      11-25-2021, 09:25 AM   #595
minn19
minn19's Avatar
14515
10,434
Drives: 25 Z06, 25 X5M60, 24 MMER
Originally Posted by M5Rick View Post
I hate anyone I suspect is cheating, you apparently don't.
The speed of the Merc at Brazil was phenomenal,so how do you explain his pace without your figures? Ham-was-faster,I saw it on the screen not the figures, how do you know the figures are correct
This is possibly your best troll yet! MB/Mercafia strikes again apparently!
Steeler2468.50
3798j13993.50
F87source8203.00
      11-25-2021, 09:35 AM   #596
Steeler
Steeler's Avatar
2469
2,729
Drives: Built not Bought 04 Z4 VF. E70
Dickie has laser eyes. Eyes don't lie apparently. Wow, that statement is so out there it's hard to quantify.
W2A Intercooled Vortech V3Si, custom ducting, Alpha N, 60# Bosch,2.62 pulley, multi port WMI, Severn Tuning(pokeybritches), Tial, magnaflow,SS race muffler, 42 design,3.91LSD, H&R, Hotchkis,ST coils,Konis, Megan camber arms, AKG SS, Nylon mounts, Poly bushings, Carbon interior, CF Aero.APEX
minn1914514.50
F87source8203.00
      11-25-2021, 10:06 AM   #597
TheBingoBalls
TheBingoBalls's Avatar
4319
4,873
Drives: BMW
Originally Posted by F87source View Post
Innocent until proven guilty, if you can prove mercedes is cheating I will call them out on it.
Otherwise if you hate without proof, then you imply you also hate max and redbull for cheating with their flexi wing which was caught and they had to change it, and if you also don't care about facts and only speculate max cheated by heating the tires higher than normal to get a higher pressure reading than what it was supposed to be - i.e. cheating with tire pressures. That caused the blow out. Since you don't care about facts then that's what we have.
Proof?
The speed of the Merc at Brazil was phenomenal,so how do you explain his pace without your figures? [COLOR="Black"]Ham-was-faster,[/COLOR]I saw it on the screen not the figures, how do you know the figures are correct
No one knows but the argument is that it wasnt necessarily sheer pace of the Mercedes, it was that RB just lacked pace that day which made the Mercedes seem faster than it really was whether you want to point at PU or wing.
minn1914514.50
F87source8203.00
      11-25-2021, 12:20 PM   #598
M5Rick
M5Rick's Avatar
73156
23,162
Drives: M5 F10 DCT Gunmetal
RB did have a small problem with their drs activation arm being too stiff making the moveable wing flap at times to vibratate forcing the team to revert to an earlier wing for more stability. This has now been modified for the latest wing to work optimally.
      11-25-2021, 02:19 PM   #599
M5Rick
M5Rick's Avatar
73156
23,162
Originally Posted by ///M Power-Belgium View Post
Jane . That's what we are talking about !
It's all very well for Masi to stand up for the marshall waving a yellow erroneously inside the barrier but Horner was spot on speaking up as Gasly continued to drive as not to impede other cars so the warning was unjustified. Max and BOT should never have received grid penalties, Masi simply overreacted unnecessarilly.
      11-25-2021, 02:22 PM   #600
F87source
F87source's Avatar
8203
8,202
Drives: Bmw M2
Because being fast around a track is not directly proportional to straight line speed alone, cornering speed, downforce generation - related to braking (this is a huge reason why road cars can't brake with as much g forces as an F1 car, the next is mechanical grip of the tires)... If you knew F1 as well as you said you did you wouldn't have to pull things out of thin air to try to explain a phenomenon you see on tv, you'd be able to think more logically instead jumping straight to nonsense.
So the Mercedes may not be the fastest on track but it certainly up there hence why you see it being able to close the gap on nearly every car on the field. Then nothing else on the field holds a candle to the w12 in terms of downforce generation (redbull excluded) so it can out brake and out corner the rest of the field hence why overtaking was so easy looking (if you're not Bottas). So that's the logical explanation based on given facts in formula 1.
Next the figures are from the F1 taken radar traps, the same figures you see during the races in the bottom corner of the screen. So they've been taken via radar or lidar, which is much more accurate than what you see because you're insanely biased against Mercedes and so far you've only attributed everything to top speed and neglected every other factor.
Again all you've provided was "I saw this", I "I saw that" etc etc but no data. You literally have nothing to stand on, except your unnatural hate towards Mercedes in this debate.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242
      11-25-2021, 02:24 PM   #601
F87source
F87source's Avatar
8203
8,202
Drives: Bmw M2
Originally Posted by Killed by Death View Post
With all due respect, since I know you are kinda neutral, RB wasn't cheating with their Flexi wing. It passed all tests and they, along with other teams, were given several weeks to adapt and pass the new test. Also, no fines or penalties were given.
On the other hand, MB's front wing is way more Flexi than others as seen from wing cam. But the FIA is letting it slide and telling other teams to catch up.
Double standard to me. I don't believe tests and regulations should be changed mid-season. If a car passes all tests at the beginning of the season it should be fair ALL season IMHO.
I hold the same opinion for MB's rear wing which seems to be the current controversy.
It was meant to highlight the double standards mpower and Rick have towards Mercedes vs. redbull. Even when a rumour is spread about Merc they go wild, but when it's redbull they're quiet.
