him or not hes won 7 championships and that cant be done without talent. In identical cars, Bottas won 0 and Rosberg won 1 and it nearly killed him. Russ may have beat a lot of other teammates but none of them are F1 champions. |
03-18-2022, 04:31 PM | #635 | |
1671
Rep 2,016
F87source8016.00 |
03-18-2022, 04:32 PM | #636 |
72869
Rep 27,119
Ocon's hole looked really bad !
M5Rick71350.50 |
03-18-2022, 04:36 PM | #637 |
72869
Rep 27,119
The McLaren wing has a setting for angle of attack
M5Rick71350.50 Fliplegend1702.00 |
03-18-2022, 04:37 PM | #638 |
71351
Rep 22,744
