06-06-2012, 12:51 PM | #486 |
136
Rep 5,040
06-06-2012, 06:07 PM | #487 | |
89
Rep 1,247
Drives: fat cars are still boats
Location: compensating a fat car with horsepower is like giving an alcoholic cocaine to sober him up.
I'm the kind of guy who usually puts his money where his mouth is... I wouldn't take the trouble if I wasn't genuinely convinced that the Toyobaru really is a cornerstone. I miss some aspects of the Cayman driving experience... namely its precision, driving position and the manual gearbox - the best gearbox I've ever experienced. Period. But at the same time I love the challenge of driving the 1M - you are always fighting with yourself as you are always aware that you are not making the most of the 1M capabilities, so you are compelled to push it and yourself to its limits because this car was made to go sideways and you soon will find yourself wishing for better driving skills. Then there's the gas mileage issue which is important when your driving style systematically puts you on the 15 mpg mark and you are paying 2.13 US$ per 0.26 gal. So, the way I see this Toyobaru is like a fusion between the Porsche and the 1M for the best of their traits... and it just isn't a perfect fusion because of the torque absence... then I have to ask for it! |
06-06-2012, 06:16 PM | #488 | ||
4th down; 4th quarter? Renegade.
93
Rep 3,846
As for the torque; upgrades to Subarus are so cheap. Sounds like the chassis is great. You can almost drop a whole new motor in one for the price of a full BMW exhaust. : ) Last edited by Singletrack; 06-06-2012 at 08:15 PM.. |
06-06-2012, 06:41 PM | #489 |
89
Rep 1,247
Yes. But on the other hand I also think this car should make a statement to the snobbish of the pseudo-sports car world with its comparatively low price tag... so it should be perfect out of the factory.
06-06-2012, 07:27 PM | #490 |
93
Rep 3,846
Properly driven, I'm sure it will whip a lot of the people you are referring to on the track. ; )
06-06-2012, 08:29 PM | #492 |
93
Rep 3,846
Looks dope in matte. Don't like the fender green (would do gloss black myself), but the mirrors are cool.
I'd go white with bronze wheels personally. Straight JDM y0! ; ) |
06-07-2012, 08:20 PM | #495 |
89
Rep 1,247
06-08-2012, 12:32 PM | #496 |
41
Rep 560
Outside of Insideline and Toyobaru's own numbers, it seems no other magazine or websites are getting that same 0-60 time. Others are below 7 seconds and some are even mid-6s.
2012 Z4
06-10-2012, 08:14 PM | #497 | |
89
Rep 1,247
Mind you that the automatic version was the one tested by EVO magazine... isn't this outrageous?! Last edited by GoingTooFast; 06-10-2012 at 08:40 PM.. |
06-10-2012, 10:08 PM | #498 |
89
Rep 1,247
Three different engines with the same exact displacement (1998cc) and equal number of cylinders (four). Why is the Toyobaru's engine the only one with direct fuel injection and yet the worst of the three? You could say that it's the most fuel-efficient of the three engines averaging 7.8L/100 km and while that is true the problem is it's not much different from the 8.2L/100 km achieved by the multi-point fuel injection (MPI) Renaultsport's engine if you consider that the Clio RS weights the same 1240 kg BUT has shorter gear ratios... and what about the performance?! Let's compare the three cars equipped with each of those engines:
Multiplying the differential ratio with the transmission ratio we have: ............. Type R (FD2)........... Clio RS............ BRZ 1st......... 16.55:1.................... 14.91:1........... 14.88:1 2nd......... 10.78:1.................... 9.34:1............. 8.98:1 3rd.......... 7.69:1..................... 6.74:1............. 6.31:1 4th.......... 5.82:1..................... 5.34:1............. 4.96:1 5th.......... 4.66:1..................... 4.31:1............. 4.10:1 6th.......... 3.74:1..................... 3.60:1............. 3.20:1 Redline..... 8600 rpm................. 7400 rpm.......... 7400 rpm Torque.... 159 lb-ft................. 159 lb-ft.......... 151 lb-ft Power....... 222 hp..................... 203 hp............ 200 hp CR............ 11.7:1..................... 11.5:1............. 12.5:1 BoreXStroke 86x86 mm................ 82.7x93 mm..... 86x86 mm Displac...... 1998 cc................... 1998 cc .......... 1998 cc Weight...... 1270 kg.................... 1240 kg ......... 1239 kg 0-62 mph... 6.3 s........................ 6.9 s.............. 7.6 s Max Speed. 241 km/h.................. 225 km/h......... 226 km/h So I ask why in hell does the Toyobaru's engine have such a high compression ratio (12.5:1) if it can't make the most of it?! Poor engineering then?! Last edited by GoingTooFast; 06-10-2012 at 10:16 PM.. |
06-11-2012, 05:40 AM | #500 |
89
Rep 1,247
06-11-2012, 05:46 AM | #501 | |
89
Rep 1,247
I want this to be answered! |
06-11-2012, 09:05 AM | #502 |
32
Rep 241
A friend picked one of these up this weekend. It is not a good road car, it is exceptionally slow, at least in my opinion. It might be fun as a track day car because it really does handle beautifully, I can't see any reason someone would buy a Miata as a track day car instead of this. Even so, against drivers of reasonably equal skill I don't think you would be able to keep up with some of the cars people are trying to compare this with...it really is sloooooooooooooooooooooow. Hopefully the STI/TRD (or whatever designation Toyota uses, assuming it comes out with a higher performance model) makes it a better DD.
F06 650i Carbon Black / Black
G05 X5 m50i Mineral White / Tartufo Porsche Taycan Turbo Carrara White / Limestone Beige |
06-11-2012, 09:59 AM | #503 | |
4459
Rep 9,160
I haven't seen what official race support Subie/Toyota are offering for the 86, but Mazdaspeed provides so much support for the Miata (and other Mazdas) that it's a huge bonus for any aspiring track junkie. |
06-11-2012, 11:56 AM | #504 |
49
Rep 1,135
06-11-2012, 12:10 PM | #505 | |
89
Rep 1,247
Because the engine should have a fat torque curve without dips and peaks over the entire rpm range like the Renaultsport's engine (Renaultsport surely knows how to do a proper engine): |
06-11-2012, 12:42 PM | #506 |
Snow Wizard
39
Rep 428
I am really surprised that this car has 12.5:1 compression and can only offer 200hp. What are they doing? DI engines are great, but it seems Subaru don't have the ability to pull the power out in a NA engine.