      11-25-2021, 03:11 PM   #602
M5Rick
M5Rick's Avatar
73156
23,162
So much gobbledegook from you and claiming to be a neutral, I say you're a liar and a Merc fan.
      11-25-2021, 03:17 PM   #603
F87source
F87source's Avatar
8203
8,202
Drives: Bmw M2
Highlight the portions that is "gobbledegook" and explain why with science and facts. If you can't then you're full of yourself.
minn1914514.50
      11-25-2021, 03:37 PM   #604
M5Rick
M5Rick's Avatar
73156
23,162
You stick with your meaningless figures and I'll judge with my eyes, what is clear to me now is that you hate RB.
      11-25-2021, 03:42 PM   #605
F87source
F87source's Avatar
8203
8,202
Drives: Bmw M2
And just like that you are full of crap, if something doesn't look the way you want it to look , i.e. mercedes being the fastest in a striaght line to fulfill the narrative mercedes is cheating with their "jet mode" then you refuse to accept it. That is a denial of reality and a sign of being deluded beyond reason, you guys no longer have any credibility, because you do not stick with facts you stick with feelings.
How do I hate RB? Because I am defending mercedes against baseless accusations? I would defend any team even RB if accusations are baseless, but you guys literally only bully mercedes so they are the only ones who need defending.
minn1914514.50
      11-25-2021, 03:45 PM   #606
F87source
F87source's Avatar
8203
8,202
Drives: Bmw M2
https://the-race.com/formula-1/mark-...d-bull-claims/
This one goes into a detailed analysis on the speed delta between mercedes and redbull, and it is nowhere near the "unraceable" 20kph+ difference that horner says it is.
minn1914514.50
      11-25-2021, 03:49 PM   #607
M5Rick
M5Rick's Avatar
73156
23,162
The deluded one is you and are doing your upmost to put RB down with your nonsense, anything you say is more gobbledegook with no meaning, you're nothing but a Ham altar boy in disguise.
      11-25-2021, 03:59 PM   #608
F87source
F87source's Avatar
8203
8,202
Drives: Bmw M2
Right because showing the out right performance figures that completely debunks your narrative on mercedes being the fastest because of their cheating wing and cheating engine is "gobbledegook". Meanwhile you guys have zero backing for your claims with credible data of any kind and rely solely on feelings and biased personal observations, and that is totally acceptable. If what I am saying is nonsense why can you not highlight the nonsensical part and debunk it with fact? Right because all you can do is talk, and there is even more detailed analysis out there pointing that the gap between mercedes and rb isn't as significant as rb claims. This also goes against your view that max is some kind of super human driver and he is holding off lewis in a cheating car - so another reason you can't accept the truth because it would mean max isn't as super human as you make him out to be. (This isn't degrading max, he is damn good and a generation talent, but you guys hype him up far too much by gas lightining mercedes)
And debunked again, if you were in a real debate that would have been the end of it the moment you started changing the subject and unable to counter the data.
Also note, I have not even made an attempt to pull redbull down, I am debunking your myths about mercedes and used relational comparisons to redbull.
      11-25-2021, 04:14 PM   #609
M5Rick
M5Rick's Avatar
73156
23,162
More yada yada from you, whatever Ham lover.
      11-25-2021, 04:24 PM   #610
F87source
F87source's Avatar
8203
8,202
Drives: Bmw M2
Common technique to deflect attention away from yourself and change the subject. The data doesn't lie and I just dismantled your "jet mode" talking point, and there was not a single thing you could counter with.
Call me what you want I really do not care, it doesn't bother me, and it doesn't change the truth of your lies.
      11-25-2021, 04:27 PM   #611
M5Rick
M5Rick's Avatar
73156
23,162
Common technique to deflect attention away from yourself and change the subject. The data doesn't lie and I just dismantled your "jet mode" talking point, and there was not a single thing you could rebuke with.
You're a grande liar saying you're a neutral, case closed m'Lud take him to the cells.
      11-25-2021, 04:33 PM   #612
Steeler
Steeler's Avatar
2469
2,729
      11-25-2021, 04:38 PM   #613
F87source
F87source's Avatar
8203
8,202
Drives: Bmw M2
Yet I am the only one able to provide facts and data unlike you.
Steeler2468.50
minn1914514.50
      11-25-2021, 04:43 PM   #614
M5Rick
M5Rick's Avatar
73156
23,162
You provide a heap of s*it to put RB down
      11-25-2021, 04:57 PM   #615
F87source
F87source's Avatar
8203
8,202
Drives: Bmw M2
I'm only defending Merc and debunking the lies about the supposed jet speed and how they have abnormally high speeds, and if it's a heap of s*it why can't you debunk it with facts?
Ah yes because the truth hurts.
And where have I put RB down? It's not my fault the data shows that they're near the bottom of the pack in terms of top speed. Data doesn't lie. They usually have better cornering speeds vs. mercedes hence they gave similar race Pace, but in Brazil and Qatar Mercedes managed to match or exceed that cornering speed and that's why they came out on top as they now are faster and corner better.
Btw look in the mirror you're projecting again, you guys are the only ones who have been putting out hate and degrading comments towards Mercedes and you don't seem to care.
Steeler2468.50
      11-25-2021, 05:01 PM   #616
M5Rick
M5Rick's Avatar
73156
23,162
Your figures belong in a garbage can lol you're like a mad scientist that gone off the rails.
