07-18-2012, 03:38 PM | #23 | |
TIM YOYO
1506
Rep 3,282
Drives: 2013 M3
Keep in mind, I'm talking ranges, not absolute RPM. So for example, with our hypothetical N/A IC engine, we might see torque rise to within 80% of peak at 3,500 RPM and drop off a cliff at 6,000 RPM. That's a range of 2,500 RPM, and is pretty typical (maybe even aggressive) for your run of the mill N/A IC engine. High performance engines employ technologies to expand that range and push it higher in the RPM range in order to generate more horsepower. An electric motor has a very different torque curve. Peak torque for an electric motor usually occurs in the hundreds of RPM. It wouldn't be unusual for an electric motor to generate torque peak at 400 RPM, then taper off by a couple of percentage points in the 5k to 6k RPM range, then taper off gradually from there. I found a pretty interesting graph that shows the contrast between the two: http://www.global-greenhouse-warming...uegraph_v2.gif First off, this is an unfair graph. They marginalize the IC engine by comparing a high-performance EV (Tesla Roadster) with an economy oriented IC engine, but even if you were plotting an N55 against the motor in the Tesla, you'd see that the profile of the torque curve on the N55 can't match the one in the Tesla. Scaling the torque plateau of an electric motor upward is simply a matter of engineering. The profile of the curve doesn't change much. Another down side of IC engines is their link between RPM and efficiency. A gasoline engine must maintain a specific air-fuel ratio in order to sustain combustion. At high RPM, you're moving a lot of air, thus you must supply more fuel. This holds true, even if you restrict air intake with a throttle. You are still turning more RPM and igniting the fuel-air mixture more rapidly, and thus consuming more fuel. This means that if you want to prioritize fuel economy, you need to operate your IC engine at low RPM. If you also want to go fast, you need more gears. Let's circle back to the original quandary. Why don't electric cars need gearboxes? Two reasons: 1) Electric motors generate usable torque over a very broad RPM range. 2) Electric motors (depending on design) do not suffer a steep efficiency penalty from high-RPM operation
His: 2019 R1250GS - Black
Hers: 2013 X3 28i - N20 Mineral Silver / Sand Beige / Premium, Tech Past: 2013 ///M3 - Interlagos Blue Black M-DCT Past: 2010 135i - TiAg Coral Red 6MT ///M-Sport |
07-18-2012, 07:32 PM | #24 |
Rep 2
Hey guys,
Thanks for all the kind words about the build. And Red Dot Racer, swing by man, it's been a while. Regarding the 2 speed trans: Our torque curve is completely flat until about 4000 rpm. We are putting out just north of 700 lb/ft at the wheels, so we have plenty of low end torque, but to get a top speed in the 150mph range we needed the extra gear, and it allows us to have some bottom end with the low gear. One interesting thing, we're using an E34 (big) diff case (thanks Rally Road) with 2.81 gears, so we have a pretty tall ratio in the back. With the stock 3.23 in the M, we were redlining at about 125mph. Also, we're not doing this just to be green. We're doing it because it's all about the torque. I've never felt any car that produces MAX torque off the line, and holds it all the way up. It truly is like nothing else, even if it's expensive and heavy. It's pretty clear once they improve the batteries (and they are), I can't imagine OEM's like BMW not offering this in a stock M chassis. Perhaps they will still pipe engine noises into the cabin. Thanks again, the BMW community is truly one of the best, and we're stoked that we picked an E36 to do this project. Best decision ever. |
07-18-2012, 09:25 PM | #25 | |
100
Rep 1,265
Drives: 1973 Jensen Interceptor
07-18-2012, 11:45 PM | #26 |
TIM YOYO
1506
Rep 3,282
Drives: 2013 M3
HUZZAH!
