08-17-2010, 11:46 PM | #23 | |
![]() ![]() ![]() 1300
Rep 7,389
I shoot almost everything in Aperture Priority. I DO pay attention to the shutter speed. In the case of the mountain goat I was up over 1/1000 second because it was very windy on top of that mountain. Just because I used Aperture Priority I didn't ignore the shutter speed. I chose my DOF and then adjusted the ISO up to get a shutter speed that wouldn't be blurred by the strong wind. As you see, the light was very good. The 5D2 has exceptionally good IQ, but you could have gotten very close, particularly at these "internet sizes" with your Rebel.
08-18-2010, 12:34 AM | #24 | ||
![]() ![]() ![]() ![]() 332
Rep 17,315
Drives: E92 M3, E30 325i
great. thanks for the information. I've messed with the DOF but still learning the proper use of the ISO depending on the light, etc.. |
08-18-2010, 09:02 AM | #25 |
![]() 1338
Rep 1,624
Thanks. Yes, it was tweaked a little. Here's what I did:
1. slight curve correction. 2. masked the lenses and ///M badge so I could leave them colored while everything else was B&W. 3. clone stamped to get rid off all the moths that had landed on my rear windshield. 4. resized image. 5. unsharp mask to get back some sharpness after resizing. I typically do a little color correction using curves even with my L-series lens. I do find that not as much is needed w/ the L lens, though. I would also do steps 4 & 5 regardless of the lens I used. Step 3 is done as needed. Step 2 was just an artistic thing. I guess I'm basically saying that I didn't do those things, which wasn't much work, specifically because I had used the kit lens.
- Jeff
bosstones' flickr |
08-18-2010, 09:35 AM | #26 |
![]() 325
Rep 2,874
Bosstones, how do you do the mask? I'm still trying to figure that out.
08-18-2010, 11:08 AM | #27 | |
![]() 51
Rep 280
I'm in Aperture Priority 80% of the time so I'd stick with that. What do you mean by quality? If its color rendition, pro lenses help but a lot can be reproduced in photoshop. However, I prefer to get the best color initially but leaving the shutter open longer and using a lower ISO. If its sharpness, remember most lenses are sharpest atleast 2 stops down from wide open, so with the 17-55 I'd be in f5.6. If its DOF, get some primes. The 50 f1.8 is the best bang for your buck in DOF and quality. Your in-door portraits will look great at f2.0. The lense is only $100, GET IT!! If its composition, pick up a photography composition book at Borders. Start learning tips for different scenarios (landscape, documentary, journalistic, sports, portraits, events, etcs). Then its practice practice practice. |
08-18-2010, 11:13 AM | #28 | |
![]() 51
Rep 280
I'd use ISO 400 as your default, if your shutter speed sinks slower than 1/50 indoor (the shake in hand usually has no affect 1/50 or faster), then start increasing ISO until the shutter is faster than 1/50. |
08-18-2010, 11:38 AM | #30 | ||
Rep 17,315
I guess what I meant by quality was how sharp the picture was and how "vibrant" the colors were, etc.. I'm sure with the help of photoshop I could tweak the pictures I take to make them look better, but I do understand that I can't expect the same quality pictures from a $2000 setup compared to a $5000+ setup. I'll just practice with what I have and in the future if I stick with this hobby I'll decide whether to invest in some "above amateur level" gear. ![]() Quote:
08-18-2010, 11:51 AM | #31 | |
![]() 51
Rep 280
So for your 17-55mm make sure your shutter speed is faster the than 55 (or 1/55). For your 50mm maks sure your shutter speed is faster than 50 (or 1/50) If you get the 70-200L make sure your shutter speed is faster than 200 (or 1/200). Remember, longer focal lengths magnify the hand shake, so 1/200 minimum is needed. |
08-18-2010, 11:58 AM | #32 |
![]() ![]() ![]() ![]() ![]() 562
Rep 18,123
Assuming you are shooting cars:
http://www.carphototutorials.com/
![]() Current: 2010 Alpine White 335D LCI l 19" BBS LMs l KW V2 Coilovers l BMW Performance Grilles l MSport Front/Rear l Karbonwerke Trunk l F1 Pinnacle Tint 35% Former: E92 Space Grey 335i Latest pics |
08-18-2010, 12:03 PM | #33 | |
Rep 17,315
08-18-2010, 12:06 PM | #34 | |
Rep 17,315
08-18-2010, 01:45 PM | #35 | |
![]() 325
Rep 2,874
I have a great book on light. I'll post the title when I get home. |
08-18-2010, 05:42 PM | #36 |
Rep 17,315
awesome thanks!
08-18-2010, 08:19 PM | #37 |
![]() 325
Rep 2,874
OK, here it is. Stoppee's Guide to Photography and Light. Good read.
08-18-2010, 09:45 PM | #38 |
![]() 1338
Rep 1,624
Hey, Mike, any chance you can take a couple of quick low light/night shots with the new lens? Hand held would be fine since I seem to have an abhorrence towards using/carrying my tripod.
![]() Canon's 85mm prime is a pretty nice one and won't break the bank, too, BTW.
- Jeff
bosstones' flickr |
08-19-2010, 08:33 AM | #39 |
![]() 325
Rep 2,874
sure. you want night or evening? Give me an idea of the subject matter you envision and I'll see what I can do.
08-19-2010, 09:11 AM | #40 | |
![]() 1338
Rep 1,624
- Jeff
bosstones' flickr |
08-19-2010, 10:21 AM | #41 |
![]() 325
Rep 2,874
No problem. I have noticed I can get a very steady hold at 1/40 and 1/50 with the IS on mode 1. I'll try to get out tonight and shoot some shots.
08-19-2010, 10:45 AM | #42 |
Rep 18,123
85mm is very sharp. Here's the non-L:
![]() ![]() Here's the MkI version of the 70-200mm Probably too shallow DOF: ![]() ![]() All these were taken with my 40D before I got the 5D Mk II.
08-19-2010, 03:48 PM | #43 | |
THE Viv
![]() 196
Rep 4,743
Drives: 330i SE
![]() Quote:
![]() Here are a few shots, all taken hand-held (no tripod) under mostly low lighting conditions, using the Canon 85mm f/1.8 prime lens on my 5d Mark II using Av mode: Viv |
08-19-2010, 10:29 PM | #44 |
![]() 325
Rep 2,874
Bosstones, here are some essentially dark, high ISO shots from my driveway. All hand held and shutter speeds between 1/15 and 1/20.
