05-05-2011, 11:32 AM | #23 | |
365
Rep 1,149
But ya I work pretty much every muscle and while i do get a little pump on other days, my biceps look huge when I work them out separately. |
05-05-2011, 05:39 PM | #24 |
37
Rep 635
I think it really just depends on what you are trying to do. If you want massive biceps, yea you need work them more.
If you are focusing on core overall body strength for stuff like MMA, Crossfit, Olympic lifting, etc. then no, you don't need to.
2009 e92 M3 - AW DCT - Apex Arc8s - Corsa
05-06-2011, 02:59 PM | #25 |
26
Rep 126
If you want massive biceps, you need to work the large muscle groups of your body. You body wants to balance things out. For example, if you do nothing but bicep curls and don't do anything at all for you tri's, shoulders, or back, your biceps will not continue to grow huge. You wouldn't have the supporting muscles to counteract the biceps, so your body won't continue to build them.
I rarely do bi or tri exercises. I do a lot of multi-joint movements including squats, deadlifts, pull-ups, bench press type stuff (bar bench, db bench, pushups, etc.), shoulder presses, etc. I get a good workout to my bi and tri's doing this. Sometimes I will knock out a couple sets of curls or tricep dips at the very end of a workout just to get an extra burn. |
05-06-2011, 03:44 PM | #26 |
14
Rep 232
Personally I value gaining strength over having HUGE pipes for arms. I would focus on compound movements such as pull ups and chin up and your biceps will come along as they need to help move your body weight. In fact I hate people who insist on curling in the squat rack and can usually out curl them with rarely ever touching the specific workout.
05-06-2011, 03:57 PM | #27 |
167
Rep 4,013
05-06-2011, 04:57 PM | #28 | |
26
Rep 126
05-10-2011, 07:36 PM | #29 | |
Rep 38
Curling in the squat rack is really annoying, ppl just don't want to bend over to pick the weight up i suppose? I would go as high weight as possible, keeping strict form and as many sets as possible per body part. I train to failure on every body part. With proper diet and supplementation, they will have no choice but to grow! |
05-10-2011, 07:42 PM | #30 |
14
Rep 232
05-10-2011, 07:47 PM | #31 | |
Rep 38
Everyone is diff, I would not see any improvement in my bi or tri if i only did those exercises. Now this is just my opinion and my observations btw... Squats= ass/legs Deads= hams/back pull ups= back/lats bench= chest if I did a couple of sets of curls or dips I would never get a pump , i need about 45mins for bi's and 40 mins for tri's. |
05-10-2011, 08:20 PM | #32 |
Rep 38
05-10-2011, 08:50 PM | #33 | |
408
Rep 3,583
Drives: 2017 M3
05-11-2011, 05:39 PM | #34 | |
14
Rep 232
Squats: Full body Deads: Full body Pull ups: most of upper body Bench: most of upper body Also there is some stuff I've read that pushing until failure isn't necessarily optimal... Tim Ferris did some studies and found better results were obtained doing a smaller prescribed amount of work than all the way to dead because of the toll it takes and the extension of recovery time that failure introduces. Just a thought... Now knowing what that Rx'd load is is the hard part |
05-11-2011, 06:39 PM | #35 | |
Rep 38
When I do an set of something I go into it already thinking of how its going to feel, as in if I'm doing a pull up i will squeeze my back/lats and stretch them on the bottom. Sure you use a lot of supporting muscles in a movement, but if i relied on them to get a workout indirectly then I'd never grow... You are right on the failure part...i have read that also, but after a certain point i plateau and need it. Recovery is not an issue with supplementation (but thats a whole diff topic on a whole diff board,lol),I train pretty hard...when i leave the gym i feel like i was just jumped by like 15 cholos with baseball bats! sets of 455lbs deads / good in 2 days. |
05-12-2011, 01:53 AM | #38 |
27
Rep 707
I personally don't do any biceps because I do 8-10 sets of pull-ups on back days. If you do enough pull-ups, especially weighted ones, you really shouldn't need to work biceps out separately.
05-12-2011, 02:11 AM | #39 |
Rep 38
i guess it all depends on the goals you have...(the look you are trying to achieve,I.e. reynolds from the proposal or dwayne johnson from the other guys)
8-10 sets of weighed pull ups is outstanding! after t-bar rows,deads,bent over rows,lat pull downs and a few other machines theres no way i can do more than about 8 pull ups at the end of my workout. |
05-12-2011, 02:17 AM | #40 |
27
Rep 707
^ Yeah, that's usually my measurement if I did enough, if I can do >10 pullups after all those weighted ones, I do another set, haha. I do a push-pull with pull-ups and military press and it usually works out pretty well with the antagonist muscle groups. The only problem I've found with weighted pull-ups is that they seem put a decent stressor on the shoulder joint, especially wider grips.
05-12-2011, 04:29 AM | #41 |
Rep 38
yes, i've seen this also... i get it in my side/rear delts pretty bad if my back is done and i push through wide grips. Mil presses hurt my shoulders so bad! If i do them too much my traps start to get a pump...it gets ugly and painfull, ends up looking like im wearing football pads,lol.
05-16-2011, 12:38 AM | #42 | |
62
Rep 1,457
05-17-2011, 08:05 PM | #43 |
60
Rep 2,014
I agree with E92snake. It depends on what your goals are. I like to work out my arms because I want them to grow above and beyond. And by doing seperate arm workouts I have some pretty large arms. I leave my back days to focus strictly on my back and if I get some bi pumps while doing so thats great but it is not enough for me to consider an arm work out.
